Suspension & Brakes Theory, alignment, spring rates....
anyone replaced rear trailing arm bushings with ball joint tool from autozone/advance auto
Old 08-13-2006, 01:15 PM
Dwight Schrute's Avatar
Default anyone replaced rear trailing arm bushings with ball joint tool from autozone/advance auto
i just replaced my lower ball joints yesterday using this universal tool. some of the cups look to be the right size for the rear trailing arm bushing. anyone know if it works right?
Old 08-13-2006, 02:32 PM
chrisw85's Avatar
the outter shell is about 3" in diameter. I just bought the SP Tools/schely tool honda bushing x-tractor, its the only way to go in my opinion.
the ball joint tool from autozone doesn't have large enough cups to do the rear trailing arm bushing.
Old 11-03-2007, 08:18 PM
coot_er's Avatar
Default Re: (chrisw85)
does anyone have this tool? how well did it work and how much did it cost?
Old 11-04-2007, 01:33 PM
doubleshotz's Avatar
Default Re: (coot_er)
http://shoptoolsshoptools.com/shopexd.asp?id=2784
Old 11-04-2007, 05:59 PM
coot_er's Avatar
Default Re: (doubleshotz)
wow, thats a little more than i was expecting. if you think about it is just a modified gear puller which is a $10 tool.
Old 11-05-2007, 04:25 AM
PatrickGSR94's Avatar
Many people will use that tool and then re-sell it. Try to find one used, use it, and then you can probably re-sell it to someone else for the same price you bought it for.
Old 11-05-2007, 07:55 PM
i ♥ snails
quicksilver1689's Avatar
i removed my trailing arms, used an old press put the back in called it a day. Took about an hour and a half or so. pretty simple.
Graybeard327
Honda CR-V & Element
07-16-2017 06:42 AM
drsab2000
03-01-2013 04:48 PM
Chef Andre
12-15-2008 01:26 PM
blaak-crx
Suspension & Brakes
10
06-02-2008 05:14 PM
Quick Reply: anyone replaced rear trailing arm bushings with ball joint tool from autozone/advance auto
