4door handinling
4door handinling
HEllo my name is Rudy I have 98 lx ek sedan i signed up for etown road coarse for 2014 and I honestly would like feedback and opnion from senior drivers so that i make any neccesary change a freiend of mine said my car is to low and will spin out:
Mods:
motor
b18b1
tranny
b16 sir
front and rear strut bar
Skunk 2 suspension (raised to maximum recommended height by skunk 2 but can go higher)
i was offered a set of tien flex suspension from a friend
gsr 15x6.65 wheel
195/55/15 tires
plan on purchasing:
stock type r lsd
front rear camber kit
a set of 9ul 15x8 et36
205 50 15 falken azenis
rear sway bar
hopefully by ssummer upgrade to gsr brakes all around( currently stock) and swap out the motor for a b20v swap or turbo the ls
all comment welcome and yes i did search around. thanks
Mods:
motor
b18b1
tranny
b16 sir
gsr 15x6.65 wheel
195/55/15 tires
plan on purchasing:
stock type r lsd
rear sway bar
Re: 4door handinling
Your brake pads will be most important aside from the tires. I wouldn't worry about all the other stuff just yet until you have a good hands on experience on what the car is doing or not doing for that matter.
"too low and will spin out" doesn't make any sense at all...
Make sure the car is mechanically sound and add fresh brake fluid/pads. You should be good to go for your first time on track.
I also just changed my brake on saturday to hawk hps pads with blank rotors and made a lil modification to my shifter i feel like it helps be shift better.will post pic
correct me if im wrong but i was told you want your control arm to be leveled and that is your optimal height
Yep, typically the first time on track you'll be using way more brake than you actually need... going to a more heat tolerant pad will be a big help and having fresh fluid is a nice safety net as well. No need to go and drop the coin on Motul or the high end fluids... just grab some Valvoline SynPower or Castrol LMA. Should be fine.
sirlaughsalot
Suspension & Brakes
56
08-20-2009 12:27 PM
whole9
11
05-12-2006 09:10 AM
sol2nr
09-19-2004 07:18 PM
hatchy
06-11-2002 01:37 PM
