Hub removal and wheel stud replacement with slide hammer - Honda-Tech
Old 08-09-2005, 06:39 AM   #1
bfitz's Avatar
Default Hub removal and wheel stud replacement with slide hammer
First off, this is for an ITR
So, I came away from the Topeka Divisional with a couple broken front wheel studs. I did some searching and found that I need to remove the hub and that I should be able to do that with a slide hammer. Last night, I borrowed a slide hammer from O'Reilly's and went to work. After a lot of banging, I'm so far left with just a sore hand.
Question 1: Is it necessary to remove the rotor from the hub before removing it? I couldn't see any reason why, and the retaining bolts didn't budge with a quick try, so I left them on. (If they do, what's the best way to get these out? It seems a bit odd that they use a phillips head here.)
Question 2: Should it really be this hard to remove the hub with a slide hammer? I maybe moved it 1/16" after all that banging. Any tips?
Thanks,
Brian
bfitz is offline   Reply With Quote
Old 08-09-2005, 06:47 AM   #2
.RJ
.RJ's Avatar
Default Re: Hub removal and wheel stud replacement with slide hammer (bfitz)
Uh oh... you do not want to use a slide hammer for this at all.
Yes you should remove the rotor. You'll need to use an impact driver to get the screws out. If the rotor is stuck, thread some m6 bolts into the other 2 holes and that will force it off the hub without the hassles of pounding on it w/ a hammer.
After that, remove the whole knuckle and take it to a machine shop with a new wheel bearing ($55 from honda, new clip is a few $ also) and say "fix it". These things need to be pressed in and out, and the wheel bearing is a good idea while its apart. I hope all that banging you did did not trash the hub too, as they arent cheap from honda ($150/ea i think).
.RJ is offline   Reply With Quote
Old 08-09-2005, 06:53 AM   #3
thawley's Avatar
Default Re: Hub removal and wheel stud replacement with slide hammer (.RJ)
Quote:
Originally Posted by .RJ
After that, remove the whole knuckle and take it to a machine shop with a new wheel bearing ($55 from honda, new clip is a few $ also) and say "fix it"....
Ditto that. I did it a while ago using a friend's hydraulic press, and that is the only way to go. It's not worth buying your own press for. But it does want a press to be done right...
thawley is offline   Reply With Quote
Old 08-09-2005, 08:24 AM   #4
bfitz's Avatar
So, no-go on the slide hammer... It seemed like a better alternative for getting things done in an evening. The adaper bolts securely to the hub using the 3 remaining studs, and it's pulling straight out, so I don't see why it would damage the hub. The bearing...possibly.
I took a look through the FSM on removing the knuckle. Is the ball-joint removal tool readily available? To avoid stranding my wife any longer than necessary, (I need a third car.) let me know if there's anything else I'll likely need:
1. Phillips bit for impact driver
2. Ball-joint removal tool
3. Wheel bearing and clip
4. M6 bolts to jack rotor
5. New studs and lug nuts (already have these)
Thanks,
Brian
Old 08-09-2005, 08:43 AM   #5
.RJ
.RJ's Avatar
For the balljoints, go to Autozone and find the thing that looks like this:
http://www.harborfreight.com/c...36861
Its about $8. Make sure you loosen, but do not remove the castle nuts - if you take them off, you run the risk of mushrooming the stud and trashing it.
Old 08-09-2005, 12:27 PM   #6
R you serious's Avatar
ive done it before with a slide hammer, its nearly unbearable.
a mini sledge works wonders on the ball joints
R you serious is offline   Reply With Quote
Old 08-09-2005, 12:32 PM   #7
bfitz's Avatar
Default Re: Hub removal and wheel stud replacement with slide hammer (R you serious)
So it's possible How long did it take you to get it off? Did the bearing survive? Were you able to reinstall by impacting the spindle nut?
My fingers still don't feel quite right, and I wasn't even successful.
