FS: Jan-Mar RACE PARTS ONLY
Moderator
Only post for sale ad's of RACE PARTS
NO WTB
DO NOT REPLY TO A POST.....PM the person....Keep this thread free of banter....just FOR SALE Posts
Must have:
Contact
Location
Price
Chad
NO WTB
Must have:
Contact
Location
Price
Chad
Re: FS: Jan-Mar RACE PARTS ONLY
Stack Electric Oil Pressure Gauge Has been modified to fin it a pod.Comes with pod and oil line for a remote mount of the sending unit. Make offer.
As seen here: http://www.racerpartswholesale.com/p...lectric_Gauges
Braille 11.5 Carbon Fiber Battery
SOLD
Brand New STACK RPM Gauge
SOLD
2006+ Civic Si Mishimoto Radiator & Aluminum Fan Shroud
SOLD
SOLD
SOLD
SOLD
EK, EG, DC Autopower Full Roll Cage, Brand New!! Only opened to fit in the car.........$850
* * *Decided to fork out the money for a full custom cage, picked up only or you arrange shipping
DC5 JDM ITR Header...........$150
RSX Goodridge Stainless steel brakelines, used..........$50
96-98 Civic Seibon carbon hood.....$350
* * I decided to sell the one on the race car, being that I have two.
MOMO Daytona XL BNIB...........$610
Avid Racing K series Ek Motor Mounts......$290obo
BNIB HardRace Front Upper Control Arms EG/DC (Polyurethane, Hard Rubber Version).........$175
Retail is $225 * http://www.specialprojectsms.com/ind...?categoryID=39
RSX rear struts with Progress drop springs, shocks in good shape, no leaks.........$50
Assortment of RSX sway bars:
DC5 Mugen Rear, 25mm......$125
DC5 JDM ITR Rear, 22mm........$75
Hotchkis Front 25.4mm.......$75
JDM ITR Front Sway bar......$50
D16y8 VTEC Head, minus valve cover, Comes with distributor........$90
* * Great for mini me swaps
EK B-series OEM motor mounts........$10ea
99-00 Civic SI Front Lower Subframe and control arms......$50
* * These are beefier than the normal 96-00 Civic's. Better control and stability, faster turn in. Comes with power steering rack.
EK sedan complete doors, windows and door cards.....$100ea
Complete 98 Civic OBD2 Engine Harness ready for B series:..........$100obo
OBD1 Virgin P28......$80
OBD1 P75 (Integra LS)......$40
EK sedan trunk lid.....$75
Ebay steering wheel and quick release.....$75
Carbon "wanna be" mirrors.....$35
Camera Mount for Roll Cage/Bar. Great condition, and utilizes a Bogen mount with quick release settings (Probably the same as Autopower/Ioport). Clamps are able to accommodate tubing diameters of up to 1 5/8". The vibration isolater is red, but I just applied black tape over it to make it look cleaner. Tape can easily be removed. I am looking for $75 Shipped to the lower 48 states.
FOR SALE - 2003 EP3 K20A3 engine built to H2 spec low miles !!! Strong engine guaranteed !!!
I have the reciept for the engine when I bought it to rebuild for Honda Challenge H2. Engine is complete and runs great with only 4 weekends on it.No smoke,no oil burn/consumption.Low miles on rings,Bearings looked fantastic upon recent inspection.Dyno tuned at church's to 188hp and baselined at Bisimito 174hp/143tq; will easily make 165-170whp dynojet with a decent header and a good tune.
Honda factory bottom end parts,stock pistons,cams and rotating assembly unmodified. Cylinder head is a sweet portflow K20A3 head matchported to the honda gasket,with a valve job,resurface/mill and Honda Civic SI K20Z3 single springs and retainers.
-Has NO Intake manifold/tb,No oil pump(does have chain hanging ready for a2 pump),no thermostat housing,no crank sensor,no coilpacks or knock sensor. I can install a new pump at request.
-Comes with 50*vtc,cam sensors,stock crank pulley,stock water pump,stock metal pan,gold metallic painted valve cover,vtec solenoid etc.
Asking $1400 OBO
Pick up,Delivery,Shipping can all be setup at buyer's expense. Motor located in SO CAL.
PM me for contact info if you are serious.
Asking $1400 OBO
i have a built b20/gsr its two days old still in my ef. you can come see and drive the motor,comp test etc. i can even video tape it. i come on hard times and need cash for lawyer pm if interested i will hook it up. 1400 plus shipping. heres the build.
84mm b20 block
decked and honed bye a sunnen
fully ballanced
gsr crank
i beam lightweight rods
acl bearings
13:1 weisco debbured teflon coated forged pistons
portflow ported b16 head
arp head studs
new vtec oil pump
endyne lsvtec kit
skunk 2 valves
serdi 5angle valve job
brian crower stage 2 cams
brian crower springs titanium retainers
supertech teflon valve seals
aem cam gears
cometic head gasket
all new gaskets
84mm b20 block
fully ballanced
gsr crank
acl bearings
arp head studs
new vtec oil pump
endyne lsvtec kit
skunk 2 valves
aem cam gears
cometic head gasket
all new gaskets
FS:
H22/H23 JE Forged 11.0:1 Pistons Part #:220992. BNIB, have original work order. *Includes JE Pro Seal ring set, the rings are out of the plastic packaging since I was going to have the rotating assembly balanced, but are NOT filed. $400 shipped.
