- Wall Mounting My Wheel Collection (vid)
- Snow tire long tear
- which spare tire will fit in the 2024 Integra Type S?
- 215/45/17 on DA (1991) integra?
- SSR custom wheel rebuilt shop in so cal oc area
- Looking to get my SSR mesh wheels rebuilt in socal
- TPMS bypass
- Not allowing select to reset tpms setting
- Need help with wheel fitment on 1994 Honda Civic Ex 2D Coupe
- refinishing polished wheels question.
- What tire size should I get ?
- Do I need a new tire?
- 2003 CRV tire pressure 26 psi ?!
- Help with steel tire lug nuts (PICS)
- SSR Schumacher Wheels
- 15x7 Flush fitment and good performance need help
- Need Advice On 2002 CR-V Wheel Cross-Reference
- 95 civic tire question
- 06 Accord - Left Front Blowout
- Work Equip 03 (O Disk) option
- Alignment of Rear Wheel
- Hankook Tire for drag racing...
- Are 3rd generation Acura Integra alloy wheels compatibile with second generation?
- Questions about changing rim sizes
- Need help identifying these OEM rims
- Tire Dilemna!
- Wheel Fitment for LX
- What rims are these?
- What Hondas will these wheels fit?
- Best Fitment for a TE37 OG for an EM1
- Rays wheels??
- URGENT - EPB stuck on rotor!
- Are these wheels real?
- ek hatch 16x8 +35 wheels and tires fitment!
- Tom's Racing Dish, custom machined to fit Honda, in depth restoration
- Meister CR01 - Offset/Disk Confirmation Before Ordering
- Desmond Regamaster - refinish to spoon style advice please!!!
- Smaller Size For Winter
- Swap 215/45R17 tires with 215/55R17
- Which Enkei PF01 18" for an I4M6 2015 Honda Accord?
- Advans
- Puncture right on the edge of sidewall
- Mystery wheels, stamped rota on rear
- 15x8 +32 on '00 Civic
- Replace one, two or all four tires?
- patched tire from nail puncture
- Help with imitation two piece wheel 'bolts'
- Lost lug nut key
- Nankang AR-1 and CR-1
- Rims slightly damaged. Causes steering wheel to shimmy highway speeds. Safe?
- Wide body N wheels fitment
- Offset for 15x7 rpf1 on 98 ex coupe
- Putting c4 rims on 2003 accord coupe
- OEM Civic EG wheel info
- Corrosion or Not?
- New Wheels
- Can anyone help me find what those wheels are?
- Part of tire won't reseat on the bead or something?
- Trying to identify wheel size
- Work wheel identification
- How will upsizing wheels affect a bone-stock Accord?
- Best sidewall size for 15in
- Rims for EG hatch
- Low or stock offset on wider wheels?
- Wheel Identification
- Need help with wheel size and offset on my EK sedan
- ET offset for standard wheels
- Help Identifying wheel manufacturer
- Wheel size help?
- 16x8 tires on civic
- Falken Azenis RT615k+ 415/45 R16 Discontinued
- Wheel identification help (Rays?)
- Question about center bore sizing 2001 Civic
- Rear tires?
- Opinions on Gram Lights compared to other brands.
- Upsizing stock rims to custom rims
- Tyres rubbing fender shields when turning left/right
- Anyone know name of this RIMs set?
- Help with wheel sizing - eg Hatch
- Real TE37 wheels?
- Help with tire size for 15x8
- Tire size vs compound
- What tires are you running?
- would these wheels fit my 1993 honda civic hatchback dx?
- Wheel and Tire combo for STS Civic?
- Anyone using TR Motorsport C1's?
- How rare are these rims/wheels?
- Need help with wheel and tire fitment
- Need help confirming if my Desmond Regamaster Marquis Promadas are real :(
- New wheels to fit over wilwoods
- Tire Size Recommendation For S9A 665A Rims?
- Need advice on wheels and tires
- Offset for 15x9 wheels with 245/40r15 no rubbing
- EK hatch wheel set up suggestion
- I bought aftermarket wheels
- Rusty Steel Wheels
- tire size help
- tires
- Need help identifying wheels
- SSR collars bolt size?
- When Enkei wheels are these? Can't find them anywhere!
- What wheels are these
- Garcia tune speed choppy rings?
- ITR wheels on CD accord
- Can't find any 235 tires in a 15 or 16
- Steering Problem
- Best/cheapest place to buy new Rotas in the US?
- 205 70 15 on stock 03 Civic?
- RSX wheel fitment
- Wheel spacer suggestion needed
- What Are These ????
- Will a 13x7 with 3 1/2 inch backspace fit. No camber
- Factory Wheel Finish
- What tires fit best on 15x6.5 wheels, for a 1997 Honda Civic?
- Track. Street. Mountain 00 Civic Dx Hatch
- No torque wrench!
- Summer tire change questions
- Ignorant and in search of information
- High positive offset a problem?
- Cracking and peeling clear coat fix
- Work wheels identification
- 94 Civic Hatch Wheel/Tire Fitment
- Wedssport question?
