just got a BARD EF hatch with GSR swap - Honda-Tech
Old 10-12-2013, 08:18 PM   #1
gerard92692's Avatar
Default just got a BARD EF hatch with GSR swap
like the title says, I just picked a hatch. I plan on canyon run and track days. so the exhaust has a leak and the exhaust manifold is oem. i want to switch out the manifold for a header as well as the leaky exhaust but im not sure how to go about fitment since it has a b18c1 installed. will i need any modifications to make it fit from header back? and why are some exhaust more expensive than others. for instance flowmaster full header back system is around $250. Apexi worldsport2 is about $600 cat-back. other than the nice finish, is there enough of a difference to justify the price range?
any info about fitment will help, thanks.
gerard92692 is offline   Reply With Quote
Old 10-13-2013, 09:08 AM   #2
Default Re: just got a BARD EF hatch with GSR swap
not one suggestion?
Old 10-13-2013, 09:14 AM   #3
Freemananana's Avatar
Here's what you should do.
Get a header, eBay one if you are broke. Should be some second hand ones around here. Then go to a muffler shop, get 2.25 or 2.5 exhaust, crush bent should be fine since it's NA. Get your muffler of choice. Maybe buy a weld in universal CAT if you need one. I used my OEM one.
Should be $250 or so from head to the back of the car. I put a flowmaster, 2.25'' exhaust, stock cat on my car for $100 at the exhaust shop. Plus the cost of the muffler, $60 at the parts store. $100 for a cheap header, or more if you are actually wanting some 'engineered' goodness.
You won't find a bolt in for your car since it doesn't have the stock motor, at least not for a cheap price. You can find them custom made or some high end companies producing them.
Freemananana is offline   Reply With Quote
Old 10-13-2013, 10:31 PM   #4
GSR CRX's Avatar
the leaky exhaust that you have... is it OEM as well or custom fitted by a muffler shop? You should be able to purchase any bolt on exhaust if your using a type r or ls exhaust manifold. if you are using a GSR exhaust manifold then you would have to extend the exhaust piping approximately 4" because the GSR exhaust manifold is shorter than the 2.
GSR CRX is offline   Reply With Quote
Old 11-05-2013, 01:02 PM   #5
well i got it all dialed in finally....dealt with a dishonest shop, what a loser (just for a quick buck)...little does he know i have deep pockets and this car is my new hobby so he just lost a great customer that will be spending lots of money.
so anyways i drove down to Inline4 and picked up a DC sport Type-R 4-1 one piece header and blox test pipe and found a sweet clean condition Invidia exhaust off a great kid from craigslist, I installed everyhing so it fit well and no more exhaust issues.
now i have motor out of car and doing a rebuild with all OEM parts, oil pump, water pump, new oil pan, gaskets, even using honda bond....
next the tranny (92-93 GSR YS-1) will go to syncrotech for a rebuild using master carbon synchro kit, 4.7 or higher final drive and an Mfactory clutch type LSD
I CANNOT WAIT to hit the track and im having a blast learning all this... totally different than the world of road bikes thats for sure!!!
i will try to start a build thread
Old 06-18-2015, 10:18 AM   #6
So i decide to do a complete build and have been in the process for many months. finally got time to post some pics.
Old 06-18-2015, 10:28 AM   #7
Had a friend rebuild the motor.
Had Synchrotech build me a custom transmission with MFactory Clutch type 1.5way LSD, carbon fiber synchros, B16 short gears with LS 5th. 4.9 final drive, 9lbs flywheel and 6 puck sprung clutch (thanks to James @ Synchrotech)
Old 06-18-2015, 10:40 AM   #8
cafrog's Avatar
Cool swap. Post some pics and maybe a video. You'll be flying through the gears with that final drive. It will be quick.
cafrog is offline   Reply With Quote
Old 12-13-2015, 05:42 PM   #9
Welded roll cage and shaved engine bay and interior holes and unnecessary tabs.
Old 12-13-2015, 05:56 PM   #10
More pics
Old 12-13-2015, 05:58 PM   #11
More
Old 12-13-2015, 06:00 PM   #12
Wire wheel off old undercoating. Next wire wheel entire bottom of the car and spray new coating
Old 12-13-2015, 06:03 PM   #13
2 days of wire wheel work
Old 12-13-2015, 06:05 PM   #14
More wire wheel work
Old 12-13-2015, 06:07 PM   #15
Raptor liner
Old 12-13-2015, 06:08 PM   #16
Old 12-13-2015, 06:09 PM   #17
Finished
Old 12-13-2015, 06:11 PM   #18
Old 12-13-2015, 06:12 PM   #19
Old 12-13-2015, 06:13 PM   #20
Old 12-13-2015, 06:15 PM   #21
back end
Old 12-13-2015, 06:16 PM   #22
Shaved bay with paint
Old 12-13-2015, 06:17 PM   #23
Pics
Old 12-13-2015, 06:19 PM   #24
Old 12-13-2015, 06:20 PM   #25
Interior shaved and painted
Fitting 2.25 inch test pipe to 3 inch exhaust Another_Si_Guy Honda Civic / Del Sol (1992 - 2000) 11 12-07-2015 08:44 AM
EG hatch fitted exhaust system HERN39 Southern California (Sales) 2 11-25-2015 05:09 AM
gsr header fitment questions my96GSRteg Acura Integra 8 01-16-2012 04:01 AM
New Exhaust System Needed - '95 4DR EXCellR8 Honda Civic / Del Sol (1992 - 2000) 6 01-15-2012 01:15 PM
Si 90 EF HB Bosal Exhaust fitment?? Mrfeee1 Honda CRX / EF Civic (1988 - 1991) 2 02-01-2009 11:58 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
