Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Removing Painted-On Pinstriping... Any Suggestions?
Old 05-10-2005, 07:29 PM
Catch 22's Avatar
Default Removing Painted-On Pinstriping... Any Suggestions?
So I scored what appears to be an excellent '89 CRX Si shell. No wrecks, no rust, no nothin'. The interior still even looks extremely good and it appears to have the original paint on it (not great, but OK).
But the car is from Oklahoma, and it has a very un-CRX like pinstripe job on it. A pinstripe job that isn't quite subtle and would seem to be more at home on a Ford F-150 Lariat pickup.
I didn't think of it as a big deal until I got it home and actually looked at it closely. Its not your regular pinstriping, its actually painted on the car. And from the looks of it, I'm betting it cost somebody a fair amount of money. Its a very good job, if you like that sort of thing, which I don't.
So, any suggestions on how I might be able to get this off without ruining the paint underneath? Is there a magical product out there for doing such jobs?
TIA
Old 05-10-2005, 07:59 PM
I said I don't want a title!
Todd00's Avatar
Default Re: Removing Painted-On Pinstriping... Any Suggestions? (Catch 22)
Someone once told me that oven cleaner and a firm wax-off technique was good for the painted on stripes. I have never personally tried it though.
Old 05-10-2005, 08:33 PM
DMF
DMF's Avatar
Default Re: Removing Painted-On Pinstriping... Any Suggestions? (Todd00)
I used acetone and lots of elbow grease. Didn't seem to hurt the clear coat. I did this about 5 years ago and you still can't tell.
Old 05-10-2005, 09:03 PM
Want2race's Avatar
Default Re: Removing Painted-On Pinstriping... Any Suggestions? (DMF)
There is a pneumatic tool that removes them. I never had any luck getting it off any other way.
http://www.ai-supply.com/image...b.jpg
Old 05-10-2005, 09:38 PM
thawley's Avatar
Color sand and compound. Or just hire a detailer to do it for you. Surely that doesn't have to count in the $2005 total...
Old 05-11-2005, 12:33 AM
Vandemar's Avatar
Default Re: Removing Painted-On Pinstriping... Any Suggestions? (Want2race)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">There is a pneumatic tool that removes them. I never had any luck getting it off any other way.
http://www.ai-supply.com/image...b.jpg</TD></TR></TABLE>I've had good luck with an eraser wheel for vinyl pinstripes, and the foam adhesive for badges & such (non-Honda stuff), but I wouldn't really expect it to work for painted-on stripes .
Old 05-11-2005, 12:50 AM
jisu009's Avatar
Default Re: Removing Painted-On Pinstriping... Any Suggestions? (Vandemar)
We need pics of the car!
Old 05-11-2005, 02:56 AM
JoelG's Avatar
Default Re: Removing Painted-On Pinstriping... Any Suggestions? (jisu009)
body guys use a razor blade and a steady hand
Old 05-11-2005, 05:37 AM
burnitup's Avatar
yea ive seen the detailers at my work use rubber razor blades to take them off with soap and water i think thats what he was using.
Old 05-11-2005, 07:03 AM
leadfoot321's Avatar
The rubber wheels work well for vinyl tape stripes but will not remove painted stripes.
Chances are you will not be able to remove any painted on pinstripes without ruining the finish underneath. The paint is most likely 1Shot lettering enamel. It is used by many sign painters and pinstripers and is considered the best lettering paint in the industry. It is very durable and I have personally painted several signs with it that are ten years old and still going strong.
Below is a link to the description of the paint:
http://www.1shot.com/Lettering.html
Old 05-11-2005, 10:57 AM
SJR
SJR's Avatar
how about you sand it off, and replace it with a nice Starsky and Hutch white stripe? I think that would be awe-some on a rex. If it's red, of course.
Old 05-11-2005, 11:11 AM
Catch 22's Avatar
Default Re: Removing Painted-On Pinstriping... Any Suggestions? (SJR)
I experimented with a little Acetone... Nada.
This is no BS pinstriping job. Its primo work.
I just happen to hate it.
Old 05-11-2005, 11:41 AM
FormulaIntegra's Avatar
Just get some Krylon of a contrasting color, and spray your own Ghetto Pinstripes over them. Surely a $4 can of spraypaint won't impinge the $2005 budget, will it?
Old 05-11-2005, 05:53 PM
jisu009's Avatar
Default Re: Removing Painted-On Pinstriping... Any Suggestions? (FormulaIntegra)
Pics I say! Humor us....
Old 05-11-2005, 08:10 PM
johng's Avatar
Paint over it.
Old 09-05-2005, 07:36 AM
Catch 22's Avatar
Default Re: Removing Painted-On Pinstriping... Any Suggestions? (johng)
Back from the dead...
