Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
How to: Replace '95 GSR front wheel studs?
Old 10-29-2002, 09:21 AM
Projected's Avatar
Default How to: Replace '95 GSR front wheel studs?
I need to replace a front wheel lug nut stud on my 1995 GSR. I have taken the caliper and rotor off before. I just purchased a socket to remove the axle nut.
Once I remove the axle nut will the hub come off or will I have to get a puller of some sort? Will this require the replacement of the wheel bearing? Any help is appreciated. Thanks
Old 10-29-2002, 10:13 AM
Jimmy L's Avatar
Default Re: How to: Replace '95 GSR front wheel studs? (Projected)
The best thing to do is pull the steering knuckle and bring it to a machine shop to press out the hub/bearing. You have to seperate the upper and lower ball joints. You can have the machine shop put in the studs. You might as well replace the bearing while your at it. HTH
Old 10-29-2002, 06:47 PM
IMPORTDYNAMICS's Avatar
Default Re: How to: Replace '95 GSR front wheel studs? (Jimmy L)
I have had to replace two fronts on my 98 (dealer) the rears you can do yourself
dadecounty_hxc
06-13-2010 05:28 PM
ewoo
02-24-2009 04:23 PM
jBj
04-17-2007 12:54 PM
tominos
08-27-2003 11:19 AM
tilt
03-02-2003 06:08 PM
Quick Reply: How to: Replace '95 GSR front wheel studs?
