repairing rear subframe control arm mounts?
got into a hit and run and I only have liability so I'm paying to fix my 2004 honda civic myself. My rear drivers side wheel smacked a concrete barrier and pushed the wheel inwards and the only damage I see is the subframe mount for the control arm (only the mounting portion) and the other mount that goes to the unibody where the real thick tube like part of the control arm bolts down to. I took the entire wheel assembly off and bent these two mount points back. Probably not 100% straight but wondering if you guys have done this repair before and if I should take it to a body shop to get it perfectly aligned? or any suggestions.
Re: repairing rear subframe control arm mounts?
Pictures would help other members give more accurate advice. I cracked my rear subframe mount and a shop installed a new one and the Crx passed alignment. This was back in 2000 the shop charged 800 in labor. Couldn't even tell it was in an accident.
Mr. JDM-GSR
05-06-2004 06:30 PM
