- Interior Door Handle Fix?
- 2019 Civic Coupe Sport Upgrade Discussion
- FL5 Fuel Filling Problems
- FL5 coilovers and EDC questions
- Is a build thread still a thing?
- Scan tool
- Need help with a parasitic draw - 2020 Civic Sport Coupe
- 2024 Civic Si
- 2022 Civic Service Manual
- Potential Mould on windows
- 2017 Civic Sport - P0301, P0304, P0300
- Windshield wipers wont shut off
- Not working, Windows, door locks, sunroof trunk release passenger side mirror. Need h
- HELP! 2017 Honda Civic ECM Female Connector diagram
- Transmission Issue 2018 Honda Civic EX 1.5T
- Oil leak on a 2016 Honda civic lx 2.0l engine
- Projection of Hybid Civic
- Which Year is most reliable 2019-2021
- 2018 Civic EX-T touchscreen issue
- Rear alignment problems 2018 Civic ?
- What's the best defense against CAN-bus injection theft?
- 2020 Honda Civic
- P2647
- Civic 1.0L Small oil leak, what is this plug?
- 2016 civic touring blinker stays solid
- My car committed suicide
- 2023 Honda Civic Type R FL5
- Exhaust for 2020 Civic Sport 2.0
- 2017 Honda Civic Touring Radio Broken
- Electric parking brake replacement
- Fuel Pressure Drop - Only during WOT
- Suggestions on upgrading electrical for audio system upgrade
- Bumper swap !
- CR-Z HPD BBK on Civic
- Just bought a 2017 civic lx auto - will a type r front bumper fit ?
- cargo measurements, 10th gen hatchback
- HELP: my engine is knocking what should I do?
- Honda Civic 20137 EXL sensing Rear view mirror replacement
- Do the same rules apply yo the L series as the D series?
- Why is it so hard for Honda to figure out the warranty?
- I found a defect in the 2022 Civic
- Windshield replacement
- Leaking Brake Master Cylinder
- 2016 Civic - Replacing trunk switch to put down back seat
- What - no cargo board
- Is Dealer Right? Rear Shock Flange Bolt Missing, Sent To Body Shop For Welding
- remote stopped working
- New Civic FE1- Shakes When Braking
- Hole exposed under trans fill cap.
- Type R Trailer Hitch
- Accelerating problems
- 2023 Hatchback & Sedan windows the same?
- Transmission issue
- 2019 type r heating up
- 2021 Civic question about changing the stereo
- 2016 HONDA CIVIC TOURING... HELP!! I can't get these lights off of my dashboard.
- 2023 Honda Civic Sport - Dashboard issue
- Ultimate 9 throttle controller installed! 2.0L ivtec
- Estimate to repairs this damage 2016 civic
- Help with AC/HEat system
- Instrument Panel Warnings After Seat Removal for Amp Install
- Diesel filter location on Honda Civic 1.6 Dtec 2019
- What is this hole ?
- Stinky CVT fluid
- 2022 Civic Sport heated side mirror
- 2018 Civic EX passenger mirror replacement
- Key FOB won't pair with engine
- Driver door lock replacement
- lane assist camera question.
- Civic doors interchangeable?
- Seat heater not working
- Electrical Error - Honda Civic 2018 1L CVT
- Aftermarket power steering assembly? I'm confused
- torc Specs for front and rear suspension
- I'm at a loss here and could really use some help to figure this out.
- Civic FK7 Japan - Remote Start Disabled in ECU
- Help With Unknown Issue with Motor (possible head gasket?)
- 2017 Civic Sedan LX
- FALSE Pre-Certified Civic
- 1.5l 180hp -vs- 2.0l 158hp
- 2020 Civic Upholstery Fasteners
- AC eye irritation
- A/C Issue
- Which is the gasoline feeding hose ?
- Torque Specs for 2016 Ball Joint to Control Arm Nuts?
- water in rear psngr door
- Fluctuation rpm when ascending in slow speeds
- 2016 Civic Shifter Knob replacement issue.
- 2022 Honda Civic Sport - Initial complaints
- 2019 Civic Sport- Locked out due to dead battery
- Suggestions for smoother ride?