Contact:PM me
Contact:PM me
FS:
Usdm Itr complete 5lug- $1200 New front and rear hub bearings,extended wheel studs all around,new front rotors,new front twin piston calipers(legend),new ebc green stuff pads all 0 Miles.
Ek/eg/dc 24mm Rear sway bar $150 shipped w/brackets and bushing,adjistable endlinks
SRR Ek LCA- $150 Shipped painted black w/ spherical bushings.
2 - B series oil pans. From b18a... $15 each
Crx Energy Suspension kit left overs - Transmission mounts, Lower control arm shock mounts, and Rear Control Arm Pivot Bushings = $40
12" SPAL Radiator Fan - $50 (Retails for $197)
88-91 Civic/CRX Spoon Sports Lower Brace. BNIB (Missing Brackets) $70 ($220 new)
OEM Map Sensor = $25
STR cam cap (Red) B16 = $10 obo
OEM B16 Valve Springs = $60 ($120 new)
Golden Eagle Dowl Pins B16 w/ tapping tool = $5
62mm integra throttle body (b18a,b) = $15
Turbonetics Racegate Wastegate Springs/Flange (3-5lbs, 5-7lbs, 7-9lbs) $5
Summit Racing Black Face Digital Oil Pressure Gauge w/ Sending unit BNIB = $30 ($50 Retail total)
b16 Thermostat housing and thermostat = $15
Synapse BOV Stainless Steel Flange = $5
Jeg's T-Bolt's 2-2.5" and 1- 1.75" = $3 each
88-89 Crx Gauge Cluster, missing fuel needle. Works Perfectly w/ Auto Glo Face installed = $15
If you have any more questions or need pics please email me...
Swift Premium Race spring 2.25" ID 7" long 60 mm.. Three set of different spring rates. The 20kg and 18kg are new but 16kg has less than 500 miles on them. Great for upgrading your coilovers with stiffer rates for the track. $375 shipped for all 3 sets. Located in Sacramento, CA.
brand new corbeau race seat
never used
chris
pick up in person only (will not ship) in mt. prospect, IL (near o'hare/chicago)
sale pending pick up tonight
chris
b16/typer victor intake manifold in great shape. it has been port matched and ported for 75mm tb bye tony palo at t1 race development. it comes with aem fuel rail and b@m fuel pressure regulator.
290.00 shipped for all of it!!
i will sand blast intake for 15 dollars more
offers and questions welcome.
call anytime 5757493103 rocky
JDM Itr Clock delete In perfect condition. $20 Shipped
Auto Meter 2 5/8 Guages. Come w/ everting you see on them. $40 shipped each
Water temp
Water temp
1999 b16a2 vtec head. this head has 0 street miles and 8 pulls. the bottom end had issues so im parting it out. the head has just been freshened up. the head comes with the valve cover pictured and has -10an fittings welded to it. and stock b16a2 cams. theres no stripped holes!! CAMS and JOURNALS look brand new. head doesnt not have a lot of original miles and has NOT been rebuilt a million times like other heads for sale..this is a nice piece!
offers and questions welcome same day response.
im asking 350.00 shipped and i paypal fees.
garage sale thread check it...
http://www.hondamarketplace.com/show...7#post44434407
****Shocks are sold****
For sale set of Koni Yellow Race valved shocks with Koni sleeves for EF Civic/CRX 89-91. Bought them new 02/2010 and they are in excellent shape. About 140 auto-x runs and 5000 highway miles from coming and going to events.
Price: $700
Price: $700
QA1 Springs for sale or trade.
2.5 ID
7" Length
Pair of 550 lbs. On Hold
Pair of 450 lbs. Available
Same as these pics.
$50/pair.
2.5 ID
7" Length
Same as these pics.
$50/pair.
I started making this but have something else now. So am selling this.
Using a PDA Windows phone, a GPS receiver, and a racing program (RaceChrono) it makes a nice little entry level kit.
The program records track layouts so you can see the track and replay your laps real time, lap times, sector times, and more.
Included is:
-Palm Treo 700W (+ 2 spares)
-Treo USB hookup (Brand new never used)
-Charger and spare battery.
-Holux GPSlim 236 Receiver
-Holux charger
-Brand new never used roof mount antenna for the receiver. (Sticky bottom unused, mounts on roof or anywhere else)
If you're looking to get lap times and data for little cost this is for you. I have not used this, so you will need to put the program on the Palm and all that, I can't guarantee anything EXCEPT the condition of the items. The phone is like new, holds a VERY strong charge, no cracks, etc. Everything else is in like new condition as well.
Either way it's win win.
Asking $80 OBO. Make an offer.
Free shipping anywhere in the US through USPS.
Included is:
-Holux charger
