View Full Version : Tech / Misc
- 2023 Honda CRV Sport
- GSR swap Fuel issue? Cuts out at lower RPM?
- Please help!! Hondata Fuel issue maybe??
- H Series Slave Cylinder fits B Series with Header Clearance Issue
- Interactive Network Error
- prelude compresser
- Best bang 4 buck code scanner
- J-series CKP Sensors
- Underdash wiring
- What reference brake pads in NISSIN 16CL14VNH
- OBD1 Auto Wiring Tuck Help
- Can my engine hang on 3 motor mounts?
- 99 Civic y7 to y8 intake swap problems
- Hoping to fit a D16 Rear Engine, RWD in a Kei van!
- 98 Civic EJ9 swapped to H22A Cold Start Issues
- Dry Oil Filter - Oil Bypass Valve?
- Timing belt cover clearance issues installing ATI superdamper on b18c
- Ridgeline pops out of gear when you stop
- J-Series Engine idling for extended periods. Question
- P0172 and P219C trouble codes
- BoostedNW Etune service
- How to tell what intake manifold is on my K series?
- Help can't get fuses out because of screws
- B20v runs lean after changing spark plugs
- EVAP
- 1997 CRV RD1 AWD Automatic Speed Sensor Problems
- Modify Del Sol seats in a DC2: no more excessive lumbar!
- What are these fuel fittings?
- Fuel Pump not priming
- Defective Clutch Friction Plates
- Reliable GSR Distributors for COP Conversion Issues (That Fit Block Off Plates)
- B18A1 valve cover on a B20
- 1999 Civic ECU error P1607 "Internal Circuit Malfunction"
- Remote start not working!
- Rebuilt motor and now it won’t start
- Identify thread please
- Check engine light on (2015 Accord Hybrid) with error code U1206
- 2011 Honda PIlot airbag light on
- AP1 S2000 and G1 Insight wiring pinout
- Horn randomly goes off, even when driving.
- DRAGON FIRE Distributor or OEM distributor
- Key will not go in ignition?
- What to expect
- 01 Civic DX SRS Light Issue
- Throttle bracket for a b20z2?
- EMUSA 550cc Injectors - Deadtime Needed
- B18C1 GSR burning oil like a damn 2 stroke
- Dumb question
- Asking for advice (changing oil)
- B series burning mystery oil
- Mishimoto Slim Fans mounts fell apart.
- '96 B18C oil leak?
- Civic smoking from turbo/exhaust
- 100psi on all cylinders
- EVAP Canister & Hoses
- AEM EMS Board
- 2015 CRV WIPER ARMS NUT SIZE AND TORQUE SPECS
- Anyone heard of Deeps Japan?
- Budget bi-directional tool? Oct 2023
- H22a4 Cam Holder/Cap Oil Oriface O-Rings
- K20Z3 timing chain troubleshooting w/ only valve cover off
- Tie-rod end boot replacement query
- Need help identifying part
- 2003 Pilot Check Engine light and VTM-4 light
- 2007 Acura RDX Starting Issue, Etc.
- High fuel pressure but not sure if that's the problem
- Aftermarket TD43u OBD1 distributor - What's reliable?
- Distributer horrible misfire, vtec vs non vtec distributer
- USB Updates
- B series obd1 distributor not getting 12V
- Boosted b18 civic won’t start
- Turn signal fuse keeps blowing! 95 Integra, please help.
- R134a Replacement CRX/EF
- Cooling fan is acting weird.
- Speedometer inaccurate 95 Prelude Si Auto
- HELP Oil light flickers, oil pressure is good
- AC Freon Leak Question
- Losing my mind
- Recommendations on OBD II scanners / code readers that read Honda PGM-FI DATA LIST?
- 97 civic hatchback rear seat
- 2003 CIVIC FANS NOT ENGAGING WITH AC BUTTON
- Need help with new distributor in my b18a1 EL
- NEED HELP WITH CA SMOG!!!!!
- Cluster Lights faded out Help!
- Did I Kill My Poor 2004 Honda Civic VP (D17A1)?
- EK9 temp/wiring/gauge issue *already searched*
- Condenser Fan Not Running
- Need a connector pin out for 2000 civic ex
- Driver for Honda Fly100 ?
- AC wiring compressor to condenser fan
- What happened to my piston/cylinder head?
- Need Help! High temp
- Need Help with PO420 Code
- B-Series Identity Crisis
- 2017 Civic LX Upkeep/Maintenance Help
- Service connector won’t work!!!
- Z7 vs y8 head height
- Cranking-no start. What else to check?
- Needing a new rotor for my alternator
- TPMS Tire Pressure sensor information via OBD2
- A/C Clutch not engaging. I think it's the MICU / fuse box.
- P61 Prices?
- JDM B18B Intake Air Temp Question
- Eg civic cluster repair or different one ?
- Can't figure out this issue with b18c
- Reputable Aftermarket Wire Harness?
- o2 short term at 30%-35% lean below 3000k rpm
- Honda Fit AC Blower Fan Health Hazard
- P28 hondata vtec?
- Cam Gear TDC marks not lined up at cylinder 1 TDC
- L15BE vs. L15B7
- Swapping 3stage vtec with a single solenoid vtec
- 2000 Civic DX Cluster Issues
- Stock Fuel system limits
- How much engine movement with Hasport mounts is normal? (Video included)
- Timing Belt BS
- Car stalls after warm up (10 min)
- AC PAG Oil System Quantity
- ECT, IAT, TPS, and O2 ground wiring splice location before C103/C223???
