FS: Set of Koni yellows (adjustable) with Ground Controls for all 96-00 Civics
I have a set of Koni yellows (adjustable, Neuspeed spec with shortened shock rod and stiffer valving) with Ground control coilovers. These will fit all 96-00 Honda Civics. The spring rates are 375lbs. front and 325lbs rear. Spring are both 8" length so they can be swapped front to rear depending on your driving style. The shocks and springs are in good condition. Shocks used for about a year and a half and Ground Controls for about 9 months.
Asking $475
[Modified by 6ghatch, 11:01 AM 2/7/2003]
Asking $475
Re: FS: Set of Koni yellows (GSRrR)
would they fit DCs? How much for just shocks?
Re: FS: Set of Koni yellows (6ghatch)
thats not true, the front wishbones need to be tightened, i just did the opposite sway put dc's on a ek, and i ad to widen the fork then, i t should fit, however you might have to get civic wishbones if it doesnt tighten up enough, allthough i dont think u will have a problem
Re: FS: Set of Koni yellows (AllMotorEF9)
Re: FS: Set of Koni yellows (silverEl)
SicTransitJosh
03-15-2012 04:16 PM
fake mugen power
07-26-2007 03:00 PM
EL-Driver
04-29-2002 07:14 AM
