replacing roof on 88-91 sedan questions.
Well i've got a new roof from the junk yard, i just need to pull the skin off and transfer it over. Should I rent a spot welder? or Mig it back on and use seem sealer? Or is it possible to just use rivits? i also have the spot weld remover bit.
spot welder?
spot welder?
Re: (Pockets)
the spot welder isnt going to help you once you drill out the spot welds on the used roof, unless you do it from back side. I would drill them out from the back and use the spot welder you will get a much better and more professional job. then seam seal the roof. The panel bonding adhesive I would not use on the roof. There is a reason it was welded on from the factory. You want to make it just like it was OEM or a little stronger.
