Rim offset and your alignment...how does it change things? - Honda-Tech
Old 01-28-2003, 01:30 PM   #1
Austin's Avatar
Default Rim offset and your alignment...how does it change things?
Alright...I've been thinking here about these two things and it's really got me wondering. I have a 2001 Type-R and I have a slew of rims and tires that I run around on, however I was wondering how the different offset and rim width changes your alignment.
Stock rims, 15x6 not sure of the offset, +50mm...running 205-50/15 Falken Azenis
Stock rims, 15x6 not sure of the offset, +50mm...running 205-50/15 Victoracers
Mugen rims...16x7 +43mm...running 215-40/16 Kumho Ecsta 712's
So I get the alignment down with the Azenis on the car, then I daily drive the 712's, and use the Victoracers on the track...what kind of differences will I see in regards to the alignment settings from one rim/tire combination to another?
Thanks,
Austin - who is staying out of header threads
[EDIT]fixed the offset[/EDIT]
[Modified by Austin, 3:58 PM 1/28/2003]
Austin is offline   Reply With Quote
Old 01-28-2003, 03:34 PM   #2
1 speedstar's Avatar
Default Re: Rim offset and your alignment...how does it change things? (Austin)
im wondering the same thing... hopefully there will be some good input on this subject.
i'm wondering if using 13 inch steelies to get the car aligned with, then using 15 inch 32 offset rims will affect the alignment.
thanks,
Anthony
1 speedstar is offline   Reply With Quote
Old 01-28-2003, 03:41 PM   #3
Big Phat R's Avatar
Your stockers are 50mm offset.
Alignment (toe in/out, camber etc) shouldn't change as long as you are using similar sized rims (i.e. 15") and tires - but your scrub radius will change a bit when using the +43mm offset Mugens (14mm wider track).
Alignment changes more when you raise/lower the car - vs widening track width.
A similar post a while back did not get much input:
http://www.honda-tech.com/zerothread?id=377951
[Modified by Big Phat R, 3:42 PM 1/28/2003]
Big Phat R is offline   Reply With Quote
Old 01-28-2003, 03:57 PM   #4
Austin's Avatar
Default Re: Rim offset and your alignment...how does it change things? (Big Phat R)
Aha...thanks, that gives a little better understanding into it...also explains why the car is very darty, other than the alignment.
Austin
Old 01-28-2003, 04:24 PM   #5
Big Phat R's Avatar
If your car is too "darty" - have the alignment checked again.
Nitto NT-05s Has anyone tried them? Snafu-Si Wheel and Tire 1 08-27-2014 11:22 AM
15x6.5 38 offset vs 15x7 40 offset yoorang Wheel and Tire 3 03-29-2008 08:53 AM
15x7 rims 205/50-15 tires What Offset? enviousdm Acura Integra 1 04-11-2006 06:42 PM
Which Tire, and Which Size: Azenis RT-615 vs. Toyo T1-R 92integraVTECgsr Wheel and Tire 15 03-11-2006 08:34 AM
205/50-15" azenis on 6" rim teg92 Road Racing / Autocross & Time Attack 24 01-30-2004 12:42 PM
Tags
affect, affects, alignment, allignment, anouther, change, changing, effect, larger, mag, offset, rim, rims, set, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
