Inboard suspension - Honda-Tech
Inboard suspension
Old 08-05-2004, 02:19 PM   #1
Default Inboard suspension
Does anyone know where I can find knuckles, bell cranks and the coil over for inboard doublewishbone setup like this ?
Cause I can't find such thing anywhere.
Thanks.
C-Zero is offline   Reply With Quote
Old 08-05-2004, 02:20 PM   #2
TeamSlowdotOrg's Avatar
Default Re: Inboard suspension (C-Zero)
LOL
Seriously?
TeamSlowdotOrg is offline   Reply With Quote
Old 08-05-2004, 02:22 PM   #3
Default Re: Inboard suspension (TeamSlowdotOrg)
Quote:
Originally Posted by TeamSlowdotOrg
LOL
Seriously?
Serious, inboard suspension on mid engine civic
Old 08-05-2004, 02:26 PM   #4
Greyout's Avatar
its so he can get his car to do this
Why not run down to your local one-stop automotive stop and pick up some aluminum ignots & a copy of autoCAD?
Greyout is offline   Reply With Quote
Old 08-05-2004, 02:29 PM   #5
Default Re: Inboard suspension (Greyout)
Man look if your not going to help me out dont respond please.
Old 08-05-2004, 02:32 PM   #6
JHill's Avatar
You might call these guys:
JHill is offline   Reply With Quote
Old 08-05-2004, 02:36 PM   #7
jisu009's Avatar
Default Re: Inboard suspension (JHill)
jisu009 is offline   Reply With Quote
Old 08-05-2004, 02:36 PM   #8
Thank You.
Anyone one else want to share some info.
Old 08-05-2004, 02:37 PM   #9
jisu009's Avatar
Default Re: Inboard suspension (jisu009)
Good Job Jim...BTW is that a Purple window brace?
Old 08-05-2004, 02:41 PM   #10
J-hill thanks again its exactly what I was looking for.
Old 08-05-2004, 02:41 PM   #11
Tyson's Avatar
its all custom fab. find a shop, have it all forged, machined and welded.
Tyson is offline   Reply With Quote
Old 08-05-2004, 02:42 PM   #12
DsITR's Avatar
bwhaahah
DsITR is offline   Reply With Quote
Old 08-05-2004, 02:42 PM   #13
Default Re: Inboard suspension (Tyson)
Quote:
I think the knuckle/hub piece is sold.
Old 08-05-2004, 03:03 PM   #14
.RJ
.RJ's Avatar
Honestly if you have no experience with this at all, and do not know where to source the components from, then you probably shouldnt be attempting to implement it on a production tub.
If think you will quickly find that it such a design is a very, very poor ROI for a car that just does not need it.
.RJ is offline   Reply With Quote
Old 08-05-2004, 03:06 PM   #15
Angry Joe's Avatar
Unless you have fabrication skills and experience designing suspension geometry, you will not be able to successfully do this. Don't try it.
Angry Joe is offline   Reply With Quote
Old 08-05-2004, 03:09 PM   #16
Default Re: Inboard suspension (.RJ)
Quote:
Did'nt say I was doing it, I just want to know where I can find the parts.
This is not how to do inboard doublewish bone on your civic thread.
Old 08-05-2004, 03:14 PM   #17
Sean O'Gorman's Avatar
Hang on, I think I have some pieces like that on a couple of my Reynard Champ Cars.
Sean O'Gorman is offline   Reply With Quote
Old 08-05-2004, 04:36 PM   #18
Tyson's Avatar
you can go to any open wheel or formula sportscar manufacturer and buy parts separately. such as lola, van diemen or whatever. i guarantee you whatever they sell as replacement parts, is not going to be affordable. any other option is custom fab.
Old 08-05-2004, 05:50 PM   #19
There are different ways to go with that kind of thing. A "true" rocker arm uses a huge arm that literally acts as a teeter-totter with the pivot somewhere between the upright and an inboard mounted coilover unit.
