96 itr 4x114.3 rotor ?
I know there has been talk about this topic before but can some one tell me what usdm rotors work for my 96 itr rotors. my rotors are done and I can't machine them. I got the new pads (95 integra) front and rear. thanks in advance.
Daisy... Daisy...
Re: 96 itr 4x114.3 rotor ?
Measure you rotors and see what is comparable to this catalog.
http://www.dba.com.au/2006/PDF_CATAL...ies_020308.pdf
They are not going to list a rotor for your 96 Spec ITR. the rotors were the same size as a non-ITR, but the bolt circle is different. You need to measure the diameter, height, rotor thickness, and center bore.
theres a great thread on this topic over on dc2-itr site from the uk. check here to see what fits your car, or what an easy upgrade is-
http://www.itr-dc2.com/forum/viewtop...=19058&start=0
bump because I would like to know. I heard the prelude rotors were the ones to use but I would like a definate answer before my rotors are done
Daisy... Daisy...
Not for a 96 spec ITR. The brakes on that were the same size as any non-ITR DC2 or DC4. The 4x114.3 bolt pattern makes things difficult.
I drive a G35, it's silver, surprised?
92-97 Prelude Vtec rotors are replacements for the front. The specs are identical to the 96 spec ITR.
There are no replacements for the rear. You will have to find regular Integra rear rotors and drill them out to 4x114.
^ The above are results of extensive research. If anyone can find an alternative to the above, I'd really like to know for my own set up.
Daisy... Daisy...
A 97 Prelude has a 5x114.3 pattern. 4x114.3mm ITR brakes use the same front rotor as a nonITR DC2 or a DC4, which are 262mm. (The calipers share the same p/n.) The 5x114.3mm ITR front rotors are 282mm diameter.
- 92-96 Prelude Vtec 4x114 11" rotor
- 92-96 Prelude Non Vtec 4x114 10.234"
If you upgrade to ITR calipers, you can certainly use the Prelude Vtec rotors.
He knows where you live!
Sorry, 92-96 Prelude.
94-97 Accords are a 10.xx" rotor but are Hub over Rotor.
The 97ish CL 2.3 Premium is the one you'd want. It's what we use to go RoH and retain 4x114 and same rotor size.
horsekiller
Suspension & Brakes
05-15-2009 09:56 AM