Just a little update. 1200 grit rubbing compound is doing the job without damaging the paint. BUT...
It took nearly three hours to do one fender, and I have blisters on 3 fingers of my right hand (I'm hopelessly right handed).
This is just crazy. At this rate, removing the evil Cowboy pinstriping is going to end up being the most labor and time intensive part of this project.
No, I wouldn't have guessed that one correctly.
I'll try to get a pic of this awful pink, green, and blue striping posted later. Right now the camera needs batteries.
Scott, who says "Yes, the car was previously owned by a female in Oklahoma and I'm betting she owns at least one rhinestone denim skirt."
Old 09-05-2005, 07:58 AM
thawley's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Catch 22 &raquo;</TD></TR><TR><TD CLASS="quote">Just a little update. 1200 grit rubbing compound is doing the job without damaging the paint. BUT... It took nearly three hours to do one fender, and I have blisters on 3 fingers of my right hand (I'm hopelessly right handed).
This is just crazy. At this rate, removing the evil Cowboy pinstriping is going to end up being the most labor and time intensive part of this project.</TD></TR></TABLE>
If the striping paint is thick enough, a "run-razor" might save you a little bit of time. And they're pretty cheap, as tools go...
Eastwood sells them: http://eastwood.com/shopping/p...razor
Also might try a sanding pad and some wet/dry 1200 grit paper. Probably be a bit easier on your fingers. Though maybe not as therapeutic.
Old 09-05-2005, 08:25 AM
Catch 22's Avatar
Default Re: Removing Painted-On Pinstriping... Any Suggestions? (thawley)
Thanks John,
I may try the run razor, but I'm not sure if the striping is thick enough for it to work. If it was that thick I doubt I'd be making any headway at all with rubbing compound.
And this whole thing passed therapeutic after about 30 minutes. Now its just frustrating. I tried 1200 grit paper first (wet and dry) but it was scratching the clear coat. The compound isn't damaging the finish on the car at all.
Now, when I'm rubbing, I kind of chant to myself "who... puts... blue and pink... country and western... stripes... on... a... CRX..."
It helps pass the time.
Old 09-05-2005, 08:39 AM
thawley's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Catch 22 &raquo;</TD></TR><TR><TD CLASS="quote">this whole thing passed therapeutic after about 30 minutes. Now its just frustrating.</TD></TR></TABLE>
I can relate. It's amazing how easy it is to get obsessed with **** like that (which does not matter a whit for performance) just because it bugs me. At least you've got the 2006 Challenge Concours points to justify your efforts. I just do it 'cause I'm unbalanced...
Old 09-05-2005, 08:40 AM
california dude's Avatar
use a new razor blade like a scraper, even if you slightly touch the paint you'll be able to rub it out, if you use it like a chisel the chance of cutting is real high.
Old 09-05-2005, 05:29 PM
SpiceyRice's Avatar
Default Re: Removing Painted-On Pinstriping... Any Suggestions? (california dude)
Just paint over the pin-stripe. This is a the GRM budget CRX you're working on right? You're a racer, you shouldn't be trying for concourse points - it's un-natural.
Old 09-05-2005, 05:36 PM
tnord's Avatar
Default Re: Removing Painted-On Pinstriping... Any Suggestions? (SpiceyRice)
mask the area around the pinstripes (you don't have to get right up next to the stripe), wetsand with 1800 or 2000 grit sandpaper and respray it with krylon.
Old 09-05-2005, 05:57 PM
Catch 22's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpiceyRice &raquo;</TD></TR><TR><TD CLASS="quote">Just paint over the pin-stripe. This is a the GRM budget CRX you're working on right? You're a racer, you shouldn't be trying for concourse points - it's un-natural. </TD></TR></TABLE>
I all goes as planned, from a distance of about 20 feet people are going to look at this car and say "there's no way thats a $2006 challenge car."
But, if they know what to look at, when they get close they'll say "Oh... OK."
Old 09-06-2005, 06:52 AM
thawley's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by california dude &raquo;</TD></TR><TR><TD CLASS="quote">use a new razor blade like a scraper, even if you slightly touch the paint you'll be able to rub it out, if you use it like a chisel the chance of cutting is real high.</TD></TR></TABLE>
Scott, did you try this? Did it work? The Dude knows his scrapers, so I was just wondering...
Old 09-06-2005, 06:56 AM
Catch 22's Avatar
Yes, briefly.
I was either not removing striping or scratching paint.
I've never been really good at detail work.
BLKFLSH
36
02-28-2013 07:45 AM
killercrx91
Paint and Body
17
01-23-2009 09:20 AM
Masta
Paint and Body
27
07-02-2007 02:15 PM
Traction
06-07-2004 03:42 PM
Kasper.
07-02-2002 07:26 PM
Quick Reply: Removing Painted-On Pinstriping... Any Suggestions?
