Replacement D16Z6 Rocker Arm Assembly
Old 09-27-2016, 05:54 AM
GRN-BNDT's Avatar
Default Replacement D16Z6 Rocker Arm Assembly
Are the rocker arm assemblies the same between all D series engines? One of the ears on mine is broken where the valve cover bolts threads in. Broken bolt+incorrect extraction method=sadness. So I'm looking for a replacement and I know my local junkyard has quite a few D series motors, but I don't think there are any D16Z6s, only D15s and the like, so I'm wondering if I could use the rocker arm assembly out of one of those. Don't want to buy a whole different D16Z6 head. Or if anyone has one for the D16Z6, let me know.
Old 09-27-2016, 05:58 AM
GRN-BNDT's Avatar
Default Re: Replacement D16Z6 Rocker Arm Assembly
Update, still learning about the breakdown of this engine. I really just need the #4 cylinder side camshaft holder.
Old 09-27-2016, 02:29 PM
Hysterically Calm
TomCat39's Avatar
The rocker arm assemblies are different between the D16Z6 and all the USDM/CDM D15's of the 92-95 era. A non vtec won't have provisions for the vtec push pin that is in the D16Z6 rocker arms.
You can check the OEM part sites and check the part numbers between the 92-95 EX/SI and then the 96-00 EX (D16Y8) to see if the rocker arm part numbers match there.
If they do then you can also check for the 96-00 D16Y8 at your junk yards.
I suspect the part numbers are different though.
Venomsrose66
12-24-2015 08:16 AM
honda8991
12-26-2013 07:12 AM
stolen4drteg
10-04-2006 04:59 PM
Quick Reply: Replacement D16Z6 Rocker Arm Assembly
