View Full Version : Honda Civic / Del Sol (1992 - 2000)
- civic 1.4is automatic transmission idle speed regulation
- 98 civic no charge issue NEED HELP URGENTLY
- B16 Turbo Intermittent Overheating! HELP
- Need Help With 2000 Civic Fuel Pump Testing
- Tried to replace ignition switch, caused bigger problem
- 1999 auto to manual info needed
- Losing coolant, Head Gasket? 00 Civic EX
- Looking for correct ECM
- Anti Theft device recommendations 99 civic Hatch
- Need help 00 civic
- B16 RAMHORN 3076 stock radiator Overheating!
- What is this leaking coolant below the timing belt and alternator?
- Shifts hard after installing used transmission
- D16Y8 with H throttle body high idle
- Piston order (d16y8)
- B17 Darton turbo blown headgasket
- Moonroof visor reinstall help 00 civic ex coupe
- 1995 civic dx engine swap
- B46A B4RA or M4RA
- Fuel guage with 0-90ohm sender
- Removed aftermarket car alarm, no crank/no start!
- Security Unit Civic 2000
- Spark plugs in or out during timing belt tensioning
- IAT sensor wiring or ecu malfunction
- 92-95 Civic EG ODB Port
- ‘99 Civic Si AC Compressor clutch does not engage
- 97 Honda Civic d16y8 overheating at idle
- Prop Valve Condrum
- Shutting off at idle/neutral?
- Changed gauges from one cluster housing to another gauge issues.
- Can i put a d16y8 dizzy and vtec loom on my ek1
- K24a4 Ek Swap Wont Start
- Cracked steering wheel boss kit
- AC Harness in Engine Bay
- LSV turbo lock vtec
- I need help on my 1993 Honda Civic Coupe DX
- big crack on exhaust pipe, any suggestion how to fix it?
- Bench Bleeding the brake master cylinder
- 2000 Civic d16y7 no spark
- K24a4 oil pressure switch.
- Front Lower Control Arm Torque Specs
- 98 d16y8 race car build
- D16Y8 Misfire from Hades
- Need help with steering wheels
- Wiring DRL on 2000 Civic?
- Ek civic mini Cooper brake upgrade questions
- Ej9 Brakes does not getting harder!!!!
- obd1 harness with obd2 motor/ECU
- 2000 ek with b18b NEED HELP FUSE 31 under dash issue
- No Fuel Pump Prime
- MAP sensor help!
- No CEL at all? Car doesnt crank with new ECU + all Immobilizer Parts
- B20 vtec motor locks up when transmission is tighten.
- 2000 Civic EX Overheating, Replaced Thermostat
- Testing new brake lines
- Wrong distributor cap ?
- 99 Honda Civic
- D16Z6 cuts power at WOT
- D16y7 96-97 vs 98-00 Intake Manifolds
- Clicking noise coming from caliper while turning
- D16Y1 ECU
- What D series is this??!!
- BEE R Type B on D14A4
- Can't find this tick!
- Missfire problems
- 00 Civic EX, new Steering Lock Assembly, back to key stuck in ignition WHY?
- D16 to B20
- Automatic b16 or b18c gsr swap
- 98 ek sedan side skirts
- Are ECU's interchangeables?
- Hi I'm buying a somewhat built engine d16y8
- 1995 D15b7 to JDM D15b Swap - non V-tec - Idles Surge
- 98 Civic ex - another idle surging issue... With video
- Fluctuating idle
- Help me identify these B16 pistons?
- How difficult is it to do a d16z6 timing belt in the car? And a few other problems
- civic no start no crank sometimes after harder drives
- Are the d16z6 injectors good ?
- A/C trouble 1996 civic.
- Just picked up a 95 Del Sol
- 1993 Civic CX hatch B16 swap
- CEL NO CODE
- 00 civic ex P0141 code next steps...stumped...
- Rpm jump
- How to mini-me a d16y7 automatic/ hondata on an automatic. OBD2A
- 1997 Honda Civic 1.4i (EUDM) Crank pulley?
- Will this work
- 2000 Civic EX Coupe Driver side Door Speaker and both Windows do not work.
- D15 from stock s model to d16 from the si model
- DX MC to EX MC
- Burnt clutch smell as i was going up giant steep hill.
- 97 civic Y7 - injector dynamics 1050x
- Extra Washer stuck on hard to remove spark plug
- 97 Honda Civic OBD2 Not Commumicating With ECU
- D16y7 tps no output voltage
- Help! To hot at idle(car stay) to cold when drive
- 1999 Honda civic ex transmission fluid
- Eg2 front lip .. eg6??
- Help with AC components
- Ignition and timing issues. Need help!
- Fuel level sender
- Car has been thrown together before me
- D16Y7/Y8 MiniMe Running Rich and Poorly
- No spark no ground to distributor
- Good mature exhaust for 2000 Civic Si
- 99 coupe bad cat reason?
- Engine harness removal
- D16y7 high idle low idle iacv issues
- 98 Civic EX Skunk2 Idle Issues
- Weird headlight problem , one comes on one goes off ?
- EM1 J's Racing Fenders +15MM
- 97 Honda Civic LX Crank No Start
- 98 1.5 vtec standard swapped into a 99 1.6 hatch cx
- Time to tune
- 93 civic shuts off after turning over
- 99 coupe auto trans issues
- b18c1 break up in vtec
- Overheating temp rising and going down
- 96 Civic EX: Sudden 'bumpy" ride.
- D16y8 auto jerking and loosing all power but still running
- 98 civic hatchback charging problem
- EG - whirring noise - A/C
- B20VTEC Swap high idle
- EJ8 Vitara build
- High idle after headgasket replacement.
