Lexan/ Plexi Glass replacement hints tips and tricks?
i am buiding a crx and i have seen lexan/plexi done different ways. wondering what some of you consider to be the best? For everythingfrom sealing properly to fitment to what you used to attach the glass?
#1 don't use plexiglass/acrylic use lexan.
here they talk about screws, rivets and lexan
https://honda-tech.com/forums/showth...ighlight=lexan
flexALITE are still pretty heavy, i did my side windows with lexan from home depot, used rivets came out nice....
ive got my rear out now, just gotta get back out there and finish at some point...
We have used Threadserts, Rivets as well as DZUS 1500 Series sliding latches for attaching lexan. It is really nice having removable windows. I prefer the DZUS sliding latches.
I recommend putting weather stripping on the car so that it seals well.
http://fatboyraceworks.com/gallery/v.../LexanWindows/
Oh man i was about to buy a flexalite window package ,, ZUL8, are they really that heavy??
sharp looking car by the way
Re:
anybody got a link for this Flexalite Kit? And what makes it heavier than say just buying lexan and making your own kit? I like countersunk allen head or button head screw with nylon lock nuts. Do you take your windows out that much Rotten that them being removable is worth the extra effort and money for Dzus fastners?
also did your tint not ever bubble on you i have read that you can't tint lexan cause it realeses a gas and will bubble up under regular window tint?
Thanks!, the car has come a long way..I can thank Melissa for the Awesome vinyl job, she hand cut every peice!
you can choose from different thickness at depot. the kits come really thick and its next to the same as glass from what ive heard..
My Name is Nobody
FAL kits are not heavy... I dont know where that came from. There maybe liter options, as you can use thinner material, but when compared to OEM glass there is no comparrison. One of the best dollar to value ratio's. and a back half should only be in the $400 range(obviously home made is cheaper)
i finally got out into the garage last night to finish up the rear window..
heres some pics...
and the water test
i had a lexan sun roof on my first rex, i was suprised at how strong it really was. when i wrecked the car the lexan cracked but not all the way through... good stuff
I used PTEG, its a vacuformable plastic. I obtained a 1/8" sheet for $78. Made my own templates and cut it with a hand held jig saw. During installation I took a heat gun to it where the fitment wasn't perfect. The sides came out great but the rear has a couple of dimples. I didn't have a rear window to take a template off of, with one it could have been perfect.
Best part is that if it gets scratched all I need to do is heat it with the heat gun and it will seal up again.
I haven't tried it on the track yet (still need to get an ECU and tune) so well see if my theory holds.
ExemptedNut
03-29-2009 03:21 PM
vtec_head
07-21-2008 08:15 PM
