''simply BLACK''
Old 08-13-2013, 05:21 PM
ls joker's Avatar
Default ''simply BLACK''
2012 b16a cams &57trim vs. gsc n1s & tga- 6157 turbo
!!!! 2022 results
479whp/342wtq mustang dyno
i present BLACK
00' em1
- golden eagle 84mm b16 sleeves
-traum 10.8 comp pistons
- 21x2.350x220 heavy duty wrist pins
-eagles rods
-gsc n1's cams
-id1300s
-skunk2 pro series intake manifold
- alpha 70mm throttle body
- megapower r 76mm catback
- afi turbo ramhorn
- afi 3'' downpipe
- afi 2.5'' charge piping
- garrett gtw3476r turbo, .82 ar turbine housing
- go autoworks gt800 backdoor fmic
- ptp turbo blanket
- tial mvs/ 13psi spring
- tial q/ 6psi spring
- hondata s300 v2
- go autoworks small catch can
- hondata cpr/ k series coils
-hondata BBG
- small 3" turbo intake/vibrant filter
- mfactory helical lsd
all pic are taken with my phones sooooooo....
gona take better pics, moneys shots, full car shot tomorrow and through out the week
Old 08-13-2013, 05:39 PM
ls joker's Avatar
Default Re: ''simply BLACK''
old bay picName:  photobucket-2795-1343695095977.jpg
gt500 vs. old afi backdoorName:  photobucket-50706-1353885800944-1_zps794da811.jpg
goodiesName:  IMG_20130714_105425_524_zps7fbf6b4c.jpg
cam installName:  IMG_20130713_103114_816_zps6a394dc3.jpg
Old 08-18-2013, 09:44 AM
ls joker's Avatar
Old 02-25-2014, 04:47 PM
ls joker's Avatar
finally made a youtube account lol.
Old 02-28-2014, 03:33 AM
dcmatt's Avatar
Why the n1's over the t1's?
Old 02-28-2014, 07:35 AM
ls joker's Avatar
honestly, i was lookin for itr cams. couldnt find a decent pair without buying new. at the time i wasnt sure if i was going to be gettin a new turbo or not. and i knew the n1's and my old 57trim would be flawless. i knew the build got serious once i got the new snail
Old 02-28-2014, 08:05 AM
EFvtec Yo!'s Avatar
Nice Setup. Question... U have any issues with your dumptube resting/rubbing your radiator? I have the same AFI ramhorn/dp/dt on a new setup I am doing and my dumptube is literally pressed against my radiator.
Old 02-28-2014, 08:10 AM
ls joker's Avatar
no it kinda close tho
Old 03-22-2014, 07:06 PM
ls joker's Avatar
isb and seal. reinstalled my mfactory lsd.Name:  IMG_20140321_143442193_zpskrmcwyy9.jpg
Size:  105.0 KBName:  IMG_20140321_143920514_zpsiunqc1hq.jpg
Size:  125.9 KBName:  IMG_20140321_150623589_HDR_zpsflfhqquq.jpg
Size:  136.4 KBName:  IMG_20140321_145932981_zpsfqrbwtp0.jpg
Old 03-22-2014, 09:57 PM
KevinEF7's Avatar
Am I reading it right that your B16 setup form last year made just over 200whp??
Old 03-23-2014, 08:13 AM
ls joker's Avatar
no. the prior year was 364whp/ 230wtq. the new setup went 413whp/236wtq.
i lost one thousand rpms in spool time from the gain. but im sure it was worth the change. goin to a dyno day in april, cause i know those torque numbers are ****. i can feel it. but theyre just numbers
Old 03-23-2014, 08:15 AM
ls joker's Avatar
lsd smoothed out the launch, but still spins thru second and third gear. so glad i put that isb bearing in
Old 08-09-2014, 05:52 AM
ls joker's Avatar
sooo..... had two issued which were effecting my spool. the damn coupler off my compressor to my intercooler( backdoor coupler) had a leak. and had a leak at the damn oil breather box. vacuum has been reading lower and lower. capped the port off on the intake manifold, problem solve. after all issued being resolved, engine spools bout 500 rpms sooner. this winter i plan on doin all new couplers, small go autoworks catch can, and stickier tires. maybe some tuner 1's
Old 08-09-2014, 05:55 AM
ls joker's Avatar
id say not bad for a 61mm. considering it spooled a thousands rpms slower than my 57trim and 9:1 pistons. and after the recent changes with it spooling sooner,... i say not bad.
Old 08-09-2014, 06:05 AM
Moderator
TheShodan's Avatar
That's because of the smaller exhaust wheel of your 6157. That helps a tiny bit. Changing from N1s to Tuner 1s won't change much of anything with the turbo's behavior. Save the money for other things, like, brakes, fluids, pads, etc.
Old 08-09-2014, 07:00 AM
ls joker's Avatar
i got my basis on the tuner1s from the gsc vs itr thread thanks to d- rob. i already have hawk plus, and blanks. goin to home depot now, to window shop for a brake duct system.
Old 08-09-2014, 08:31 AM
D-Rob's Avatar
My findings regarding the GSC's were with the T1's, not the N1's.
The N1's are similar to the Tuner1's, and won't change much. It's just the T1's that I still haven't found a soft spot for.
Old 08-09-2014, 09:50 AM
Moderator
TheShodan's Avatar
I've already described the soft spot of the T1s (I take it you mean "sweet spot"?). But its on a range that many of the younger guys aren't seeing; smaller mid-framed turbochargers in the GT30R-to GTX3576R range (56lbs/min-60lbs/min), which focuses more on torque, not just top end power. It can do top end power like a Pro1, also, but its limited after that.
I even admit, when I first got them, I thought that based upon their design specs they were going to be for the larger mid-framed and large-framed turbochargers. (61lbs/min +). But after using these, setting up a few other projects in the H-T community, I'm seeing that the range is broader than most, so it can compete with the Pro1 for turbocharger applications, but after about 75lbs/min +, its time for a DDTECH or Web Cam to do the job for peak power. Peak power is still what the masses on this forum look for,
and the fact that higher idle and base ignition timing has to be slightly increased, turns off the average backyard specialist.
Old 08-09-2014, 10:35 AM
D-Rob's Avatar
No, I mean "haven't found the soft spot," meaning I have very little love for them.
Old 08-09-2014, 11:19 AM
ls joker's Avatar
i was refering to the higher pressures it took the t1's to make close to the same power on lower pressure, on naturals build.
from what ive found, the newer tuner1's are 11.9mm intake/ 11 mm exhaust. with more duration than my n1s. cant remember the duration but, the n1s are 11.6/ 11
Old 08-09-2014, 11:56 AM
Moderator
TheShodan's Avatar
Gotcha.. That's what I was making sure..
Well, we all have our love and hate for certain products for a variety of reasons.
Old 08-09-2014, 11:57 AM
Moderator
TheShodan's Avatar
again, 6 of one, half dozen of the other.
Old 08-09-2014, 02:46 PM
ls joker's Avatar
yea i know. kinda just leaned on the tuner1s. been talkin to travis at gsc since bout may, t1s keep getting pushed back from july, to august. now prolly no production on the t1s till september. wouldnt be surprised if they dont go back on sale till next year.
Old 08-09-2014, 02:48 PM
ls joker's Avatar
i will give you this though. you did try and tell me to grab them last summer. at that point, i thought those were to big of cams for my 57trim
Old 08-09-2014, 04:09 PM
DDTECH's Avatar
Is GSC not producing camshafts anymore for the Honda crowd?
Quick Reply: ''simply BLACK''
