FS: OH: GSR motor ITR transmission full swap.
Sold my race car shell and still have the motor and trans to sell. This is a very reliable setup every piece on it has been replaced with from the dealer oem parts. No parts store junk. This motor is an 83k dropout and runs flawless. I need it gone asap as its taking up space in my garage.
if interested i can send more pictures or anything you need car running and driving.
my name is mitchell and you can contact me through text or call, 513-441-8715
asking $2500 which i feel is way more then fair.
LIST:
GSR motor came from 98 GSR
New oil pump
New water pump
New Timing tensoner
New head gasket
New thermostat housing
New plug wires
Gates racing timing belt
ARP head studs
CTR Intake and Exhaust cams
CTR dual valve springs
RC 310 injectors
AEM fuel pressure regulator
1G skunk 2 intake manifold
Hondata intake manifold gasket
s2000 throttle body
1G Hytech header
PP Harmonic damper
Moroso 5.5 quart road race pan
Avid race billet mounts
Transmission is an ITR transmission
Full oem rebuild
New bearings
New syncros
Oem itr lsd
Gear X 4.975 straight cut final drive
Avid shift linkage
Has never ran anything other then Torco RTF since rebuild and is 100% perfect.
LIST:
New oil pump
New water pump
New Timing tensoner
New head gasket
New plug wires
ARP head studs
RC 310 injectors
s2000 throttle body
1G Hytech header
PP Harmonic damper
Full oem rebuild
New bearings
New syncros
Oem itr lsd
Avid shift linkage
