FS: NEW DNA Motoring Tubro Kit / 880CC Injectors CIVIC/CRX/DEL SOL INTEGRA B-SERIES
Old 09-02-2013, 09:26 PM
deary09's Avatar
Default FS: NEW DNA Motoring Tubro Kit / 880CC Injectors CIVIC/CRX/DEL SOL INTEGRA B-SERIES
text me: 626-602-6264
9/14/13 PRICE $500 FIRM PICK UP FOR TURBO KIT AND EXTRA $230 FIRM FOR THE INJECTORS
Box has been open just to look at only. HONDA CIVIC/CRX/DEL SOL, ACURA INTEGRA B-SERIES CAST IRON MANIFOLD TURBOCHARGER KIT.
KIT INCLUDES:
T04E TURBO CHARGER
50 A/R Compressor, .63A/R Turbine
T3 Flange to Manifold
5 Bolt Downpipe Flange
3" Inlet Diameter & 2" Outlet Diameter
BAR AND PLATE UNIVERSAL TURBO INTERCOOLER
27x7x2.5
2.5" outlet and inlet
150 to 130 Degree Temperature Drop
B-D SERIES INTERCOOLER PIPING KIT
(MINOR MODIFICATIONS MAY BE REQUIRED FOR PERFECT FIT)
Cast T Bolt Clamps
Silicone Hoses
T3 Turbo Down Pipe
Manufactured with high grade Cast
Direct Bolt on application (may require minor modification bends when used in conjunction with cast manifold)
Cast Iron Turbo Manifold for B-Series Engine
Made of High Grade Stainless steel
Uses T3 Turbos and 35MM/38MM Wastegate Flanges
All nuts and bolts included
38MM Wastegate
Utilized 35MM/38MM Flanges
V-Band top allows for quick changing of springs
Flanges and Gaskets are included
Designed to efficiently release pressurized gas
Complete control of Turbo PSI
BOV Blow-off Valve
High quality fitting
Prevents compressor surge, releases compressed airflow, and provides an aggressive sound
CNC anodized
BOV Flange Pipe
Perfectly suited for the BOV
Durable, made of high quality materials
Boost Controller
Conveniently adjust turbo PSI to control your desired boost
CNC anodized aluminum finish
Air Filter Adapter
Direct bolt on with out any modifications
Oil Drain Kit
Durable. Will last a lifetime
Turbo Oil Drain
High strength oil drain line
Oil Feed Kit
Turbo Oil Feed
High strength oil feed line
Professional Installation is Highly Recommended (No Instructions Included)
ASKING $560 PICK UP NO BS NO FLAKERS SERIOUS BUYERS ONLY. OUT OF THE HONDA SCENE, TIME TO MOVE ON SALE
Also have Brand new in box Precision Turbo Injectors 880CC for an extra $250
deary09 is offline
Old 09-02-2013, 10:35 PM
olddohc's Avatar
Default Re: FS: NEW DNA Motoring Tubro Kit / 880CC Injectors CIVIC/CRX/DEL SOL INTEGRA B-SERI
How much hp did they say the kit is capable of?
olddohc is offline
Old 09-03-2013, 06:14 AM
deary09's Avatar
It is a T3/T4 turbo kit so i would say 350hp max. I was only gonna boost 6psi because my compression is high since i'm built all motor setup currently b20v.
deary09 is offline
Old 09-03-2013, 10:57 AM
deary09's Avatar
If anybody interested in the turbo kit and injectors, I can give a better deal.
deary09 is offline
Old 09-07-2013, 09:19 AM
deary09's Avatar
bumppp
deary09 is offline
Old 09-07-2013, 06:40 PM
deary09's Avatar
ttt.....
deary09 is offline
Old 09-08-2013, 08:28 AM
deary09's Avatar
Make me a reasonable offer
deary09 is offline
Old 09-09-2013, 04:41 PM
deary09's Avatar
upupup
deary09 is offline
Old 09-10-2013, 04:43 PM
deary09's Avatar
213
deary09 is offline
Old 09-11-2013, 05:05 PM
deary09's Avatar
310
deary09 is offline
Old 09-11-2013, 05:52 PM
4drferio's Avatar
bump blo0od
4drferio is offline
Old 09-12-2013, 05:37 PM
deary09's Avatar
Originally Posted by 4drferio
bump blo0od
thx B
deary09 is offline
Old 09-14-2013, 09:01 AM
deary09's Avatar
new price to sell
deary09 is offline
Old 09-16-2013, 04:54 PM
deary09's Avatar
323
deary09 is offline
cdnsigop
05-18-2015 11:01 PM
94eg5squadMD
Mid-Atlantic (Sales)
06-09-2010 05:44 AM
94eg5squadMD
12-14-2009 08:18 PM
wfocrx
02-27-2008 10:09 AM
Quick Reply: FS: NEW DNA Motoring Tubro Kit / 880CC Injectors CIVIC/CRX/DEL SOL INTEGRA B-SERIES
