Run-Flat & Non-run flat tire mixing??? - Honda-Tech
Old 05-01-2006, 01:34 PM   #1
New User
Default Run-Flat & Non-run flat tire mixing???
I need some education. Long story short...I have run flat tires. Front alignment is out (new car...6 months old) and the tires are wearing badly. I bought 4 new non-run flat tires (in garage ready to be mounted). Note: 225 front, 255 rear.
Question:
The rear OEM run flat tires are in great shape, but the front OEM run flat tires are shot. I was told that you can't mix run flat tires and non run flat tires (i.e. fronts not being run flats, rear being run flats). Why is this?
So let's summerize, new BMW (6 months old), needs tires and a new alignment. BMW's response...sorry not our problem. We don't warranty the tires and the alignment is under warranty for the first 2,000 miles. Not impressed, but that's life....could always be worse.
J28S is offline   Reply With Quote
Old 05-01-2006, 01:37 PM   #2
Default Re: Run-Flat & Non-run flat tire mixing??? (J28S)
Should have bought the TL
Honda318dx is offline   Reply With Quote
Old 05-01-2006, 02:11 PM   #3
drkarrow's Avatar
Look up "Lemon-Law" in your state. That's realy messed up. There's no real reason you shouldn't be able to mix the tires. But whenever you change the tires on one end of your car and not the other, you can greatly change the handling characteristics.
drkarrow is offline   Reply With Quote
Old 05-01-2006, 03:42 PM   #4
o-man's Avatar
Location: living too close to Karl, everythings busted, nc
Are they the "same" tire, or two different brands? The biggest difference you will feel is impact harshness. The non-run flats wont have as stiff a sidewall and should weigh considerably less. Try it, if it feels weird, install the other two tires
o-man is offline   Reply With Quote
Old 05-02-2006, 12:55 PM   #5
New User
Corey - Yep, your right...I should have got th Porsche Cayman instead.
I can understand that the RFT has a firmer sidewall than a non-RFT. But didn't know companies couldn't sell you two tires if you still had RFT on the rear. Also, just trying to understand exactly(technically) how N-RFT and RFT mixing would drastically upset the handling.
Yes, if I put just the front tires on...I would have two different brands of tires on the car.
Lemon Law in this state wouldn't help with tires and an alignment. BMW could argue that I hit something which caused the car to go out of alignment.
Guess I'll be TESTING the OEM tires tonight to see how long it takes for the tires to gain traction when reving up the motor and dumping the clutch (didn't say burnout). I'll also test the LSD out and see how well it works in different situations excellerating from a stop. Hey, I'm gonna get every cent / ounce of fun out of those tires before I get the new tires mounted and an alignment.
O-man - I may go ahead and do it for a day just to see first hand how harsh the difference is.
Thanks again.
Old 05-02-2006, 01:16 PM   #6
My95SlvrBlt's Avatar
It could have been much worse. Picture yourself in a touareg... Theyre the same, if not worse for tire problems.
My95SlvrBlt is offline   Reply With Quote
Old 05-05-2006, 12:58 PM   #7
New User
Well, here's the update. Got the front two on the car and drove the **** out of the car...couldn't tell a difference (that is the car had a problem with non-RFT in front and RFT in the back). Next day, I got the rear tires put on. I will say that the OEM tires performance wise are pretty sweet (that is DAMN good).
Question #2: Why is it that BMW uses sand bags for an alignment? Would it benefit other cars (i.e. Acura Integra) to have this done the same way? Just curious.
Old 05-05-2006, 02:21 PM   #8
xerox445's Avatar
Sitting in the car changes the alignment of the car slightly, weighting it compensates for the driver weight and keeps the car a bit better aligned.
xerox445 is offline   Reply With Quote
Flat tire GoLowDrew Wheel and Tire 6 07-26-2011 12:55 PM
2008 BMW rear tires wearing extremely fast? so simple General Discussion and Debate 115 01-26-2011 04:10 PM
Back From The Dead PSU Honda / Acura 39 06-30-2009 11:08 PM
alignment help bboyprelude Honda Prelude 7 05-18-2003 04:12 PM
Flat tire, do I need an alignment? CC2 Tech / Misc 3 01-14-2003 05:19 PM
Tags
bmw, car, flat, flats, mix, mixing, nonrun, nonrunflats, regular, rft, rfts, run, runflat, runflats, tire, tires
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