- Creaking noise after eibach sportline install
- Civic TypeR fk2 - check engine light
- Weird noise reversing up my driveway (10th gen Si sedan)
- OEM radio compatibility?
- 2020 civic sport 8k miles-radiator
- Special Tool for 5mm sub-frame bolt?
- P0717
- i-VTEC emblem
- Engine Bay Rubber Part
- Access to Honda's Interactive Network
- Maintenance Minders or Miles? 2017 Si
- Where can I find this wing? 2020 Civic LX
- Key Fob Issues After Car Battery Replacement
- Intermittent misfire p0303 blown gasket??
- Dashboard warning
- Honda Civic 2018 Problem
- Help Identifying Springs 2020 SI
- Crank/Pulley Bolt
- Civic 2018 (32000km) - Vibration coming from the cabin/passenger side
- 2022 Honda Civic Sport - AC mesh question
- 2022 Civic fuel injection question
- 2019 civic si speaker wires
- 2022 Civic Sport
- 2018 LX Wiring Diagram?
- k20a3 head swap
- 2016 Civic EX-T Alternator issue/replace?
- Clanking sound on acceleration from a stop & over speed bumps
- Civic 2017 AC "sucking" sound and warranty
- Loud tick tick tick sound in engine bay - Honda Civic 2016 LX
- 2017 starting issues
- cant get the brake piston to retract
- 2018 2.0 LX intake resonator removal
- 2019 Honda Civic Clicking Noise When I Released Brake Pedal When Car is on Park
- Side camera mirror
- All Warnings lights on
- 2016 Honda Civic is difficult to turn over. Battery dying??
- My 2016 Honda Civic Touring is all of a sudden chipping paint in one area..
- Honda civic 1.5T touring 2016 A/C problem
- Your experience with the 1.5T engine
- Any idea of where i should take my 17 civic to have the rear main seal changed ?
- 2021 Honda Civic hatchback sport
- Trunk liner
- 11th gen forum needed
- Key Fob Stopped Working After Battery Replacement
- Air Intake
- Tire pressure sensor ?
- Alarm help: 2018 Civic Lx / Viper 350 PLUS 3105V
- 11th generation honda civuc touring sedan
- Starter issues on 2018 Civic LX *Update* SOLVED- replacement starter
- Transmission gears
- 2021 rearview mirror wiring
- Can 2016-2021 civic type r front bumpers fit on civic coupes 2016-2021?
- 10th Gen Intake Air Temperatures. What's your take on lowering them?
- What Oil for 2020 Civic Si?
- engine knock occasionally on acceleratio.
- 2018 Honda Civic SI WONT TURN LEFT
- using the horn for a lock alarm?
- FK8 CAMBER DIFFERENCE HELP!
- Quick video of replacing foglight and changing to LED Bulbs
- ISSUE : 2017 Honda Civic Hatchback. Sport Brake System
- Failed Inspection OBD Issue?
- Quick install video of converting Honda Civic Ex Grille to the Black Civic Sport
- Any Tips / Tricks on "Launching" the 2017+ Civic SI in 1st gear?
- Troubleshooting:Car idles rough only when in gear & A/C blower is off.
- I want to get an exhaust for my 2019 civic sport sedan
- 2016 Honda Civic Input Shaft Speed Sensor Location
- 2020 Civic ES: How do you set the Door Mirrors to retract?
- Is it possible to put a Space saver (spare tyre) in a 2020 Civic?
- Windshield Wipers not working correctly
- Problem with 2017 EX-L radio unlocking
- No wheel bearings?? 2020 Civic Sedan EX
- 2016 Civic “internal short”
- 2017 Si. Engine temp in the cold...
- Honda Civic 2017 not able to shift out of park
- Apple CarPlay colors are off on radio
- 2017 Civic EX-L - CAT Part Question - replace failed 18150-5AA-L00 with 18150-5AA-A00
- Good after market horn for 2018 Civic LX
- Add-in Inverter Pack
- Windshield wipers
- 2016 Civic alarm randomly goes off
- Noise “whine” in cabin issue
- 2019 Honda Civic electrical issue, dashboard turns on after shutting off vehicle
- Looking to Buy 2020/2021/10th Gen Civic - Known Major Issues?
- BMS High Performance Intercooler!
