Suspension & Brakes Theory, alignment, spring rates....
99 EM1 rear sway bar help!
Old 04-24-2012, 08:46 AM
Frase_civic's Avatar
Default 99 EM1 rear sway bar help!
Hey guys just picked myself up an EM1 a couple days ago, when it bought it I noticed the rear sway bar needed some attention but I wasn't too concerned about it, hoping this is an easy fix. The car is lowered with stock struts (I know its not good, but I will be upgrading in the near future to koni's) So my question is what is up with this rear sway bar? Its cold are rainy out right now so I am planning on fixing it this weekend when its nice. Here are some pics of whats going on.
1. Driver side sitting level
[IMG][/IMG]
2.Driver side jacked up
3.Passenger side sitting level
4.Passenger side jacked up
The kid before had put some aftermarket LCA's on it (they seem to be a no name brand) Are the end links gone, or did the kid just not reinstall the sway bar correctly? Or does it have something to do with the car being lowered? The rims are 15" and the tires are 195/60r/15's and the tire is just slightly tucked by about a 1/4" or less. Thanks for any help!!!
Cheers
Also heres a picture to get an idea of the ride height
[IMG][/IMG]
Also looking for a rear spoiler or trunk and spoiler combo if you live in Ontario
Old 04-24-2012, 09:36 AM
phunhaus's Avatar
Default Re: 99 EM1 rear sway bar help!
What is the problem you're trying to point out?
Old 04-24-2012, 09:56 AM
The driver side looks like it is incorrect? I have no experience with sway bars, from what I see online is the sway bar link sits directly up from the LCA making it 90 degrees.... the passenger one is pretty close but the driver looks like its way off?
Old 04-24-2012, 09:58 AM
And the bolts looks bent coming from the link connecting to the bar itself?
Old 04-25-2012, 07:26 AM
phunhaus's Avatar
They're a "ball joint" so they are intended to pivot like that.
The driver's side looks no different than the passenger side with the exception of the sway bar being slightly shifted over. Unbolt the bar from the chassis (not from the LCA's) and shift the bar to the driver's side so that it's centered. Reinstall.
Old 04-25-2012, 07:55 AM
Mr. EG's Avatar
The LR shock looks blown beyong belief.
Old 04-26-2012, 07:04 AM
Yeah I was thinking of doing that, ill shift it over for now and when the suspension comes in I plan on replacing the links while everything is apart.
Thanks!
Yeah she doesn't look too pretty, cant wait or the new set up to get here.
phat00civic
Suspension & Brakes
19
01-13-2012 01:51 PM
civexspeedy
08-25-2006 02:43 PM
KtotheEK
12-13-2004 11:14 AM
Jchild420
05-20-2004 08:55 PM
Quick Reply: 99 EM1 rear sway bar help!
