How to pull fenders?? not roll, pull.. - Honda-Tech
Old 07-21-2007, 05:38 PM   #1
nfinitecc's Avatar
Default How to pull fenders?? not roll, pull..
Is it as simple it sounds, you just grab pull? or actually loosen and jack your body lines all up, tryin to fit 15x8 -0 on an EM1
nfinitecc is offline   Reply With Quote
Old 07-22-2007, 12:36 PM   #2
nfinitecc's Avatar
Default Re: How to pull fenders?? not roll, pull.. (nfinitecc)
bump for advice
Old 07-22-2007, 07:00 PM   #3
sc4dr's Avatar
Have you tryed fitting them first?
sc4dr is offline   Reply With Quote
Old 07-23-2007, 05:16 PM   #4
I dont get it, what are you trying to pull. Is there a dent to pull or are you trying to pull the fender off the car, what do you mean?
Old 07-23-2007, 06:17 PM   #5
Bailhatch's Avatar
Default Re: How to pull fenders?? not roll, pull.. ("00"R)
he means stretching the fender arch away from the body to fit his wheels.
I just rolled and stretched the rear fenders on my 93 hatch. I just used a small hammer and slowly worked the lip up into the inner fendre. Then I just kept hammering the folded lip out and pulled it out about 1/4". I did all this on bare metal while replacing the fenders. The trick to making it look right, is to run your hand over it after every few taps so make sure you are keeping it smooth. I would not try it with paint that you want to keep on the car.
Bailhatch is offline   Reply With Quote
Old 07-23-2007, 08:10 PM   #6
memoryFAB.com representative
Default Re: How to pull fenders?? not roll, pull.. (Bailhatch)
i infact have some missing pieces of paint in the rear from doing this to fast.. you have to be careful.. and i now need new rear fenders
spock_rocker is offline   Reply With Quote
Old 07-24-2007, 12:36 PM   #7
Bailhatch's Avatar
Default Re: How to pull fenders?? not roll, pull.. (spock_rocker)
when people try and roll or pull with good paint it is recomended (not by me haha) to warm the panel up with a heat gun to let the paint flex more easily. Just what I have heard but I still wouldn't try it.
Old 07-25-2007, 12:01 PM   #8
honda.parts.dude's Avatar
I rolled the rears on my 95 civic coupe. did it with a plain hammer using light taps. Luckily I didnt have any problems with the paint!!!
honda.parts.dude is offline   Reply With Quote
Old 07-25-2007, 04:35 PM   #9
nfinitecc's Avatar
yea i ordered an eastwood roller so hopefully i can push the fenders out enough to do the trick. thanks guys
Old 07-25-2007, 07:30 PM   #10
Bailhatch's Avatar
thats cheating!
I bet it works well though... you ever see the ones made from 'widowmaker' VW jacks?
Old 07-25-2007, 07:32 PM   #11
sc4dr's Avatar
Are you talking about fenders or quarter panels? If it's a quarter panel, use a body hammer and tap the pinch weld up into the wheel opening. Take your time like bailhatch said and you'll be fine.
Old 07-25-2007, 08:44 PM   #12
Quote:
I got one of those too....works so good, i love it...as for paint..use a heat gun and kinda heat up the areas so the paint doesn't chip off
vsmhatched is offline   Reply With Quote
Old 07-25-2007, 11:41 PM   #13
aleks77's Avatar
how much is that roller, and also whats the max you can pull a fender, WITH bodywork, is an 1" or 2"s possible? I know it will cave in, but thats where bondo comes in!
aleks77 is offline   Reply With Quote
Old 07-28-2007, 01:48 AM   #14
Simple_Sauce's Avatar
Default Re: (aleks77)
You can rent fender rollers like that for as low as $50 a day.
Simple_Sauce is offline   Reply With Quote
pulling headliner from civic hatch EFSiR Honda CRX / EF Civic (1988 - 1991) 13 04-30-2008 06:14 PM
civic fan push or pull mikegeezy Honda Civic / Del Sol (1992 - 2000) 4 02-29-2008 06:52 PM
FORD - How to pull the CEL? IntegraGSR23 General Discussion and Debate 8 01-15-2004 04:40 PM
got pulled over help! LuderCriS Honda Prelude 8 02-28-2002 06:55 PM
how to pull codes?? sydag5 Honda Civic / Del Sol (1992 - 2000) 6 01-08-2002 08:22 PM
Tags
99, ek, fender, fenders, honda, pinch, price, pull, roll, rolled, rolling, slight, stretching, vw, welds
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
