B18A1 Swap - Recently Overhauled 3k Miles and counting
Old 10-20-2016, 08:30 AM
JDM_JNKY's Avatar
Default B18A1 Swap - Recently Overhauled 3k Miles and counting
This is an engine swap. Complete running Longblock w/ LSD transmission. It's freshly rebuilt. If this sells before my JDM B18C, I'll pull this swap for buyer and install my B18C. This item is still being used daily. I drive 36miles to and from work, I got to meets when possible, I've used the car competitively once so far in Vtec Club Road racing. I plan to do so until I swap in a vtec motor or complete my b20 build. The mileage is being accurately tracked and I'm an open book. If you have any questions ask, I will do my best to answer them.
Serious Buyers contact me for more details and warranty terms. I don't not respond on sundays it's family day.
909 728 5033 JOEL
$3,000 B18A1 SWAP w/ "GSR" LSD trans - 3,500 miles since overhaul. It would take more than $3500 to build this setup or have it built. Adding up the major components and machine shop labor I arrived at 3,535. Price is firm.
Product Description:
B18A1 HI-COMP SWAP - 3,000 miles since overhaul. Still in car for test drives/and or video footage
HEAD - P75 LS
New Brain Crower 2
Ported Intake and exhaust
Head Resurfaced .004
3 Angle valve job
B16 inner Valve springs
LS outer valve springs & retainers
5 bolt quality Cam Gears - I forget the company name.
Supertech Valve Seals
8 Exhaust Valve Guides
OEM B20 Intake Manifold
Port Matched TB opening 68mm
Thermal IM Gasket
Thermal TB Gasket
Omni 68mm TB
Moroso Valve Cover w/ extra gasket kit
NGK wires
NGK 7's
CLS v1 Tri-Y Header ceramic coated & wrapped
Aem Fuel Rail
Aem FPR
Liquid Fuel psi gauge
Lucas 440cc Injectors
BLOCK - B18A1
Fresh Hone
Fresh Bore
OEM Honda Head Gasket
PR3 82mm Pistons
ARP rod bolts
Nippon Hi Performance Rings
ARP head studs
GMB water pump
Orbit high volume oil pump
New ITM Timing Belt
King XP Bearings Main, Rods, & Thrust .0015
MOROSO Oil Pan
TRANSMISSION - LS w/ ITR LSD & 4.4FD
Overhauled
ITR Helical LSD
4.4 FD
1-2 5/R Brass Synchros
3-4 Carbon Synchros
1-2 slider
3-4 slider
5-6 slider
All bearings
All seals
Starter
EXTRAS
EXTRAS
Chipped VTEC ECU tuned by David at Import Auto Pros
OBD 1 Harness freshly taped and loomed
New Driver Axle
Passenger Axle
Half shaft
Lightened OEM flywheel
XTD stage 2 pressure plate
XTD stage 2 6 puck sprung disc
This is only an HT photo w/ user tag. All parts received will be LISTED items ABOVE ONLY.
JDM_JNKY is offline
Old 10-29-2016, 06:52 PM
JDM_JNKY's Avatar
Default Re: B18A1 Swap - Recently Overhauled 3k Miles and counting
Still running healthy
JDM_JNKY is offline
Old 11-14-2016, 08:50 AM
JDM_JNKY's Avatar
Daily Driven. Still for sale.
JDM_JNKY is offline
Old 11-23-2016, 07:10 AM
JDM_JNKY's Avatar
Switched up a few things. Re-tuned last week. Made 152.81whp mustang dyno, on 91 w/ TSX injectors, OEM Intake manifold ported, 68mm TB. tampered 4-3" intake w/ ac and p/s.
JDM_JNKY is offline
Old 11-23-2016, 10:35 PM
kingofbattle909's Avatar
ttt
kingofbattle909 is offline
Old 11-28-2016, 02:08 PM
aftermath1312's Avatar
Bump
aftermath1312 is offline
Old 11-28-2016, 02:14 PM
JDM_JNKY's Avatar
Thanks Guys.
JDM_JNKY is offline
Old 11-28-2016, 02:47 PM
da6er's Avatar
Legit!!!
da6er is offline
Old 12-22-2016, 11:10 PM
Ttt
Old 12-24-2016, 04:29 PM
JDM_JNKY's Avatar
Thanks Gents
JDM_JNKY is offline
Old 12-25-2016, 07:32 AM
jdmeg6118's Avatar
Deals
jdmeg6118 is offline
Old 01-19-2017, 07:03 PM
JDM_JNKY's Avatar
Still for sale. Runs & Drives beautifully. Still in the car for buyer and I to go have a spin. It's a LS engine w/ ITR Horsepower.