The system in your pics is a "pushrod and bellcrank" affair, with that link running from the bottom of the upright to a pivoted link, then to the coilover. It is also possible to have a pullrod system where that long diagonal rod is in tension - pulling - rather than compression. Some IRL cars use one, some the other but I can't remember which does which.
It's hard to tell but that tub-chassis Honda might use a direct bellcrank set-up, with a bigger version of that little pivoting thingie in the formula car suspensions.
In any case, all of these parts are either (a) expense enough that you would crap your pants to find out how much, or (b) hand made by people who really know how to build stuff. Just the aero-spec rod ends will break a mere mortal.
This is going to generate a lot of mirth out there but you can learn a LOT about how these systems work with LEGO Technic systems. When I taught my junior high robotics class, I modeled both rocker and pushrod suspensions for my kids to play with. You can play with motion ratios, arm lengths and - if you add a link simulating a steering tie rod, you can learn pretty much everything there is to know about bumpsteer.
K
Knestis is offline   Reply With Quote
Old 08-05-2004, 05:52 PM   #20
Default Re: Inboard suspension (Knestis)
K
Old 08-05-2004, 06:20 PM   #21
Johnny Mac's Avatar
None of what you're looking for is off the shelf. Some suspension engineer would have spent many hours on a solid modeling package to come up with a system that would work. Then, each part is CNC machined to his specs. Hence, unless you know someone who might have worked on such a project, then your chances of finding this stuff is very remote at best.
Johnny Mac is offline   Reply With Quote
Old 08-05-2004, 07:09 PM   #22
Banned
Default Re: Inboard suspension (Johnny Mac)
Yup, sorry to join the raining-on-your-dreams parade, but the above is all correct. It's going to be very, very expensive. I made my own front rocker suspension (along with the rest of the car) because I know dang well I can't afford a $100,000 one-off custom Mini.
Oh dang, wait... I have just the place for you: http://www.emachineshop.com/
You download free CAD software, draw up your parts, the sw quotes you a price, you e-mail them the file and they make them on their CNC machines. No kidding... and it'll cost a fortune regardless.
You have to understand too, that fabing it is the easy part... do you have suspension design software? How do you know what to ask for? Do you realize that even if you find someone who has this stuff on the shelf, that it'll work in only one configuration, theirs? What is that configuration? How could you know?
Really, seriously, spend a good solid year reading design books before doing anything... that's what I did.
kb58 is offline   Reply With Quote
Old 08-05-2004, 07:16 PM   #23
Banned
Default Re: Inboard suspension (kb58)
If you want to do a mid-engine car, just transplant the entire FWD drivetrain, suspension and all, into the back of the car. See my website.
Old 08-05-2004, 07:39 PM   #24
Quote:
Thats what I'm doing.
Old 08-05-2004, 08:37 PM   #25
GSpeedR's Avatar
When I taught my junior high robotics class...
Junior high robotics?! Damn I was lucky if I had algebra back in junior high. Damn rich kids and their damn...advanced elementary education...
About custom suspensions, you need modeling software to draw what you want and create an assembly of parts, then import that into a motion simulator (ADAMS) to see how it will work, and then CNC it, and then do it over when you screw the entire thing up cuz you welded two pieces together wrong and the car breaks.
Also, think about what kind of forces/stresses said components will see. FEA and the like would also be a good idea. So how many $1000s is that in just software?
GSpeedR is offline   Reply With Quote
There is a flame shaped black spot in my eye. MidShipCivic General Discussion and Debate 35 04-29-2008 03:47 PM
Dent on piston what to smooth it out with? (picture) MidShipCivic Forced Induction 8 03-16-2008 11:13 PM
90-93 integra spare tire area fuel cell? What fuel cell have you used? MidShipCivic Welding / Fabrication 8 02-12-2008 08:59 AM
Can I still use this block? (4g63) Deck dent. MidShipCivic Forced Induction 25 01-19-2008 02:55 PM
Give me your opinion on a lowered roof cause I like it. MidShipCivic Welding / Fabrication 34 07-10-2005 12:30 AM
Tags
build, cars, coil, coilover, design, geometry, images, inboard, lego, miata, set, simulation, spindle, suspension, system, upright, works
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