- fitment
- ? About semi slicks
- Wheel/Tire Identification
- Lightweight Wheels
- Need help identifying oem wheels
- Need help!Legit or fake te37?
- TIRE COMPOUND: Driving manual transmission up steep hill and breaking loose tires
- Falken ZiexRE950s
- what wheel manufacture is this?
- 14" wheels with Honda centrecaps ... but from which car?
- Help me find my missing hubcaps
- Wheels Fitment
- Work valve stems for RSZ-r's
- Any Idea What Wheel This Is?
- Centercap size for rota slipstreams???
- What do you think these are worth ?
- 1999 Honda Civic Si EM1 Rims Lug Nut Question
- Aftermarket Wheels For 1990 Civic DX Hatchback
- SCCA / Road racing tire setups for DC2
- 225-45-15 tires on 15x8 +40 DC2 fitment
- Help I need to know what model wheel is ??
- Looking for valve stems for Mugen MR5.
- Wheel to caliper clearance issue.
- What, IYHO is the "Best" street/summer tire combination?
- Offset for 94 Del Sol wheels
- 15x6.5 +35 vs 15x7 +45 (4x100) regamaster question
- Air leaking at clip-on wheel weight: can I replace with adhesive weight at home?
- Pic request - Rota Hunter wheels - Black
- CE28 real or fake?
- 2nd set of wheels/tires 2016 EX-T
- Going to a 185/75/14?
- Wheel exchange, clearance, scrub radius
- Should I just go to steel rims?
- Bronze TE37 discoloration help
- Satin/brushed polishing
- Wheel Help Please
- Poor Man's Slicks
- What brand logo is this?
- Is this Fixable??
- Name these wheels!
- Name that wheel!
- Want a 275/35r15 Street tire
- Opinions on street tires for big turbo
- Discontinued 225/40r17
- Safe to Drive With Hub Adapters
- 215/70R16 TIRES
- Recommend me a tire size 16x8+38
- Enkei J-speed 3's
- Honda Access wheels
- Need help identifying these rims.
- Mugen Wheels on ebay
- Can anyone identify these rims
- So.. I get the feeling there are few options on tires now?
- 15x9 +35 et turbo integra street setup advice
- Widest wheels for EF civic
- 18" Civic wheels on 2006 Accord Cpe V6 6M
- 13" Alloy Wheels- what are they from?
- Storing Track Wheels
- Eg hatch wheels?
- Where to buy Rota Rims Online
- Are center caps necessary?
- 225/50/15 fitment
- will 16x8 et23 fit on a 90-93 integra?
- 215/45/r17
- 14" rims
- Does anyone change wheels in winter?
- What size tire to put on 15x8 +25 rim?
- What size tire on 15x8 +25 rim?
- Oem 14” wheel
- Tire size help?
- Please help!!!!!
- Fixing slight curb rash ?
- Wheel size for EJ1 B16 build
- What wheels are you running?
- Are “polished” Rota slipstreams actually polished or machined/clear?
- Brand and name of this wheel ?
- 1988 Civic wheels....thoughts on value??
- What size and fitment for 1997 JDM DC2
- 16x9+25 EG Sedan fitment?
- Wheel size with 3pc front end
- Help identifying wheels
- Help Identifying this rim
- Can’t find wheels for a CD7. A.m I stupid?
- Real TE37's?
- Help Identifying Aftermarket Wheels
- Figuring out my offset
- Honda oem wheels. what model are they from?
- Are these tires really from 2007!
- Info on old Honda wheels
- Could really use some help here
- 1994 GSR 195/55/15 FAT FIVE
- Help Identify Stock OEM Rims
- Aftermarket wheel/tire size for 05 Civic
- Lug Nuts - Different for Steel vs Alloy Wheels?
- Best Tires?
- 225/45-15 tire options for street
- 15x8 205 clearance on a stock 94 EG Civic VX on stock alignment
- what is the socket size needed for honda pilot wheel lug nuts
- (# civic wheel swap
- 2002 Honda Civic Si wheel questions
- Restoring a barn find 97 civc
- 96-97 spec ITR wheels on civics
- weds sport TC-05 17x9 weight ?
- ES1--16" Wheel Question
- Tire rubbing issue
- EK Wheel Fitment
- 4x100 Advan center caps?
- Question about some Advans and bolt pattern.
- All terrain or Snow Tires/Blizzard Civic
- Wheel fitment.
- 15x7 extreme summer tires
- 16x8 with +35 and 205 tires?
- 205/50/15 All season high performance tire choices
- Rim question
- 16s and 14s
- Need Help Identifying Rims. 1994 Accord LX / 1991 Acura Integra
- Best street tires for gsr blades
- Enkei RPF1 offset, are these 41mm or 35mm?
- 92 Wheels
- Anyone know what kind of wheel this is?
- Why does my tire sound like this
- Tire size
- TSW wheel?
- how close can i gt to wheel's load limit?
- rotational mass (barrel weight)
