View Full Version : Paint and Body
- can a 6th gen accord door fit on a 5th gen??
- Need help with removing bumper reinforcement!
- Quarter? panel repair
- Car covered in primer spray paint, what next?
- Having trouble with splash guard install
- Undercoating First Time
- 2023 Honda Pilot elite paint
- Honda HRV B Pillar Vinyl Tape Cleaning?
- Restoration Shops for del Sol rust
- DIY Window Sash Tape Advice
- Tailgate Electronic Strut Replacement - 2018 Honda CRV EX-L
- Swapping a Mirror Cover
- Is there a way to color match a center console? By dyeing it ?
- Turbo can....
- Richmond VA area shops?
- What brand paint should I be ordering..
- Door Seam Rust
- Underbody rust
- Paint Advice Needed
- DIY Carbon Fiber restoration video + photos
- Vapor barrier
- Does somebody know this wing?
- 2002 Honda Accord coupe door removal
- Paint Wrinkles on 2nd Coat
- Paint Tips
- ,2002 Honda Accord coupe fasters?
- Fix or replace rusted areas on 96 civic?
- 94 honda accord door moulding clip... part number?
- Does my plan to paint my 97' Integra look alright?
- Rust
- 99 EX, Painting fog light covers, front lip, sideskirts
- Top windshield trim removal?
- Best way to clean old, dirty door panels.
- Help with very old window tint removal
- How do I remove fender flares without damaging paint?
- Dustless blasting the CX
- Have you used a good high temperature paint?
- Seeking advice on rust repair: rust converter and paint selection
- HELP ! POLYURETHANE BUMPER FIX
- EF Chassis Interior Paints?
- Best undercoating for my lude
- Rattle can paint job W/ spraymaxx 2k clear
- LA Members: Body/Paint Shop Rec's?
- Newbie paint repair
- Front rail extension damage/repair
- 88 CRX si sunroof seal
- Recommended "Adhesive" (?) to Use for Trunk "Skin"
- Bent Strut Tower
- Interchangeable parts
- Wraps, DIY, Paint condition
- 2012 Paint chipping
- Aftermarket 99-00 style bumper for 96-95 civic?
- Can I repair this damage on my own?!
- 1992 Honda civic hatchback
- i know its a long shot but ill give it a try
- Need help removing bottom cover & high-mount brake light from spoiler (CR-V)
- Aztec green
- 2006 Civic Clear coat question
- 1993 Civic Si Paint Peeling Off Fender
- Overspray on windows
- Updated DIY Spoon Rep Power Mirror Visibility
- 96-98 rear vti lip question
- Replica R Lip
- How much to fix ??
- Anyone ever make a hood with the "angry eye" look?
- Repair advice
- How to remove mirror for Accord 2018 Sport
- Type r rear lip on rsx help
- Sideswiped!
- Sand and polish new paint
- Close Encounter With Road Sign – Best Way To Fix?
- Any ideas on going from messed up Black to White
- Filling Holes for Bay Re-Spray
- Paint Color Scheme ideas for my prelude?
- DIY Paint Question
- Been Busy
- Best Aftermarket Body Parts???
- Replacement OEM Spoiler Gasket
- 1995 civic coupe ex rear windshield??!!! Help!!
- Dc2 Red Recaros WYA
- OEM championship white paint
- ef9 roof for ed6
- Pits in carbon fiber
- Cut out rust and cover with Fender Flare?
- Dashboard gouges
- Refinishing Wheels but primer is coming off, any tips?
- Is my radiator support straight enough to pass salvage inspection?
- EK Quarter Panel
- Home made Wrinkle Finish Green paint first attempt
- EF Sedan Driver Door Won't Lock/Unlock
- General Body & Paint Questions
- Where do you buy your primer, base coat and clear?
- EM/EK R81 Engine bay paint color/code?
- EF Paintjobs Code and shade details ( Help Needed)
- Wanting to change different color on 92 eg
- Gasket between inner and outer panel?
- What trunk is this????Vis carbon trunk
- Side Mirror Fitment
- Keep original color? 1993 Integra GSR
- Cleaning underside of hood.
- 1988 Acura Integra LS Body Work Parts Questions
- Minimum Air Compressor Requirements
- Rust at bottom of rear window, help! 94 Integra
- jdm itr front end installation help!
- CF trunk lock cyl misalignment fix
- Rust between panels--what product do you suggest?
- Painting exterior of oil pan
- Correct Glue or Adhesive to Reattach Plastic Body Trim Sealant Strip
- Estimating Paint Amount
- Help! Quarter panel rust on 99 Coupe CA
- Honda Civic EX sedan 1994 exterior mirrors
- EG, EF, And FK8 windshield
- Using primer as a base coat on my car?
- spot priming engine bay this weekend need advice
- What all do I need for small paint jobs?
- Rust Proofing
- Plasti-Dip a small strip
- Small front side window
- Cutting Body Panel Near Gas Door - Advice?
- 94-01 Integra 4dr and 2dr roof interchangable?
- 2016 Honda Accord interior paint trim
- Flocking my interior
- Stripping paint from plastic center caps
- Valve Cover Repaint
- Best finishing sand paper grit
- Trunk Rust 99 Civic
- Using Osphos on eg civ engine bay
- 96 integra j racing cf hood?
