Quarter Panel replacement
Old 12-13-2010, 10:12 PM
jasoncrashtech's Avatar
Default Quarter Panel replacement
i have read a lot of threads on rust problems and damaged quarter panels, so i took some pic's of a recent car i had to fix hoping it might answer some questions ht members have or will soon have.
you will need to take the tire off and load the suspension. uni-body design is strong but it's a rule of thumb so the car sits even. cover everything with welding blankets and remove interior that's in danger or in the way.
this quarter took a good amount of pressure. the door opens and shuts fine but the door gap is badly distorted.
the quarter panel i'm getting will be coming from a wrecking yard. it's in good shape.
the outer wheel house curled in from the hit. it will need to be pulled re shaped with a hammer and dolly before the new quarter goes on.
this is small reinforcement piece that is bonded behind the quarter with a non structural foam. it will be cleaned and a new bead of foam will be applied before the quarter goes on.
when you are using a used quarter panel (lkq quarter panel) you need to drill the spot welds out cleanly and use a small chisel get the panel free. it won't take much to break it loose so be careful.
i always use weld though primer on the back side of the flange after i clean the part.
with the old quarter out of the way i lay the lkq quarter in it's place. line it up were it needs to be. observe the surrounding panels and so on. with the lkq panel overlapping the splice sections, make your cut.
the piece in my hand will be my sleeve. (it's used as a backing plate when you weld the new quarter on)
clean the burrs on the metal, remove the paint on the outside of the sleeve, apply weld through primer to the sleeve, about a 1/4 inch or less above the cut line use a hole punch or a drill so you can weld the sleeve in place but don't damage the panel.
the wheel house is straightened out and all welding area's have been coated with weld through primer but before a single weld is made i will test fit the tailight bumper and check the gap and bodylines with the door. the bead of foam was also applied for the brace that runs behind the quarter
everything looked good so in the wheel house of the quarter panel i layed down a thick bead of metal bond and i started welding where i needed.
some duraglass on the welded sections, followed by some minor body work, prime then paint.
use body wax in as many area's you can reach when your done with paint. do not use before paint, do not use before welding , it's flammable. put a good layer in this area especially
hope this helps some of you guys out. i skimmed through a lot like seam sealing, tools and so on but i hope it's some good basic info that ht members can make use of.
Old 12-15-2010, 05:03 PM
sc34dc4's Avatar
Default Re: Quarter Panel replacement
I had to replace the pass. 1/4 on my integra cause it bought it wrecked for cheap and a friend gave me the 1/4 off an auction car he bought for the swap. After having to drill out the spot welds on both 1/4's I was like damn. It was a lot of work to do it right but worth it in the end I guess. Panel adhesive and seam sealer are your friends for sure.
Great job man.
Old 12-18-2010, 03:25 PM
jcdimvic's Avatar
Great job man!!
Old 12-18-2010, 05:55 PM
DVDr's Avatar
Thanks for sharing, great job.
Old 12-18-2010, 07:27 PM
prelude1897's Avatar
Great work...
Old 12-19-2010, 07:03 AM
1991civicsi's Avatar
Old 12-21-2010, 10:15 AM
gsl_05's Avatar
Great info meng. I will be using this as a guide when I weld in my used 1/4's for my EF.
Old 12-23-2010, 03:40 PM
i'm glad that i can help
Old 12-27-2010, 05:49 AM
Hawkze_2.3's Avatar
Very helpful, thanks for posting!
Old 12-29-2010, 06:21 AM
alwaysfidgeting's Avatar
Thanks for sharing, GREAT JOB!!!!!.
Old 12-30-2010, 10:33 AM
92egvx's Avatar
very helpful and handing to have info like this thanks man...i'm actually thinking about doing autobody and collision work too so thanks
Old 12-30-2010, 12:30 PM
it's better to keep it as a hobby imo. shop owners , crappy estimates and so on can take a toll on the hobby you love but good luck if thats what you want to do .
Old 12-30-2010, 12:35 PM
dem0nk1d's Avatar
Now did you mig weld the seam back together and then grind smooth?
Old 12-30-2010, 03:41 PM
Originally Posted by dem0nk1d
[IMG]
ya, on a prevous picture i cut a section out that wasn't needed and used that for a backing plate. in the industry it's called a sleeve. the quarter gets cut to length when you lay the new quarter over it and cut.
but yes on sail panels and rockers you mig weld them in and grind the extra metal off
Old 12-30-2010, 08:28 PM
dem0nk1d's Avatar
what do you think when body shops use braising rod to do the same thing? doesn't this create way too much heat vs the mig? with the mig you can do a tac weld move over an inch let it cool then keep doing it over and over, to keep warping down... also I've noticed that the braising weld wasn't nearly as strong..
Old 01-01-2011, 04:56 PM
i don't have any experience with shops insisting on braising quarter panel replacements. toyota does recommend to braise on there cars in the areas where they use the material but its always a very small amount around the back glass corner or a door skin etc.
it doesn't make sense to use the material thought. my opinion is simple and basic, get the panel in the right spot, make good welds, protect against corrosion as much as possible, and put everything back together properly so the customer is confident in there car again.
shops might have a different opinion and business practice then me though.
Old 02-10-2013, 09:00 AM
soon i will do one of these for a door skin.
Old 02-10-2013, 05:44 PM
Racko40's Avatar
Well done man, thats the proper way to replace an LKQ quarter panel.
And i hope all bodymen out there get the deserved Hrs/pay to do it this way.
Old 02-11-2013, 08:19 AM
dderolph's Avatar
I gather the original post here originally contained photos. Now, no photos. Without them, the value of this discussion is greatly diminished. What happened to the photos? Can they be restored?
Old 02-12-2013, 06:25 PM
photo's work fine for me and they are still in my bucket account
Old 02-13-2013, 08:01 AM
dderolph's Avatar
OK, I've been using the Opera browser and, for some reason, it does not display the photos. So, I tried using Internet Explorer and saw them. I'll have to investigate why Opera is doing this.
Edit: I found out that the problem with photobucket affected many web surfers, not only those using Opera but those using the Chrome browser and perhaps Firefox. Since first posting this message, the problem has resolved for me. Apparently, photobucket has made a fix; they were getting many complaints on their user forum.
Old 02-19-2013, 01:33 PM
Rukusmasta2's Avatar
good job man
Old 03-08-2013, 07:54 PM
Originally Posted by Rukusmasta2
good job man
Thank you sir and thank you to everyone that likes the info!
Old 02-08-2014, 09:46 PM
no one wants to hear the truth
cetcivic's Avatar
good stuff
c 2
04-29-2007 07:52 AM
msgboardking
01-02-2007 09:11 AM
itr2401
10-27-2002 06:46 PM
JunkeeCrx
06-25-2002 12:07 PM
onyx00
09-05-2001 12:44 PM
Quick Reply: Quarter Panel replacement
