Clarification for Stock Class Category G Rules
Anyone here Auto-Cross in the Greater Los Angeles area? I'd really like to get some people together so we can practice before season. Also, since I'm new to SCCA Auto-X I have a couple questions. I ordered the rulebook and some of the rules still confuse me. So, my question is can you guys clarify the exact rules on Stock Class Category G for me? It would be really helpful.
Thanks
Stock Class Category G for a 1995 Acura Integra GS-R
1.1 Bodywork
I can't have anything like aftermarket wings, sideskirts, lips, bumpers, rear bumpers, sideskirts, etc.?
1.2 Tires
Tires are run on 195/55VR15 Yokohama ESV 100 Tires
1.3 Wheels
Wheels have to be stock size running on 195/55VR15 size tires?
1.4 Shock Absorbers
Aftermarket shock absorbers may be used as long as they cannot have more than two adjustment settings...does this mean that I cannot use coilovers because you can adjust three settings on them. Basically I have to run a stock shock absorber system?
1.5 Brakes
Stock brake system but, aftermarket pads may be used.
1.6 Sway Bars
Stock rear and front sway bars?
1.7 Suspension
Stock suspension system no modification?
1.8 Electrical
Stock electrical system...no messing with the ECU?
1.9 Engine and Drive Train
-Will replace stock air filter with K&N Filter
-You cannot port and polish the head?
-Aftermarket exhaust can be applied from the catalytic converter down?
-What are water expansion and oil catch tanks?
-What are scattershields?
-What are silicone hose replacements?
Thanks
1.1 Bodywork
1.2 Tires
1.3 Wheels
1.4 Shock Absorbers
1.5 Brakes
1.6 Sway Bars
1.7 Suspension
1.8 Electrical
Re: Clarification for Stock Class Category G Rules (super_mut)
1.1 Bodywork
Correct
1.2 Tires
You can run any DOT stamped tire that fits on a stock size wheel and fits within the fender.
1.3 Wheels
Stock size wheels only. 0.25" offset difference allowed.
1.4 Shock Absorbers
Stock type/style shocks. Same length, spring perch height, etc. Off-the-sheflt Koni, Bilstein, etc are usually ok.
1.5 Brakes
Correct. May use aftermarket fluid as well.
1.6 Sway Bars
Front bar may be changed/added. Rear must be stock
1.7 Suspension
Springs OEM. Shocks see above. Control arms, etc stock
1.8 Electrical
Correct
Correct
Correct
Overflow tank for radiator, etc. Don't worry about them.
Shield placed around bellhousing to protecet driver if flywheel blows up. Usually added to higher power RWD cars, but can be added to FWD too. Don't worry about it.
Correct
1.2 Tires
1.3 Wheels
1.4 Shock Absorbers
1.5 Brakes
1.6 Sway Bars
1.7 Suspension
1.8 Electrical
Correct
Correct
Correct
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by super_mut »</TD></TR><TR><TD CLASS="quote">Anyone here Auto-Cross in the Greater Los Angeles area? I'd really like to get some people together so we can practice before season. Also, since I'm new to SCCA Auto-X I have a couple questions. I ordered the rulebook and some of the rules still confuse me. So, my question is can you guys clarify the exact rules on Stock Class Category G for me? It would be really helpful.
Thanks
1.1 Bodywork
1.2 Tires
1.3 Wheels
1.4 Shock Absorbers
1.5 Brakes
1.6 Sway Bars
1.7 Suspension
1.8 Electrical
as far as I know..only major components you can change are:
shocks (can't effect height of car) you CANNOT change the springs nor their rates..therefore, no coilovers
FRONT swaybar..can't touch the rear
exhaust from catback
rims must be same width, diameter, and offset (offset is to a certain degree...dunno what that is)
can run any size tires you feel like
any brake pads or fluid you feel like
rest of the stuff you can't change...not sure about body kits...as long as it's nonfunctional i'm guessing it'll be fine
edit: someone already answered
Thanks
1.1 Bodywork
1.2 Tires
1.3 Wheels
1.4 Shock Absorbers
1.5 Brakes
1.6 Sway Bars
1.7 Suspension
1.8 Electrical
Re: Clarification for Stock Class Category G Rules (azian21485)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by azian21485 »</TD></TR><TR><TD CLASS="quote">not sure about body kits...as long as it's nonfunctional i'm guessing it'll be fine</TD></TR></TABLE>
They're not legal---- but if you're not competitive, and not national, I'm guessing no one will protest.
-Chris
-Chris
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by super_mut »</TD></TR><TR><TD CLASS="quote">Anyone here Auto-Cross in the Greater Los Angeles area? I'd really like to get some people together so we can practice before season.</TD></TR></TABLE>
The season has already begun. We had 2 events already. What practice are you talking about?
http://www.solo2.com, click on "calendar" link.
RiceRocket
01-14-2002 10:45 AM
