Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Traction Bars and their Benefits for Road Racing/Autocross
Old 05-24-2005, 09:47 AM
Adam.'s Avatar
Default Traction Bars and their Benefits for Road Racing/Autocross
I wanted to find out everyone's opinion on these. I get horrible wheel hop at the track (drag) so I'd like to pick up a set, but since I'll pretty much only want them for one or two trips to the track, I'd like to see if they have any real benefit to rr/auto-x to justify their $350 cost. I'm not worried about classing as most everything I'll do is HPDE.
Thanks.
EDIT: By the way, I read all of these threads already:
https://honda-tech.com/zerothread?id=1202148
https://honda-tech.com/zerothread?id=940859
https://honda-tech.com/zerothread?id=880580
https://honda-tech.com/zerothread?id=823954
https://honda-tech.com/zerothread?id=818507
https://honda-tech.com/zerothread?id=749954
https://honda-tech.com/zerothread?id=695823
https://honda-tech.com/zerothread?id=659450
https://honda-tech.com/zerothread?id=153006
Nothing really concrete. Everyone is talking about another thread out there that I can't find. So I was hoping to start up a new discussion.
Modified by DarkKnight1 at 1:58 PM 5/24/2005
Old 05-24-2005, 04:36 PM
JRDbuilt's Avatar
Default Re: Traction Bars and their Benefits for Road Racing/Autocross (DarkKnight1)
im curious too!!
Old 05-25-2005, 03:37 AM
solo-x's Avatar
Default Re: Traction Bars and their Benefits for Road Racing/Autocross (JRDbuilt)
the problem is they aren't legal for the majority of the classes out there. since the majority of the people in here ARE concerned about classing, either now or in the near future, most have not tried any traction bars. you might have more luck asking in the suspension forum or the drag racing forum.
nate
Old 05-25-2005, 04:03 AM
swamp honda's Avatar
Default Re: Traction Bars and their Benefits for Road Racing/Autocross (solo-x)
i also would like to know what the end result is on this discussion................
Old 05-25-2005, 08:56 AM
StyleTEG's Avatar
Default Re: Traction Bars and their Benefits for Road Racing/Autocross (joeysol)
The only two benifits I see are ability to adjust castor, and some slight increase in chassis regiditty.
However, if the bars bind (like some have noticed) they pretty much become more harm than good.
Old 05-25-2005, 09:13 PM
stormy's Avatar
Default Re: Traction Bars and their Benefits for Road Racing/Autocross (StyleTEG)
the only version I've liked so far are those from competion engineering which are adjustable for ride height as well.
Since they are alot like the radius rods in the old da you'll get the same benefits such as greatly reduced wheel hop and added suspension rigidity as well as a major brace at the tips of the front frame rails which should greatly improve overall chasis rigidity and turn in and braking
but like I said I would look into the competioing engineering versions through moroso
Old 05-26-2005, 04:29 AM
Default Re: Traction Bars and their Benefits for Road Racing/Autocross (stormy)
But has anyone actually use one of these on the track????????????????
Old 05-26-2005, 05:51 AM
mike-y's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stormy &raquo;</TD></TR><TR><TD CLASS="quote">the only version I've liked so far are those from competion engineering which are adjustable for ride height as well.
That picture shows the radius rods located close to the outer mount points, very close to the tires, which limits how much you are able to turn your wheels. Not a good thing for track driving. That appears to be a drag race only setup.
Some other brands locate the pivot points further inboard, and are supposed to allow full range of suspension movement without binding (like the stock ED/EF and DA radius arms). That would be my biggest concern when looking at one of these products.
Gojo
08-27-2011 03:51 AM
MrParks
08-17-2011 05:00 PM
NSCRA
05-18-2010 08:54 PM
95bkeg
11-22-2006 08:35 AM
Quick Reply: Traction Bars and their Benefits for Road Racing/Autocross
