View Full Version : Hybrid / Engine Swaps
- RA1 Odyssey H22A swap HELP!
- Where is the f20,f22 threads?
- It’s been a while. Honda powered sand rail with bug body
- Mini me swap wiring
- 2000 Ek B Swap throwing p1337 and p1298
- B20B bottom end noise.
- 2009 Ridgeline into 2003 Pilot
- integra engine swap (from b18 to d16)
- Looking for quality aftermarket replacement for B18C engine mount bolts and nuts
- F22a6 long block, f22a1 intake.
- Civic swap
- K24 Return line with OEM Parts?
- B20vtec GSR head high idle
- B18c swap questions
- Going B20 to B16 Q
- Overheating issues, b18b1 swapped '94 civic
- Need help k swapping 94 accord
- What year is this engine?
- Need some info
- B18c rear engine mount bolts
- Pump no prime
- Rough Idle/ Misfire B20z Into EJ6 Hatch
- mini me swap in ef questions
- What swap is worth it for a track build in 2023?
- What ecu to use for d16y7/8 mini me
- B18c1 into EF - Fuel Issue? (cranks but won't start)
- 01 accord with a 96 h22a swap used stock harness and ecu what do I need to make it ru
- B18B1
- Swapping from 95 d15b3 engine to 86 zc1 twin carb
- 2000 Civic EK9 Coupe K24 Auto Swap
- H2B Questions Eg Civic
- 2006 CRV- Can I swap a K24a8 in?
- Ef civic si hatchback swapped b18b1 ****need*****info*****helllppppp
- firing on 2 cylinders
- H22a4 ek civic need help BAD
- D14z2 to d16zc sohc non vtec swap
- 1998 Civic Dx mini-me swap?
- Auto shops in Chicago that do engine swaps?
- H2B eg coupe issues
- O2 sensor diagram - B16A
- B18 direct swap
- 99 Honda Accord EX with F23A1 Vtec redline at 5000
- Hondata Kpro V4 On Line Ignition Off
- Boosted B18A1/B16 LS/VTEC HELP!
- Crx clutch cable threaded all the way down
- 96 Accord F22B1 JDM Swap Wiring Confusion
- EJ1. K20A or B18C swap?
- What ecu and ewh should i use?
- Will 10-pin B18b distributor swap onto later 99+ JDM B20 engine?
- Is stage 4 bad for basic bolt ons b18c1 or b20z no vtec
- Where To Buy Flywheel Bolts?
- B20b swapped ‘94 del Sol
- 97 Accord JDM f22b swapped headache
- Will Skunk2 stage 2 tuner camshafts work with stock pistons on a ls/vtech setup?
- Need help with my lsv
- 98 JDM b18c r into 2000 LS HELP
- D16 civic swap
- Help me pull a b18a1
- D16 swap problems
- Ek k swap fuel rail
- cb7 f20b loss of power/ misfire NO CEL
- K swap prelude
- h22 trans
- h22 4p alt to 3p harness
- B16 engine swap into ek2
- P72 intake manifold vacuum ports
- Beating a dead horse y7 w/y8 intake manifold IACV question
- B16 In a ek evap system.
- EURO R SWAP CD5 ACCORD
- B18c1 vs d16y8 build cost?
- EK3 ENGINE SWAP NON VTEC D15B TO VTEC D15B
- 3 out of 4 Misfires
- OBD0 to OBD1 questions
- Parts compatibility
- J35Y6 Block Questions
- 95 accord h swap
- GSR swap stalls as soon as I plug the MAP sensor in.
- Are there any BAR'd k20 or k24 EK Civics?
- B20 swap need help
- H22 rocker in B16a head
- B20v oil leak pressurized
- CD5 F20B HELP
- Gsr Valve Springs on exhaust side of b16
- b18c swap stalling when warmed up , help !
- JDM F18B Swap
- J30A4 into 89 Civic DX
- Ek bseries swap question
- F22a1 EK Swap-Wiring Harness Help
- ITR Swap issues in 00’ Civic Please help..
- Is my D15B manual transmission compatible with an F20B single cam?
- HELP!!...D15B 3 stage coolant and vaccum hoses
- 95' Prelude Si Build Guidance
- Feedback on B18C1 swap.
- b16b swap in em1
- Advice for 01 Civic Sedan K Swap hopeful! (My first all out build)
- Bracket identification on b series tranny
- JDM B20z with LS ecu
- I need help
- y8/y7 in EG?
- 1978 Civic Wagon CTR +Jackson build
- B20VTEC PTV Clearance and Pistons
- 2004 Pilot J35A4 Wiring Help Needed
- Removing belt from balance shaft h22.
- D16Y8 into a 2000 lx
- F22A to F22b1 swap- Fuel rail question
- b18b1 into 99 civic cx hatch
- Spark, fuel and timing but it doesnt start...
- A little insight
- K24 '95eg swap overheating
- JDM D16A swap - lots of questions
- B20b into 96 ek. NEED HELP!!
- es9 civic swap help
- engine swap 2020 civic to 1992 accord
- H2B Knocking??? Help please
- b18 swap from b20
- 95 accord h/b swap??
- B Series swap alternator replacement
- b20b swapped 98 civic mounts help
- HELP!! Will a 4wd transmission work in my 2wd civic. And stay 2wd??