- Fuel pump sounds but no fuel
- EX Cluster in DX CEL stays on, Why?
- del sol iccv wiring help
- B20VTEC Crank pully question
- Looking for this part
- engine won’t stay running.
- D to B swap no crank
- Crank sort of no start?
- (HELP) Which cats for 98 Honda civic EX b20b swap
- 1994 Honda Civic HB - Part Identification
- What model/yr/body style do these seats go to?
- EM/FI 15A Fuse keeps blowing?
- B16 no spark, no engine light on
- B16 - Rotating Crank while CAMS at TDC
- b16a Ticking Sound
- OB2A d16y7 stock wire harness to OB2A Vtec Engine & manifold
- B20VTEC Injector Question
- P0505 Code on Y8 intake swapped D16Y7
- 95 Civic DX Coupe, Horn not working
- problems after replacing clutch
- Coilovers
- S40 gearbox won't turn
- 1995 Honda Civic Doesn't Start
- Car sounds like its cammed when stock
- Del sol Cat
- Main wiring harness AT to MT conversion.
- Pls help identify these skunk2 cams on a b16a vtec
- I have a civic with a gsr swap I am trying to get it runn it is boosted aswell
- LS/VTEC dowel pin question
- 92 civic stumble
- D16y7 Misfire on all 4 cylinders
- 2000 honda civic wont idle in drive and shuts off when hot
- Issue with wiring 1993 del sol S no bulb check circuit no beeper
- 95 Civic LX trunk won't pop open automatically
- Thermostat Issue - Weird
- 98 Civic Hx 02 / Misfire codes
- Skunk 2 Intake Manifold and TB swap
- Overheating/ Fans not cutting on need help!
- HELP 1993 Civic Lx Auto Sedan
- K24 Swap - Harness and Throttle body
- 1997 Civic No Start
- Black box under rear deck of 2000 LX?
- B series - Size of water outlet in head?
- Is Torque converters of EG and EK are interchangeable
- Engine harness swap (From obd2a to obd1) mini me swap
- 96 Civic No Start / Intermittent Stalling
- No clue what to do. Need help pls
- '01 b18c1 in to '98 Civic LX
- Fuel pump won't prime
- Transmission torque mount
- 1995 Honda Civic LX won't start after rain
- Car door speaker replacement for 1995 Honda Civic LX
- Check engine light
- Coolant overfill tank stays maxed out, surging idle when warmed up.
- d15b7 Valve Cover Stud Torque Spec
- B18C1 cam cap rail question
- Ek civic cluster needle came out with pin
- Engine sputters
- 1997 Civic daily build.
- 00 civic EX advice after mechanic installed LKQ engine, lotta mistakes
- 1997 civic
- K24z3 into a ek
- Motor mount broken in the block
- Replacing Rear Break Lines '98 Honda Civic LX
- 94 civic lx d15b7 crank issue.
- D16y7 driver side motor mount click
- Iacv help
- Need help with ECU!
- 1998 civic tailgate lift handle
- 1998 civic rear lower control arm bushing help
- 1992 Honda Civic stutters after about 15 minutes
- Identifying B16 Head
- 00 Civic Interlock Solenoid Issues continued...
- Power door Issue
- cv joints
- Mishimoto cooling hose fitment
- Vehicle stalled, cranks, no spark.
- Fuel pump grinding noise, occasional CEL, car jerks from 1k - 2k rpm
- B18C4 EJ9 No spark
- POOR ACCELERATION / BOG DOWN EG 94’
- 00 Civic Ex wiring questions
- Ep3 steering wheel on del sol
- Timing belt slack
- 1999 abandoned civic being resurrected after 10 years. Issue with bogging
- My EM1 is not running 100% - Any ideas?
- Do you add any dielectric grease to the ignition coil spring?
- EK9 replica wheels. 4 lug and 5 lug
- Overcharging issues
- 2nd to 3rd High Rpm Shift Hesitation?
- Delsol ECU identification
- Mechanic apprentice w/ questions ‘97 civic ex
- Del Sol 1994 Tachometer Capacitor Specs
- 99 si coupe front subrframe assembly compatibility
- Single Click From LHS when braking hard
- EG civic bumper reinstall help
- Obd1 gsr into 98 ek hatch wiring question
- running lights won't work ?
- NEED HELP ASAP
- 98 civic lx knocking?
- 98 Honda civic lx
- 1992 Civic EG Hatch - Can you add A/C?
- Eg8 sedan battery shorted new battery negative lead sparks bad when trying to connect
- 93 EJ1 cutting off driving
- Need Help with ECU
- small idle surge after b20 swap
- Green wire Z6 ECU harness?
- Civic Si/Integra exhaust question…
- D16y8 p0141 code car won't stay running
- Wacky Vent Selector Nob Behavior & Not Working 99 Civic LX
- Eg civic drivers side plugs help
- situation: D16A swap into 99 civic
- Possible Interlock Shifter Solenoid issues 00 Civic EX
- Please help
- 97 civic
- Low Pitch Humming under Acceleration/Deceleration
- B20vtec problem
- Will removing Black Box & PCV valve on Naturally Aspirated car cause RMS to leak?
- 1993 Honda Del Sol Si Thread
- '93 civic eg automatic climate control turns off
- Help with turn indicator problem
- Wheel Sizes
- Civic Ek B16A2 Temperature gauge issue help
- 300k mile abuse
- Honda Civic 1999 Sedan (D15b Non-Vtec P2C ECU), Power Steering issue!!!
- D16y8 Swap into 92 EG hatch / OBD1 or OBD2?