JDM_JNKY is offline
Old 01-24-2017, 08:49 AM
JDM_JNKY's Avatar
just some info. I thought I'd share. I know a lot of people see a $3k LS but it's well work it.
DIY SWAP COSTS
jdm b20b $450
Craigslist trans w/ grinds or hot $250-350 w/out $450-650
shift linkage $50-$100
Header Ebay Cheapie $50 Ebay decent $150 Good Header $250
axles $50 used new $150
halfshaft $50
Mounts $100 ebay $150 decent $250 innovative
Harness $50-100
Intake oem $40 aftermarket $50-350
Timing belt water pump $100
That’s a ebay parts swap at 1200, no installation, no fluids w/ a engine that has 65k+ miles on it. Then let's say you go on to modify it:
intake manifold $80-150
TB $100-150
Cams $150 - 350
cam gears $150
pistons & rings $150
rod bolts $90
gasket kit $100
oil pan $175
ARP Studs $150
OEM Gasket $110
Machine shop bore, hone, resurfacing, valve job, valve seals, crank polishing $300-500
head porting $200-400
port matching $100
Bearings $150
Now modified we are at 3205, all calculated at the least listed price. Notice it does not include engine assembly labor, engine installation labor, extras like plugs, wires, fluids. These are the bare figures. Assembly labor we will say $500, because that’s logical. Installation we will not post a price, why? Because Backyarders are plenty - so we will say that is “free 99.” With assembly we arrive at $3705. $3705 on a ebay “built” swap. $700 over what I’m asking for a quality brand built swap, Tuned.
I didn't even bother calculating transmission costs. LSD, Clutch, flywheel, overhaul parts and related labor. You get the picture.
JDM_JNKY is offline
Old 02-17-2017, 06:26 PM
JDM_JNKY's Avatar
bump
JDM_JNKY is offline
Old 02-18-2017, 07:51 AM
king06's Avatar
Good luck. But that's ITR money for an ls with a bunch oem parts and ebay parts. I don't doubt you would spent more building it, I just don't see it.
king06 is offline
Old 02-18-2017, 11:47 PM
JDM_JNKY's Avatar
Then it's just not meant for you to see. Thanks for the input, I appreciate you stopping by to take a look.
Some key points to look at/consider: Used higher mileage R vs Freshly overhauled LS, buyers choice. At the end of the day, I'm not on the forums with a gun, saying by me now! Simply advertising a full swap for sale. It can hang, chase down and out run may Vtec engines. If a person doesn't know what they are buying then I can totally see how the price wouldn't make sense. Saying you have an R for bragging rights doesn't mean anything if a LS non Vtec is passing you by.
JDM_JNKY is offline
Old 03-01-2017, 08:08 PM
LiL accORd RideR's Avatar
LiL accORd RideR is offline
Old 03-01-2017, 09:42 PM
PilotOnDubs's Avatar
PilotOnDubs is offline
Old 03-07-2017, 10:36 PM
JDM_JNKY's Avatar
THANKS GUYS
JDM_JNKY is offline
Old 03-10-2017, 10:53 AM
xlonelydrifterx's Avatar
are you willing to separate?
xlonelydrifterx is offline
Old 03-10-2017, 06:03 PM
JDM_JNKY's Avatar
Not interested in separating anything listed here. It will remain as a swap. Whether it sits in my car, or on a garage floor.
JDM_JNKY is offline
Old 03-22-2017, 08:26 AM
JDM_JNKY's Avatar
Up Up.
JDM_JNKY is offline
Old 03-30-2017, 06:58 AM
JDM_JNKY's Avatar
bump
JDM_JNKY is offline
Old 03-30-2017, 07:43 AM
da6er's Avatar
da6er is offline
jdm_ek_noob
10-09-2013 03:53 PM
13173
Appearance Build Threads
137
10-03-2010 07:57 AM
slateEKsi
Northeast (Sales)
34
03-28-2010 04:42 PM
JB3BELL331
01-27-2004 02:23 PM
Quick Reply: B18A1 Swap - Recently Overhauled 3k Miles and counting
