FS: OBD I to OBD II adapter
Re: FS: OBD I to OBD II adapter (SPECR)
Hey man,
Do you have any pics? I need to see this. I am assuming it will fit in the B18's also. I am very interested. I always thought they have it the other way?
To clarify things, the adapter harness goes between the connections found inside the passenger side kick panels that once plugged into the old ecu. It allows you to plug a OBD II ecu in the car with a B-series swap(OBDII).
Hey I not trying to be stupid. Just in case. You mean I can plug my 2000( OBDII ) gsr swap in to my 1994( OBDI ) civic HB . If we are correct, do you do CODs?
Re: FS: OBD I to OBD II adapter (Civic1620)
I made it myself. It will work but you still need to run four wires to the engine harness. A 92-94 civic (OBD1) does not have a knock sensor, crank angle sensor, or a secondary butteryfly.
guyuenvy
05-16-2002 12:27 AM
