Suspension & Brakes Theory, alignment, spring rates....
ABS Light On
Old 10-01-2016, 04:10 PM
H22 CB's Avatar
Default ABS Light On
My car recently got rear ended and pushed into the car in front of me...kept the car, but now salvaged. Getting it registered again is a b!tch. I need to pass a brake and light inspection and an ABS light is an automatic failure. When I jump the diag port and turn the key on. I get a single quick flash of the ABS light, then nothing again until I turn off the ignition and turn it back on. I would think the code would repeat. Anyway, I assumed it was a code 1 and attempted to bleed the ABS since it was drained (but not run) due to the accident. A low pressure hose had been severed. When I jump the ABS relay to run the pump, it turns on but doesn't move any fluid. What's wrong here?
newhondaowner29
01-11-2006 08:11 PM
f22suzuka
04-21-2004 10:15 AM
Undercover_Skank
03-15-2004 07:13 AM
GSblueRacing
05-06-2003 09:21 PM
CNSK
04-12-2003 11:13 PM
Quick Reply: ABS Light On
