Suspension & Brakes Theory, alignment, spring rates....
abs delete?
Old 10-23-2010, 05:32 PM
mmcsiggi's Avatar
Default abs delete?
i have a 98 dc2 type r and i want to delete the abs..
so the only thing i need is the 4040 prop valve?
and will some abs light be on forever or what?
thanks
Old 10-24-2010, 07:29 AM
blackGSRcoupe94's Avatar
Default Re: abs delete?
40/40 prop valve, brake lines from MC to prop valve, brake lines from prop valve to front shock towers.
Old 10-24-2010, 12:44 PM
mmcsiggi's Avatar
what about the abs light? will it be a problem?
Old 10-25-2010, 02:34 PM
actually if the whole ABS wire harness is removed from the car the light will have no power. if for some reason it does come on, you can just pull the bulb out.
Old 10-26-2010, 01:38 PM
SOHCunderdog's Avatar
If you are certain you will not ever be putting back in ABS, remove all wiring for ABS, computer and the black box in the engine bay.
Old 10-27-2010, 09:09 AM
lsturbo33's Avatar
Master cylinder, brake booster, 2 lines from master to prop valve, and prop valve from 98+RS will be a direct bolt in. Or, get prop valve from 98+ integra RS and 2 custom lines from your current master cylinder to prop valve.
Old 10-28-2010, 03:42 PM
whats so special about a 98+ RS prop valve?
Old 11-02-2010, 12:20 PM
lsturbo33's Avatar
The 94-97 and 98-01 RS integras came factory without abs. The prop valves are different between the two. Get the right prop valve and the rear brake lines will bolt in to the prop valve. Nothing special just the outside dimensions of the unit.
trm4life
04-27-2017 05:28 AM
speed_demon018
12-15-2012 07:11 AM
dc2teg06
04-27-2009 06:42 PM
dc4teg95
02-23-2009 04:15 AM
malubawla
20
04-09-2007 04:28 PM
Quick Reply: abs delete?
