Output for tach on ecu of B18c? - Honda-Tech
Old 09-20-2005, 12:23 AM   #1
apexinghonda's Avatar
Default Output for tach on ecu of B18c?
I searched. Didn't find it. I don't trust any other section on Honda-tech for "technical advice". Trying to put in a autometer big tach. Where do you get your signal? I am assuming the ECU which is what I did with my supra for a shift light. Any help appreciated.
B18c in a CRX Si chassis.
Barry H.
apexinghonda is offline   Reply With Quote
Old 09-20-2005, 04:32 AM   #2
.RJ
.RJ's Avatar
Default Re: Output for tach on ecu of B18c? (apexinghonda)
Is it an OBD1 Engine/ECU? I *belive* the signal is off the distributor.
I have a helms on .pdf that I can send you - drop me an email, rpjenkins@gmail.com
.RJ is offline   Reply With Quote
Old 09-20-2005, 11:22 AM   #3
Default Re: Output for tach on ecu of B18c? (.RJ)
Hey R.J. according to the previous owner the car has a OBD1 Ecu. I also have Hondata (unknown model number) I looked on it to see what outputs it had and "rpm" was not one of them. Any help appreciated. Trying to mount one of those monster tach so that I quit shifting based on how long the tach needle has been pegged at 8,000revs and stopped before I shift.
Barry H.
Old 09-20-2005, 11:25 AM   #4
.RJ
.RJ's Avatar
Drop me an email and I can send you or host a copy of the helms for you.
Old 09-20-2005, 11:53 AM   #5
STN_Pat's Avatar
Is it the same signal as for a shift light ? Got mine from behind the cluster, it's the only green wire !
STN_Pat is offline   Reply With Quote
Old 09-20-2005, 11:57 AM   #6
slammed_93_hatch's Avatar
Default Re: Output for tach on ecu of B18c? (STN_Pat)
for 92-95 civic's i have always heard it is the blue wire attached to nothing in the engine bay in the drivers side right next to the fire wall.
I have seen 2 or 3 tachs hooked up here and they worked
slammed_93_hatch is offline   Reply With Quote
Old 09-20-2005, 12:00 PM   #7
Quote:
Done and thanks. Blue wire, green wire, hell I will cut them all. I think I have another Hondata "box" right under the hood on the driver's side. My car has one of those Kenji wiring harnesses so which wire is which may be a bitch. I am a poet and don't know it.
Barry H.
Old 09-20-2005, 12:17 PM   #8
.RJ
.RJ's Avatar
You got mail
Old 09-20-2005, 06:39 PM   #9
On my 94 GSR there is a blue wire on the firewall area near the master cylinder that is a tach signal. I never looked to see what the one is to the guage cluster since that was so easy to get to and use.
Mohudsolo is offline   Reply With Quote
Tags
89, b18, crx, engine, signal, tach
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