- 2007 RDX long Cold Starts. No CEL
- Accord speedometer dropping
- Dual solenoid Vtech d16y8 head
- 2014 Civic AC Compressor housing fix?
- boost controller not working
- Looking for the spec of the connector plug for oil level sensor
- GSR Head
- 93 hatchback
- Problem with 2015 Honda Odyssey
- Weird idle problem
- no power to starter signal wire causing No crank/no start
- 78 Austin mini- D16Y7 engine swap wiring
- Speaker wiring 1993 DX
- Adjust FPR?
- VSA and TC Light On (2009 Civic Si)
- B series thermostat issue
- evap wiring issue 00 civic HX
- repurposing a key fob?
- No Crank/Start
- 99 Crv Auto to Manual swap help needed
- 99 Integra Auto Trans into a 98 CRV AUTO AWD?
- d15b JDM Knock Sensor
- FUEL delivery issues
- Exhaust bolt keeps spinning
- Bad ecu or oxygen sensor
- Refillable Wiper Blades still Exist ?
- Bad Oil Pan Gasket?
- 2020 CR v Hybrid Touring AWD Power Tailgate
- AC Troubleshooting
- New Fully-built Transmission Popping out of Gear - Usually 5th
- 07 rtl ridgeline ac will not shut off advice please
- suggestions after timing belt replacemnt
- Change 2016 CRV Date
- Tucked harness ac wiring.
- Need alternator wiring diagram for 2012 honda odyssey
- 91 civic no crank
- Looking for oem equivalent GSR valve springs
- B16 tucked engine harness
- Broken valve cover breather hose fitting
- Honda JDM service manual
- Ek coupe gauge cluster swap
- Oil pressure too high on built b18
- Heater 95 civic
- What works with what?
- 78 Austin mini w/ D16Y7- harness question
- D16y8 conversion issues
- Need help finding replacement clips
- Identify distributor cap
- External coil?
- 99 civic si battery won’t charge
- How to convert auto ecu to manual P76 - 902 ecu
- 91 accord runs bad when warm
- 1997 Honda CRV AC Issues
- Alternator Relocation
- Out of ideas with fuel issue
- Weird ass issue with dizzy cap on b18cr
- Knock sensor by pass
- OBD2A Ecu - Repairs?
- Is it a good idea to buy Civic DX?
- How much wider is the Duraflex TKO RBS widebody kit than stock
- Tips removing fuel line
- Pablomg's Injectors aren't working!
- Chip tuning with Crome, Solid CEL
- Problem with CarPlay/Siri no longer providing audio feedback
- buzzing sound underneath car 5 hours after parking
- LS-vtec with vtec killer question
- Compression test reading 0-0-9-89?
- Radiator fan works but won’t turn on.
- '03 Accord V6 SRS - seatbelt tensioner & SRS unit?
- Bought an EK hatch could use some advice
- Troubleshooting: 2.7 V6 Vibration at idle
- temp water sending unit (ECT) thread measure
- Honda Stream - Gas pedal occasionally not able to depress when driving...
- Normal ECT range?
- How to reset dashboard lights without infotainment screen?
- Bisimoto header not lining up with exhaust pipe
- Walk away auto lock doesn't work
- No V-tec, cannot find similar thread anywhere!
- 98 Civic EX Starts and then Stalls *Solved* Replaced main relay
- TOP 3100 burner help
- Crank no start, no fuel pump priming.
- Backfiring out of the intake tdc and 150 psi
- Honda SUV 2009 Not starting
- B16a EF Not Starting HELP
- D16y8 engine problem
- Difference between YY ECUs and X5 ECUs
- Looking to replace Pin in alternator
- LSVtec not engaging VTEC EK
- My Honda is overheating, and I have no idea why
- Is it possible to set #1 TDC after timing belt is removed?
- Is it good practice to disconnect battery during timing belt/water pump replacement?
- Newbie needs advice
- Tilton Flow Control Valves?
- Immediate change in compression numbers?
- Innovative traction bar for 91 civic help
- Honda civic d16y7 vs d15b crankshaft pulley differences
- Type R Swap Rotors
- Is it OK to DYI a/c recharge?
- Engine knocking sound
- Help. B16a2
- Fuel Pump replacement; Walbro 255
- Accord 13 AC Clutch engaged after 10-20 min driving
- Coolant temp sensor causing P0171 on start up? Curious about the cause.
- Part number of door lock rod holder plastic bracket?
- Please identify this distributer
- back up camera
- 99 Civic Auto to Manual Swap b18a1 NO START
- Jdm 93 civic no scs connector?
- Aftermarket Battery Terminal with voltage sensor?
- D15B7 Re-Ring Question
- Injector Help!
- hack with cobra rtp honda edition
- 1998 Honda Civic EX coupe headliner clip
- Air getting in power steering system
- AC works briefly and intermittently; 2008 Honda Accord
- B16A2 ~1500rpm vibration
- EDM 90-91 STD cluster (NOT SiR)
- Need Opinions 2001 Honda Accord LX 2.3l IACV Issues
- How to fix cruise control clutch switch
- Replaced Rear Rotors - Right Rear has Streak after 4k miles
- Honda Civic EX misfire codes immediately after new exhaust pipe welded on
- Can Someone tell me what brand of wheels these are?
- Alternatives to NLA Fuel Pressure Regulator
- MPCS service connector tool - where to buy
- Honda iN EPC and service info
- Honda accord 1994 windows and control gauges wont work
- Deleted Downstream O2 Sensor causing Misfire?
- Ignition not giving ecu signal
- Scan tools?
- Dohc Zc engine issue
- Pls help my car is bugging out
