FS: Fully Built SOHC engine for boost. 1000.00 OBO
FS: FULLY BUILT SOHC FOR SALE 900.00 *Price Drop*
Engine at 6k Miles on it 900.00
Engine: Fully built and balanced D16y8 Block (1999) Eagle Rods, Endyn Rollerwave 10:1 CR forged pistons (.020 overbore) everything replaced, pumps, gaskets everything... turbo tolerences on everything also... STR blockguard. D16z6 cylinder head (stock except for a ZEX Cam 59100), AEM Fuel Rail, CX engine harness and shift linkage with rear motor mount bracket, throttle cable.
The engine does not come with tranny or clutch or flywheel bolts and is missing two pressure plate bolts.
PM offers if interested in trade... THIS ENGINE NEEDS A TURBO KIT!!! IT IS BUILT TO EASILY WITHSTAND 7-13 pound daily driven and more for track fun... It has never seen boost or nitrous I assure you...
Came out of this car.
Modified by straywalker at 1:31 PM 1/22/2005
Modified by straywalker at 10:58 AM 1/26/2005
Modified by straywalker at 10:59 AM 1/26/2005
Modified by straywalker at 11:00 AM 1/26/2005
Re: (spooncivic1)
yes at high rpms only cause the ring tolerances. since its bored .20 over the rings are set for a turbo tolerance there for oil will burn at high rpm's. does not burn bad at all or make a huge white cloud of smoke. very minute.
Tb0y
06-13-2015 04:50 PM
