F/S: Autopage RS-850LCD RS850 LCD 2 Way Alarm/Remote Start/Pager
Old 04-29-2004, 08:59 PM
confucius's Avatar
Default F/S: Autopage RS-850LCD RS850 LCD 2 Way Alarm/Remote Start/Pager
I have a Autopage RS-850 LCD aram for sale.
Brand new. Asking for $175 shipped.
cnaman@ureach.com
STANDARD FEATURES:
# One, 4 button High Frequency Carbon Fiber Standard Remote Transmitters
# One, 5 button Carbon Fiber 2-way FM LCD transceiver
# Two-way, window mount Long range helical transceiver antenna module
# SIS-11 dual stage shock / glass sensor
# Discrete temperature sensor that communicates in-car temperature via LCD remote
# Window mount knock sensor for driver paging
# Remote car starter with 5 on-board relays and all the features of the RS-650
# 120 Bit Random Code Hopping
# Code Learning / Anti-scan Receiver
# Back-up Memory System
# Dedicated Remote Panic and Car Locator
# Passive Arming By-pass from Remote Parking Light Flash Dual Polarity (relay on-board)
# 2nd Channel Trunk Release Output
# 4,5,6 Auxiliary Programmable Outputs
# Plug-in Push type Valet/Override Switch
# Plug-in Super Bright LED
# Starter Disable 500mA Output with Relay & Socket
# Dome Light Illuminated Entry
# 1 Positive, 4 Negative Inputs
# Error By-pass Reporting
# 120 db Electronic siren
# Horn Honk Output
# Ground When Armed Output
# Dual Polarity (+/-) 500mA Door Lock Outputs
# Drivers Priority 2 Step Unlock
# Output for optional P.I.R. sensor
# All Programmable Features are Programmed via the Remote Transmitter
# Compatible with 2003 Vehicles
REMOTE START FEATURES:
# 5 On Board Relays
# Ignition 1
# Ignition 2
# Starter
# Accessory
# Parking Light
# 3rd Ignition Output
# Ground When Start Output
# Diesel Fuel Compatible
# Hood Safety Pin Switch Input
# Selectable Voltage / RPM Start Sensing / Timer Start
# Timer Start Control (.6 seconds - 4 seconds)
# Temporary Stop Feature
# Factory Security Disarm & Rearm outputs
# Programmable 3 Hour / 24 Hour Timer Start
# Sensor Control Output During Start
# OEM Alarm Output
# Selectable Run Timer
# Ignition Control Lock By-pass During Remote Start
# Double Push Safety Start Feature
PROGRAMMABLE FEATURES:
# WEIGHT: 6 lb. 6 oz (2.9kg)
# Chirp Delete
# Manual / Passive Arming
# Passive Arming Door Locks
# Ignition Control Door Locks
# Automatic Re-arm
# Auxiliary Channel Outputs 4,5,6,Momentary/Latched/Timer 45 Second door delay entry
# Single/Double Pulse Unlock
# Pathway Illumination
# Voltage Sense/RPM Sense/Timer Start
# 5,10,20,30 Minute Run Timer
# Gasoline/Diesel Engine type
# Lock-Unlock Output Timing (.9-3 sec.)
# Factory Disarm/Rearm
TWO-WAY LCD REMOTE OPERATION:
# Two-way transmitting remote and paging receiver with 3 color LCD
# Transmitting range up to 2000 feet and
# receiving range up to 1 Half mile
# 5-button configuration
# Powered by 1 "AAA" type 1.5 volt alkaline
# battery with battery life indicator
# 3-color LCD screen displays
# Over 30 icons and figures providing around the clock confirmation on vehicle and alarm status
# Back lighting for nighttime use
# 24 hour digital clock with countdown timer for parking meter reminder and alarm
# The clocks doubles as a temperature indicator for monitoring in-car temperature Multiple audible
# confirmation tones and melody chimes as well as vibrator mode for paging
# Silent arm mode capable
# Transmitter key lock
# Battery save model
confucius is offline
Old 04-30-2004, 11:45 AM
confucius's Avatar
ttt
Old 05-02-2004, 02:05 PM
confucius's Avatar
Default Re: (confucius)
ttt
Old 05-11-2004, 11:24 AM
confucius's Avatar
Default Re: F/S: Autopage RS-850LCD RS850 LCD 2 Way Alarm/Remote Start/Pager (confucius)
TTT UP
Old 05-24-2004, 09:09 AM
projectPSI's Avatar
YGPM
projectPSI is offline
Old 05-26-2004, 03:03 PM
confucius's Avatar
Default Re: (thundergrayteg)
sold.........................
Old 06-11-2016, 05:53 PM
Bucknutty's Avatar
Do you still have alarm system interested in getting it
Bucknutty is offline
Old 06-11-2016, 05:57 PM
e0325's Avatar
Lol
Sold in 2004
e0325 is offline
ramos2589
Audio / Security / Video
02-02-2008 04:28 PM
darkirony
10-10-2004 08:43 AM
Quick Reply: F/S: Autopage RS-850LCD RS850 LCD 2 Way Alarm/Remote Start/Pager
