FS: Rockford Fosgate Power 1000bd 1000Wrms x 1Ch @ 2ohms
Price: 350 obo
Rockford Fosgate 1000bd amp for sale
Awesome amp, tons of power, bass adjust **** included
1000 WATTS RMS AT 2 OHMS
500 WATTS RMS AT 4 OHMS
good amp for Alpine type r's, jl w6's or a w7, etc.
Re: FS: Rockford Fosgate Power 1000bd 1000Wrms x 1Ch @ 2ohms (b18cinteg96)
Some more info on the Amp:
from sound domain:
The fanatics at Rockford Fosgate have defied the laws of physics! How else can you explain Rockford cramming 500 watts of power into a chassis the same size as their 250-watt models? The new Power 1000bd amplifier utilizes STARDUST (Single-Terminal Alternating-Rail DUal Sampling Topology) technology to achieve amazing efficiency. No longer limited to traditional class-D shortcomings, Rockford's class-bd amplifier delivers the highest watts-per-square-inch possible! The Power 1000bd comes with Punch Bass, a remote operated bass level control that helps correct for missing low bass output in the automotive sound environment without adding excessive boost. The supplied remote level **** can be installed anywhere for easy tuning. The Power 1000bd features a built-in 24 dB slope low-pass crossover continuously variable from 50-250 Hz. Rockford’s Transnova circuitry simplifies the current and voltage gain while TOPAZ (Tracking Operation PreAmplifier Zone) circuitry eliminates 80% of unwanted noise created by ground loops. Power series amplifiers feature discreet surface mount technology (DSM) utilizing high-speed robotics to produce circuit boards that are more efficient, put out more power, and are less prone to unwanted noise. The result is sound so clean and bass so tight you have to hear it to believe it. To keep the amp protected, Rockford’s NOMAD (NOn-Multiplying Advanced Decision) protection circuitry uses an analog computer that serves to protect, but not limit the amp. When the bass hits, you can count on this Power amp to keep its cool. The Power 1000bd features MEHSA (Maximum Efficiency Heat Sink Application) heat-sink technology, a unique design that results in five times better heat dissipation than conventional amplifier designs. The updated die-cast heatsink is powder-coated with SolarTex for greater heat dissipation and has a sleek, rounded shape. Features removable endcaps that cover all connections for a clean, finished appearance. Requires outboard 100-amp fuse, available separately.
Subwoofer Mono Amp Specifications
* Amplifier Type: Mono
* RMS Power: 500W x 1 @ 4 ohms
* THD at 4-Ohm RMS Power: < 1%
* RMS Power: 1000W x 1 @ 2 ohms
* Speaker Level Inputs: No
* Preamp Outputs: Yes
* Built-In Crossovers: LP
* Bass Boost: 0 - 18 dB
* Frequency Response: 10-250Hz
* Signal to Noise Ratio: > 100 dB
* Fuse Rating: 100 amps
from sound domain:
Aloha04MSM
03-22-2006 07:46 PM