Brian
Old 08-09-2005, 02:04 PM   #8
i remember it took a long time, you really have to have someone large wailing on that thing to make anysort of progress.
bearing was pressed back on with it as well.
i highly recommend you dont waste your time with this technique
Old 08-09-2005, 02:08 PM   #9
mstewar's Avatar
seriously man, use the press..
mstewar is offline   Reply With Quote
Old 08-09-2005, 04:30 PM   #10
rex_boy's Avatar
Default Re: Hub removal and wheel stud replacement with slide hammer (thawley)
Quote:
I bought a press for $100 at harbor freight and have used it several times.
2 pairs or knukles with wheel bearings and 16 studs.
1 Quaife diff that I took to a machine shop the first time and they put them on backwards.
but serioursly take there advice and have them pressed on.
rex_boy is offline   Reply With Quote
Old 08-09-2005, 04:42 PM   #11
bfitz's Avatar
Default Re: Hub removal and wheel stud replacement with slide hammer (rex_boy)
Ok, I have three ball joints off. How do I remove the knuckle from the drive shaft? The FSM just says to remove it with a plastic hammer...
Brian
Old 08-09-2005, 04:46 PM   #12
.RJ
.RJ's Avatar
Returned your PM
Old 08-09-2005, 05:00 PM   #13
743power's Avatar
I've successfully used "the slide hammer" (dun dun dun) method before. The pinky side of my hand bone was brusied for a week or so, but I was able to do it myself in 2 hours for both sides.
Bearings were fine for another 15k street miles or so, when I had new ones pressed in (with a press) just as preventative maintenance. I gave the guy at the transmission shop $25 and he did both bearings for me. I also asked him to unscrew the dust shields, but I think the screws wouldn't come off because they are certainly still on the knuckles. . .
If you can deal without the car for another day, just pull the knuckles off and bring them to a known competent shop with a press and have it done right.
743power is offline   Reply With Quote
Old 08-09-2005, 05:54 PM   #14
bimmerboodle's Avatar
It is not"you might" but you WILLmushroom the ball joint stud. I have done this and was forced to grind the threads down temporarily till I could replace them. Stoopid ball joints.
bimmerboodle is offline   Reply With Quote
Old 08-09-2005, 08:32 PM   #15
DMF
DMF's Avatar
Default Re: Hub removal and wheel stud replacement with slide hammer (bimmerboodle)
I've used the slide hammer trick twice. I didn't have a problem either time (I think some of you guys need to hit up the gym ) I had them apart in a matter of seconds!
Now the first time I did this was for a car I didn't care about and the second was a last minute attempt to get a car on track (got the hub apart and two studs changed and back together in about 5 minutes, he made it to grid and everything!).
Now for peace of mind, if it were a race car or any car I cared about, and I had more than 5 minutes to get it done, I would get a new bearing and have it done with a press.
DMF is offline   Reply With Quote
Old 08-10-2005, 12:55 AM   #16
LX4CYL's Avatar
Default Re: Hub removal and wheel stud replacement with slide hammer (DMF)
What exactly is wrong with use the slide hammer? I replaced all 4 wheel studs on the front right of my daily driver, using a slide hammer, in under an hour (and it was the first time doing it myself). I glopped on some wheel bearing grease on the bearing inner race, before carefully lining the hub back up with the bearing in the knuckle, then used the spindle nut and an impact wrench to press it back in. Few months later and no probs with the wheel bearing
LX4CYL is offline   Reply With Quote
Front Hub Question WillItFit Honda Fit 0 07-12-2008 08:15 PM
extended lug studs crv-techu Acura Integra 6 06-10-2008 02:51 AM
how do i remove the front wheel hub unit bearing em1mata Honda Civic / Del Sol (1992 - 2000) 1 04-05-2007 11:27 AM
A cut wrist and a few hours later im back to five lug. xmilanoredsix Acura Integra Type-R 1 09-02-2004 06:31 AM
Broken Wheel Stud red_sir Honda Civic / Del Sol (1992 - 2000) 8 11-30-2002 08:31 AM
Tags
2004, 91, accord, bearing, broken, hamer, hammer, hammering, honda, hub, pilot, pull, removal, replace, slide, stud, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
