04 accord.
04 accord.
04 Honda Accord v6 Automatic
I just replaced both front wheel bearings and upper + lower arms. I'm putting everything together and and I'm having difficulty putting the CV axle spline into the wheel hub assy. Anyone run into this before?
Cool Cool Island Breezes. BOY-EE
Re: 04 accord.
A lot of people have trouble with this. Sometimes its just your technique that needs adjustment. Other times, its because you pulled on the axle and seperated the inner joint.
How are you doing this? Which ball joint is disconnected? And what position is your steering wheel in?
Did you pull on the axle or let it droop and seperate? Look at the boot closest to the trans. Does it look kinda stretched?
Getsch
10-24-2005 03:02 PM
