Looking for a machine shop in hesperia applevalley victorville high desert area. - Honda-Tech
Old 03-13-2011, 08:42 PM   #1
No-Traction = Fun
CaliforniaDad's Avatar
Default Looking for a machine shop in hesperia applevalley victorville high desert area.
hey all you high desert rats. I'm looking for a good machine shop up here in the hesperia applevalley or victorville area.
I'm going to rebuild a B18C1 I picked up.
I need to do the following,
Head:
-pressure tested
-cleaned out
-3 angle valve job
-new valve seals
-and resurface
block:
-Hot Tank
-Hone all Cylinders
-Deck'd
-crank micropolished
CaliforniaDad is offline   Reply With Quote
Old 03-14-2011, 11:15 AM   #2
No-Traction = Fun
Default Re: Looking for a machine shop in hesperia applevalley victorville high desert area.
anyone? anyone?
Old 03-14-2011, 11:59 AM   #3
No-Traction = Fun
I pulled the pistons and rods out of the bottom end and cleaned them up. They look like there in great condition and I was wondering if I can/should reuse them. The block was a 2001 not sure how many miles. It had a bad rod bearing.
Old 03-17-2011, 04:25 PM   #4
No-Traction = Fun
Found a local shop and was told the rods need to be cut and re-sized back to spec. $20.00 each
Old 05-30-2011, 03:50 PM   #5
Hey, How much did they charge to rebuild your bottom end? Where is the shop located at bro? and What was done to it and how much did they charge.... i need a shop.... Thanx bro.
Smex26 is offline   Reply With Quote
Old 05-30-2011, 08:47 PM   #6
robcivic559's Avatar
i live around the same area would like too know 2 got a 90 LS da block and 94LS block
760 HI DES
robcivic559 is offline   Reply With Quote
Old 06-08-2011, 09:21 PM   #7
No-Traction = Fun
Arringdale's Engine Rebuilding
11918 I Avenue
Hesperia, CA 92345-4945
(760) 948-5155
Ask for Rick & tell them David G sent you!!!
Old 06-09-2011, 03:57 AM   #8
Daisy... Daisy...
Dogginator's Avatar
This will probably help more people in the regional forum.
Dogginator is offline   Reply With Quote
Old 06-09-2011, 10:33 PM   #9
SP GARAGE's Avatar
i know of 2 great engine builders in that area.... PM me... and i can help you get in contact with them... theres jeff from GO-PWR and LEO G. from LGwerkz
SP GARAGE is offline   Reply With Quote
Old 12-11-2015, 07:10 AM   #10
strategy400's Avatar
I've used Arringdales with great results. 100k on my D15B7 and still going strong. I plan to be a repeat customer.
strategy400 is offline   Reply With Quote
JDM B20 OEM OBD2 Distributor MurkyRiversEK For Sale 6 12-22-2015 10:20 AM
So. Cal Honda Theives Icon_Ed6 Honda CRX / EF Civic (1988 - 1991) 35 12-18-2010 01:20 AM
High Desert, Ca AutoHypes2k Honda S2000 6 03-08-2009 02:07 PM
wtt: NEW mugen style lip (eg2/eg6) for stock ex/si theskabeater Southern California (Sales) 1 12-07-2008 05:59 PM
HELP ME HELP YOU SALE II MUGEN CF-48s, EF8 RADIATOR, S2K R/C Drift car, Pioneer CD, Audiobahn amp, B DOHC_C-REX For Sale 34 01-06-2007 11:29 AM
Tags
acura, apple, body, desert, engine, fabrication, high, honda, integra, machine, performance, shop, shops, valley, victorville
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
