quick primer question?...
After primering the car, I cant seem to find sealant in spray can form, is there another alternative I cause for sealant for the primer? clear lacquer or adhesion promoter possibly? or should redo it over and use a primer/sealer and continue from there?
Re: quick primer question?... (VTECth1s)
Your post/ questions are very confusing. If you want decent results on a complete, stay away from the rattle cans, especially with the priming step. If you don't intend to prep and paint a complete right after priming, don't even start the job, kind of going in a backward direction. In most situations if a job is prepped properly after priming its ready for paint, sealing over primer is a waste. Most paint systems the sealer i just the primer thinned out w/ reducer.
