AC remaval, evaporator case replacement?
I am mostly finished with the removal of the ac system, but am not sure what to do about the evaporator. I pulled it out, but now it seems as though I won't have use of the heat. And I wan't to keep the heater. Should
I just gut the evap case, or is there a part I can buy, I searched here but cant find a non-ac part.
http://www.hondaautomotiveparts.com/...+UNIT+%28DX%29
Re: AC remaval, evaporator case replacement? (smokin rubber)
Yes, you replace it with a heater blower duct for a non-A/C model.
Part #11 from here:
http://www.hondaautomotiveparts.com/...=HEATER+BLOWER
Part #11 from here:
Re: AC remaval, evaporator case replacement? (urbanlegend21)
you can also remove the evaporater from the box and rivet some aluminum over the holes in the outside of the box, thats what i did
[QUOTEI always wondered where the squirrels went......[/QUOTE]
I always thought there were at least 5 squirrels, they must be on roids or somthing.
Re: AC remaval, evaporator case replacement? (sackdz)
[QUOTE]Yes, you replace it with a heater blower duct for a non-A/C model.
[\QUOTE]
In addition, when you install it, I would suggest putting a screen over the side of that heating duct...the furthest away from the blower. Otherwise, it will blow tiny things like seeds from trees and little crap in your face when you turn the blower on high.
Ask me how I now...
Jonna ~ who recently removed sleet pieces from face that had fallen in the hood cowl and down to the blower.
[\QUOTE]
Ask me how I now...
Draggin99Si
12-29-2006 05:36 PM
