B18A1 Swap - Recently Overhauled 3k Miles and counting
This is an engine swap. Complete running Longblock w/ LSD transmission. It's freshly rebuilt. If this sells before my JDM B18C, I'll pull this swap for buyer and install my B18C. This item is still being used daily. I drive 36miles to and from work, I got to meets when possible, I've used the car competitively once so far in Vtec Club Road racing. I plan to do so until I swap in a vtec motor or complete my b20 build. The mileage is being accurately tracked and I'm an open book. If you have any questions ask, I will do my best to answer them.
Serious Buyers contact me for more details and warranty terms. I don't not respond on sundays it's family day.
909 728 5033 JOEL
$3,000 B18A1 SWAP w/ "GSR" LSD trans - 3,500 miles since overhaul. It would take more than $3500 to build this setup or have it built. Adding up the major components and machine shop labor I arrived at 3,535. Price is firm.
Product Description:
B18A1 HI-COMP SWAP - 3,000 miles since overhaul. Still in car for test drives/and or video footage
HEAD - P75 LS
New Brain Crower 2
Ported Intake and exhaust
Head Resurfaced .004
3 Angle valve job
B16 inner Valve springs
LS outer valve springs & retainers
5 bolt quality Cam Gears - I forget the company name.
Supertech Valve Seals
8 Exhaust Valve Guides
OEM B20 Intake Manifold
Port Matched TB opening 68mm
Thermal IM Gasket
Thermal TB Gasket
Omni 68mm TB
Moroso Valve Cover w/ extra gasket kit
NGK wires
NGK 7's
CLS v1 Tri-Y Header ceramic coated & wrapped
Aem Fuel Rail
Aem FPR
Liquid Fuel psi gauge
Lucas 440cc Injectors
BLOCK - B18A1
Fresh Hone
Fresh Bore
OEM Honda Head Gasket
PR3 82mm Pistons
ARP rod bolts
Nippon Hi Performance Rings
ARP head studs
GMB water pump
Orbit high volume oil pump
New ITM Timing Belt
King XP Bearings Main, Rods, & Thrust .0015
MOROSO Oil Pan
TRANSMISSION - LS w/ ITR LSD & 4.4FD
Overhauled
ITR Helical LSD
4.4 FD
1-2 5/R Brass Synchros
3-4 Carbon Synchros
1-2 slider
3-4 slider
5-6 slider
All bearings
All seals
Starter
EXTRAS EXTRAS
Chipped VTEC ECU tuned by David at Import Auto Pros
OBD 1 Harness freshly taped and loomed
New Driver Axle
Passenger Axle
Half shaft
Lightened OEM flywheel
XTD stage 2 pressure plate
XTD stage 2 6 puck sprung disc
This is only an HT photo w/ user tag. All parts received will be LISTED items ABOVE ONLY.
909 728 5033 JOEL
HEAD - P75 LS
New Brain Crower 2
3 Angle valve job
Thermal IM Gasket
Thermal TB Gasket
Omni 68mm TB
NGK wires
NGK 7's
Aem Fuel Rail
Aem FPR
BLOCK - B18A1
Fresh Hone
Fresh Bore
PR3 82mm Pistons
ARP rod bolts
ARP head studs
GMB water pump
New ITM Timing Belt
MOROSO Oil Pan
Overhauled
ITR Helical LSD
4.4 FD
3-4 Carbon Synchros
1-2 slider
3-4 slider
5-6 slider
All bearings
All seals
Starter
EXTRAS EXTRAS
New Driver Axle
Passenger Axle
Half shaft
Re: B18A1 Swap - Recently Overhauled 3k Miles and counting
Switched up a few things. Re-tuned last week. Made 152.81whp mustang dyno, on 91 w/ TSX injectors, OEM Intake manifold ported, 68mm TB. tampered 4-3" intake w/ ac and p/s.
just some info. I thought I'd share. I know a lot of people see a $3k LS but it's well work it.
DIY SWAP COSTS
jdm b20b $450
Craigslist trans w/ grinds or hot $250-350 w/out $450-650
shift linkage $50-$100
Header Ebay Cheapie $50 Ebay decent $150 Good Header $250
axles $50 used new $150
halfshaft $50
Mounts $100 ebay $150 decent $250 innovative
Harness $50-100
Intake oem $40 aftermarket $50-350
Timing belt water pump $100
That’s a ebay parts swap at 1200, no installation, no fluids w/ a engine that has 65k+ miles on it. Then let's say you go on to modify it:
intake manifold $80-150
TB $100-150
Cams $150 - 350
cam gears $150
pistons & rings $150
rod bolts $90
gasket kit $100
oil pan $175
ARP Studs $150
OEM Gasket $110
Machine shop bore, hone, resurfacing, valve job, valve seals, crank polishing $300-500
head porting $200-400
port matching $100
Bearings $150
Now modified we are at 3205, all calculated at the least listed price. Notice it does not include engine assembly labor, engine installation labor, extras like plugs, wires, fluids. These are the bare figures. Assembly labor we will say $500, because that’s logical. Installation we will not post a price, why? Because Backyarders are plenty - so we will say that is “free 99.” With assembly we arrive at $3705. $3705 on a ebay “built” swap. $700 over what I’m asking for a quality brand built swap, Tuned.
I didn't even bother calculating transmission costs. LSD, Clutch, flywheel, overhaul parts and related labor. You get the picture.
DIY SWAP COSTS
jdm b20b $450
halfshaft $50
Harness $50-100
TB $100-150
Cams $150 - 350
cam gears $150
rod bolts $90
gasket kit $100
oil pan $175
ARP Studs $150
OEM Gasket $110
port matching $100
Bearings $150
Then it's just not meant for you to see. Thanks for the input, I appreciate you stopping by to take a look.
Some key points to look at/consider: Used higher mileage R vs Freshly overhauled LS, buyers choice. At the end of the day, I'm not on the forums with a gun, saying by me now! Simply advertising a full swap for sale. It can hang, chase down and out run may Vtec engines. If a person doesn't know what they are buying then I can totally see how the price wouldn't make sense. Saying you have an R for bragging rights doesn't mean anything if a LS non Vtec is passing you by.
JDM_JNKY
11-23-2016 07:09 AM
13173
Appearance Build Threads
137
10-03-2010 07:57 AM