- Power mirror actuator rod/motor fix
- Hit a deer now car won’t start!
- 2017 Honda Civic si electrical issue,no crank,no communicate w/obd2
- JB4 for Honda Civic FAQ
- 2016 LX starting problem, no codes, no clue
- Fob and trunk button
- [Help] 2017 Honda Civic LX backup camera
- Civic 2016 - P0706 Error code
- 2019 Civic melted break light..help!!
- Broken sensor connector
- 2016 Civic EX Warning Lights All Coming On
- 2018 civic ex rear driver door wont lock/unlock with fob
- Issue? Engine cooling fan running all the time
- 2020 Type R-is there a way to display boost AND throttle % at the same time?
- 2018 Civic Hatchback Sport - Does anyone have a diagram of the PCM connectors?
- Civic EX 1.5L Turbo issues after installation of cold air intake
- Mishimoto air filter has intermittent "ticking". Told this was normal. True?
- How to Permanently Disable Your Seatbelt Warning Noise & What It Removes
- A/C Parts Nationwide Backorder?
- **Help**with A/c condenser
- Any issues with the OEM Radio Crashing?
- So how much miles before 0% oil life for a 2L in general ?
- Tire Pressure Winter & Summer
- Performance tips- 2017 Honda Civic Hatchback Ex-L.
- MAF Plug Replacement
- Right Rear Bumper Side Garnish part availability
- Honda Civic 10th(FC) Wheels Upgrades. Install 15mm+20mm Wheel Spacers
- Thermostat not opening L15B7 engine
- Assistance needed: 2018-2019 Civic OEM Fog light purchase and installation tips.
- Aftermarket exhaust options '20 Civic Sport. What companies are out there?
- Flywheel torque L15B7 engine
- Cabin harness wire schematic
- (2017 Civic EX-T) Does anyone know how to turn this lock feedback off?
- RF Signal Theft Prevention: 2016 Civic and the use of "Faraday"-styled items
- Fuse Issue
- Muffler options for the 2020 Honda Civic sport under $200?
- 2019 Civic Fog light Recommendations - (Yellow 3000k preferred)
- 2017 Honda Civic coupe EX-L 12v socket outlet doesn’t work
- Open the hatch from inside the car?
- OEM vs off brand air filter???
- 2016 civic ACG Fuse Blown and Car won’t star, Help Please
- Looking for tire input
- Civic warranty scope coverage (secondhand car)
- 10th gen si turndown pipe - Is it dangerous for the engine to use?
- 2020 6spd transmission Civic issues: I don't believe it's me. Other possibilities?
- Steering wheel shakes a bit after tire rotation
- 2016 Honda Civic Ex-L not starting
- Honda civic catalytic converter
- rear view visability on civic
- question on oil issues and new type oil avail 5/20 qf6b qf6a
- 2020 Civic EX using OEM halogen bulbs. Can I switch to LED or HID without damage?
- 2" Trailer Hitch for 10th Gen Civic Hatchback 1.5L
- 2020 Civic Hatchback - Which Fuse for rear running lights
- Trouble with the CVT?
- 2019 Honda Civic 5 door engine serial #
- Windows ROLL DOWN because of key fob
- Under engine cover/shield clip/screw part number
- 2017 Honda Civic Ex-T Upgrades?
- 2019 civic LX Intemittent wiper settings. Are they really "intermittent?"
- Honda Vehicle Protection Plan Warranty
- Honda Not Honoring Air Conditioning Condenser Recall
- DIY Side View Mirror Cover
- Looking for input on 2020 Honda Civics
- Short Distance Driving & Fuel Dilution
- New Floor Mats, but driver's side only.
- Megosdog's Enters the 2018 Honda Civic & attempts to merge old school w/ the new
- Better heal and toe set up?
- First mods-2020 Civic Si?
- 2020 Civic LX Manual Transmission options still available??
- Civic 2018 Urgent problem Tubing loose
- Park to reverse popping/knocking sound?
- Honda Civic Hatchback bumper/headlights swap
- Propeller like sound and rumbling after getting a tire rotation
- New Tires/Alignment = Lots of Errors
- Troubleshooting: 2018 Civic Door open indicator malfunction
