1 broken lug nut stud OMG!! - Honda-Tech
Old 07-30-2011, 10:02 PM   #1
Default 1 broken lug nut stud OMG!!
my dumb *** friend over tight one of my lug nut stud and it broke off, now my car runs hella shitty when u doing 70-80mph, it literally shakes my front end. Can the one broken stud fucc up the driving stability?
jdmcivic2fast is offline   Reply With Quote
Old 07-30-2011, 10:08 PM   #2
v8killaz's Avatar
Default Re: 1 broken lug nut stud OMG!!
not really but it could if the rims are non oem and the hub rings dont align properly. just get a new stud for a dollar and slap it in
v8killaz is offline   Reply With Quote
Old 07-30-2011, 10:28 PM   #3
99civ's Avatar
Quote:
So 3 out of 4 tightened will balance the same as 4 tightened and spin the same?
Listen to me, fix this ASAP. It will break more than one as time/miles roll on. I had a rear with 3/4 tightened and 99... my car broke down on the way to Indiana(not even 100 miles in). I knew better but immaturity controlled the situation. It's a simple 10 dollar fix as long you have access to a press.. I've had them go bad on a trip(IU) and a neighborhood ride just miles away. Not worth the labor to NOT fix it prior to anything happening..
99civ is offline   Reply With Quote
Old 07-30-2011, 10:30 PM   #4
yea rims are oem, it drove fine before the stud broke, now it shakes like the tires are outta balance or something. Where can I find a stud for a dollar? Do I have to press the hub bearing out to get to the stud?
Old 07-30-2011, 11:35 PM   #5
99civ's Avatar
Quote:
Yes and when I last checked they were like 8 bucks at honda.. Looks like 1.75+shipping on ebay.
Old 07-31-2011, 04:34 AM   #6
Master Detailer
98civdx's Avatar
First, there is noithing wrong with running on 3 of the four for a short time. Assuming all of the others are tightened to proper spec.
Yes, I am speaking from experience. I drove my car for over a year with only 3, and guess what? NOITHING happened.
No, you do not need to press in a new bearing. All you need to do is grind one edge of the stud, and it should slip right in. Again, I am speaking for experience. it's very very simple to do.
You can go down to a autoparts store and pick up studs all day long. But I would adivse biting the bullet and buy OEM, or something such as ARP studs.
When you broke the stud, and before you drove it, did you make sure to tighten the others to the correct spec?
98civdx is offline   Reply With Quote
Old 07-31-2011, 06:44 AM   #7
The Grumpiest
grumblemarc's Avatar
Quote:
Originally Posted by 98civdx View Post
First, there is nothing wrong with running on 3 of the four for a short time. Assuming all of the others are tightened to proper spec.
Yes, I am speaking from experience. I drove my car for over a year with only 3, and guess what? NOTHING happened.
Same here. Had a stud that was crossed threaded or a while. Never had vibrating/shaking issues. Possibly something else is broken/warped now.
grumblemarc is offline   Reply With Quote
Old 07-31-2011, 10:08 AM   #8
v8killaz's Avatar
ive driven with 2 studs stripped on a 4 lug perfectly fine. its not safe but who cares.
and yes autozone sells studs for cheap. i think 1-2 bucks last time i went i grabbed like 10
Old 07-31-2011, 11:52 AM   #9
99civ's Avatar
No reason to have a pissing match when we've obviously both have had different experiences.. You're given 4 studs to tighten 4 lugs. Can you run 3? Sure. Should you be so comfortable with it to not fix it? If its only shaking @ 75-80, like someone already stated, you might already have something out of whack.
Old 08-01-2011, 02:29 PM   #10
Im not sure if it's all tight to spec cause it was my dumb friend who did it(thought he knew how to fix cars) cause i had to go pick up the wife. whats the spec anyways? I'll have to double check, but most likely i'll replace the stud. anyone got a quick picture or a do it yourself instruction on taking out the stud without a press? I wanna see where u have to grind to make sure it'll be ok to grind before I get into bigger trouble lol
Old 08-01-2011, 04:03 PM   #11
Did your friend over tighten others that may break or not be holding tight? You may not have 3 good.
Drive 4 fun is offline   Reply With Quote
Old 08-01-2011, 04:22 PM   #12
Master Detailer
98civdx's Avatar
80lb's.
Google it, you'll find something
Old 08-01-2011, 04:25 PM   #13
v8killaz's Avatar
check youtube. ive seen videos of people doing them on hondas
Old 08-02-2011, 03:45 AM   #14
Ek Forever y0!
Libertariat's Avatar
There's nothing wrong with an Autozone replacement stud. I rode on 3 lugs for probably 2 years and finally replaced it when I started autocrossing about 5 months ago. Been holding up fine.
Libertariat is offline   Reply With Quote
Old 08-02-2011, 11:27 AM   #15
can i reuse a stud from another hub? i got another like 4 good but used studs from a different knuckle hub assembly
Old 08-02-2011, 11:33 AM   #16
saw the youtube vid on a green del sol. So i guess u grind down a part of the stopping plate on the stud?
Old 08-02-2011, 12:08 PM   #17
The Grumpiest
Yes.
Old 08-02-2011, 05:50 PM   #18
ok called honda this morning and they want 8 bucks for it, so I said umm f it since im only replacing 1 i'll it up autozone. grabbed a new one from autozone for $1.99 came out to $2.15 out the door. I pretty much follow the video on youtube and grinded down the stopping plate on the new stud. I grinded the stud all the way down on one side but it still didn't have enough clearence to shoot the stud straight into the hole on the hub plate, so I had to grind down the side of the knuckle a bit to get it clear meanwhile I had the new grinded stud in the freezer. after a bit of grinding the knuckle I got the stud from the freezer and it poped right into the hole. I then used a 32mm axle nut and a lug nut to tight and pull the new stud into its home. Everything worked out flawless and the car seems to ride much better now.
thanks for all your help guys ireally appreciate it!
Loose lug nut stud eM2tK Honda Civic (2001 - 2005) 1 03-09-2011 11:15 AM
95 Civic Lug Nut Stud Replacement zeeartist09 Tech / Misc 5 08-12-2010 10:51 AM
broken wheel stud, lug nut is stuck on help 98civdx Honda Civic / Del Sol (1992 - 2000) 12 09-20-2009 01:23 AM
Broken Wheel Studs Jordan_4WS Honda Prelude 4 08-20-2002 06:53 AM
lug nut stud replacement D16y8Joe Honda Civic / Del Sol (1992 - 2000) 7 07-25-2002 03:11 PM
Tags
99, accord, broke, broken, car, fix, honda, lug, lugnut, nut, pilot, run, snapped, stud, tire
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