- 2011 LX Engine Swap
- B series intermittent cutting out
- b20vtec da9 help
- Start laughing now if you wish
- I have a 98 civic (EJ8) B20b swapped from a 97 CRV problem;(
- B18B1 Swap
- EG K24 swap
- Manual to Automatic
- Stumped on Lsvtec oil pressure
- H22A swap into 96 Accord wagon OBD1
- ABS Light on after B18c Swap, EG hatch
- ZC to B20B VTEC Help Wanted
- H22A Swapped 94-97 Accord Questions
- Swap help
- Need help with wiring harness ls/vtec and transmission mount problems.
- G23 Turbo
- 97 hx d16y5 to a 00 ex y8
- K24 Swap CD5 Accord Questions
- Intermediate shaft
- K swap on an automatic EK that’s been manual swapped
- J35a6 and j32a3 autos, what to do?
- Ek hatch b20 exhaust???
- 96-00ex full b16b1 engine and trans swap
- Budget kswap harness for 97 civic
- Lsvtec runs for a second before dying
- OBD2B to OBD2A repin help
- OBD0 - OBD1 Jumper Harness Concerns in EF
- Plz help electrical question
- Mini-me a D15Z6 or D14A4/Z2?
- B20 Vtec Swap into an EK1
- Power Steering on LSVtec
- Mini me/ obd0 to obd2
- Newbie at work: B18B1 swap into a ‘99 civic ex- what does it take to swap?
- 96 prelude f22 into a 2000 prelude shell
- LSVTEC Ecu
- Turbo d16y8 or swap to b16
- What type of radiator for J32a swap in civic
- 2000 ek h22a swap engine harness questions?
- K swap question
- SWAP HELP
- Turbo d16y8 or swap to b series
- J swap intermediate axle
- B20 swap
- D16z6 into a 2000 Civic ex
- K swap steering coupler problem
- Exhaust mounting problem with B20 EK hatch
- B18A1 swap into EK
- J swap crank no start
- B20 swap help.
- B18b swap ek hatch - no spark
- B20B Swap into Del Sol
- 93 EG with 98 B18b1 swap tps issues
- ECU issues
- Z6 head, y8 intake and z6 throttle body need help with a hose
- H22 EK Mounts
- F23a swap in 98 accord ULEV
- 1998 B20b swap civic start then stalls
- B18C into 2000 Civic DX
- D15B7 to D15Z8 swap
- H2B Swap
- Vibrations and or rubbing after B series swap at 30 mph+
- D15b with P28 head
- F20B iab operation with jdm pcb ecu.
- K24 Acura TSX engine going into 2006 Honda civic 1.8L
- Code P1381
- B18c1 or b20b, Which is better for turbo applications?
- Need guidance on the f23a7 swap in 91 accord. How's it done?
- 00 civic ex coupe with F23A swap a/c install questions
- EG Jdm b18c thermostat housing coolant line location?
- EG swap JDM h22a 98 obo2 to obo1 problems etc
- Front axles civic or integra ??
- Wiring 99 EK Si Engine into DX Hatch
- 98 Civic and Type R
- B20b budget build recommendations for my Honda Civic Del Sol!
- Motor swap for 00 Honda accord.
- d15z7 (3-stage VTEC) into 91 honda civic hatchback (d15b2)
- B20b with gsr head overheating when sitting at idle with A/C on
- CIVIC EG SWAP HELP
- B16B into 97 DX - question on a couple sensors
- d16y7 to d16y2
- Can you use an AWD transmission for a FWD build?
- beginner k24a engine swap
- Turbo G23
- h2b crank pulley options
- Integra with a NSX motor FWD
- Ckf bypass issues
- F22b1 with h22a head but im stuck i need some advice.
- f23a1 swap in 2000 civic problems
- Honda and Acura
- Help need guidance
- 98 Civic Coupe H22A Engine Swap
- fuel injectors
- K24 ecu choice
- Engine Swap
- 93 Del sol with f20b low compression Cylinder 4
- Need help my 95 eg coupe wont crank or start its a b18b1 swap
- cv axle help
- D15B7 Head on D16Y5 Block (93 Civic DX)
- B18/16b1 Non-Vtec Turbo. An F1 tribute
- 1991 Civic Si to B series
- B18 to B20 96 Civic EX
- D16Z6 Swap - What is Compatible Alternative
- B20 swap
- B20 96 civic swap, o2 help
- Nseries engine in hatch
- Fuel injectors not firing, but have power.
- Help what is this 99 civic/ b20vtec
- D16A1 swap into '87 CRX
- LS/vtec
- 1987 D15A2 swap
- 2017 Civic si engine swap Into 2000 Civic
- Need help
- 2 issues. B20b nonvtec engine harness and wiring
- D13 to d15b non vtec
- Need help fast
- Vtec Bypass Trouble
- 99 B18C1 Swap Into 99 EK *BARD* Help
- 93 civic coupe gsr swap vtec trouble
- D16a6/z6 timing belt question
- Gsr swapping my sedan, First time swapping!! Advice?
- B16A 1st gen block swap
- Budget Build thread: V6 powered J-series 98 Acura EL sedan
- 93 Delsol B16b motor GSR tranny... axles, half shaft help??
- DelSol B16b with GSR tranny... axles? Halfshaft?
- Potential buy on a f20b teg, help!
- D15b/z6 question with misfire
- Honda B20 - 97 Civic - Vtec issue
- I am buy parts for k swaping my ek hatch and i need help.
- Please help... Question on ICM wiring
- Jdm D15b/Z6 head swap questions, need help!
- Which sparkplugs should I be using when swapping an engine
