FS::: zc trany & D16A8
i have a zc trany with jack shaft i was told it had a lsd diff. i have got to get rid of fast moving to Michigan in jan/2006. It has appox-45-50k miles on it, no grinds i will take $175.00 no less, I also have a d16a8 with a bad bottom end it can be rebuilt everything else is good on the motor head, dissy, intake man. I will take $100.00 for it(motor) The trany that i have WILL NOT fit a SOHC becuse the jack shaft has no place to bolt up on the block you must run 90-93 tag cv axles i also have a DX centerforce cluch disk with it.
please contact me a importslife200@yahoo.com OR (678) 637-8996/(678) 268-7523
Modified by importslife at 6:40 PM 12/5/2005
Re: FS::: zc trany & D16A8 (importslife)
The ZC Tranny can be used on certain SOHC, the half shaft bolt hole is present in earlier blocks, it just needs to be tapped to be used.
Re: FS::: zc trany & D16A8 (dr_latino999)
I did not know that. learn something new every day. So check your block to see if it has the proper holes if you are intrested.
jdmpnoy89
03-24-2007 08:49 AM