- 94-2000 Acura integra type r side skirts ?
- EG quarter panel suggestions (rust)
- Quarter Panel replacement - Adhesive question
- urethane sealer
- Frank's Custom Fiberglass EG rear hatch
- Rusted floorboards? Help
- Simple question about paint color match
- Temporary Rust Inhibitor?
- How much paint needed and how to do it
- 96 integra c west side skirts
- Need help identifying a carbon fiber hood
- Window Run Problems (need to know what part this other thing is)
- EG Hatchback Windshield Seals and Molding
- Modifying a 96integra 4dr mugen style sideskirts to fit a 2dr
- Modifying 96integra 4dr mugen sideskirts to fit a 2dr
- What does Honda say about their cars paint delaminating?
- Ccc side skirts ?
- Where to order high quality paint online?
- 1991 civic sedan -Where to get rear windshield and roof channels trims and seals
- Resin repair on genuine spoon spoiler
- first time painter help
- What color is this ????
- 96-00 EK Civic Rear inner fender panels?
- Plans for underbody: thoughts?
- Eg civic carpet tucking
- Rustoleum paint job on engine bay !
- Bumper question for EG
- Vynal spray help and questions
- Paint Old Gas Tank or Replace
- Bent core support
- Best Method for Restoring Factory Hardware
- Battle of the Bulge!
- A little bit of cancer
- Painting my ej6 camo green
- Paint mudflaps?
- Restore / re-do blacked out chrome trim
- My spray can failed mid-paint job! :( What to do?
- 1996 Civic Front End
- [Cost Question] How much did you pay for your exterior respray?
- Paint system for a beginner
- Looking for online or local - gallon of R81
- Can anyone I.D. these skirts?
- I just had a quick question... well quick for me to ask
- '01 Prelude-My photoshop skills and fun ideas
- complete quarter panel removal? confused...
- OEM suspension coating
- Possibility of an Acura bading fitting on a front mugen bumper
- Is this bad?
- Rattle Can paint job
- Surface Rust on Underside
- Dried up sticky substance, HELP to take it off?!
- Top secret gold/ knockoff color +opinions
- 2009 Honda Accord EX-L coupe-
- Replacing only lower radiator support
- SOMEONE PLEASE HELP ME!!
- 1990 Ef civic door trim clip
- Will a 95 civic hood fit a 94 del sol?
- 1992 Accord - Body Filler?
- window visors, sunroof visor
- Core radiator support replacement
- Painting question and opinions on what to do with this old girl!
- Worst gaps!
- body seam leak at very rear corner 1991 Honda options?
- Trunk lip / deck is this seam sealer 1991 Honda?
- OEM seams welded or glued 1991 Honda?
- body repair help with fiberglass / welding / identify structural parts, and options
- Finished S2000 hardtop project.
- 1996-2000 CIVIC SIDESKIRTS
- 17" Rims Restore Project, help requested!
- Honda Engine Paint Color
- Questions about re-sprays/paint touch ups
- Best way to repair this damage?
- Bumper body work estimates
- Dent on Driver Panel
- Radiator support
- OEM Undercoat
- H2b before and after.. just the beginning tell me what you think
- paintless dent removal tools which ones?
- 92 Body Issues
- What brand of paint is used on he Honda Ridgeline?
- Help with finding interchangeable body kit parts for 2003 accord coupe.
- Rear Windshield Replacement Q?
- How do you repair the EP3 rear panel?
- Front end repair
- EP3 HFP body kit removal
- Quarter Panel Support
- I got rear-ended, what is your best advice?
- Crystal black Pearl blending/matching
- Interior Color - Color Name or Paint Code?
- How to ID my paint color
- Need help doing some body work repair
- 2012 Odyssey Service Estimate
- Options for a body repair?
- Is there an actual difference between this paint, honestly??
- Should I clear coat my stripped interior?
- What's advised to use to fix this sideskirt crack?
- Approximate cost
- Scuffed Paint
- how do i fix and restore faded & oxidised roof
- Guesstimate on how much to completely re-paint 90 EF Hatch
- Full Interior Detail on the Civic Hatch
- OEM FA5 Trunk 'Si' Emblem - Where to Buy???
- Honda Civic 2014
- Repairing Clearcoat in your garage for under $30.00...I'm trying it. (Video inside)
- Rust on rear quarter panel of 2013 Crosstour
- Get touch-up paint off 2010 Crosstour
- valve cover paint
- Plug under driver's side carpet
- Rust on a 95 Civic
- Factory Primer
- Can this be repaired? 1999 Integra
- Need some help from the body guys... PLEASE
- need some advice on first time body work
- 88-91 civic sedan 6 piece door belt-line trim
- Are body panels the same between Japan/US/Great Britain?
- paint code NH658-P, is it 2 stage paint
- Are my headlight lenses repairable?
- Is this a dealer quality quarter panel replacement!?
- How to remove white spots (I think paint???) from my Accord 2013?
- Help! Are 2014/15 civic side mirrors interchangeable between coupe and sedan?
- what tape does dealership use for vizors and lip kits?
