sanding and primering
Old 01-07-2008, 09:00 PM
h4rrison's Avatar
Default sanding and primering
close
Modified by h4rrison at 12:52 AM 1/10/2008
Old 01-07-2008, 09:12 PM
msinsky14's Avatar
Default Re: sanding and primering (h4rrison)
yes. if u dont the paint will peel off, or mabe even run down the lip ur painting before it even adheres. if u dont want to primer, but u should, u can just scufff it with a 3m red scuffing pad and clean it with wax/grease remover. but at that point u might as well just spray some cheapoxy primer after scuffing and lay the paint on right over it
Old 01-07-2008, 09:29 PM
h4rrison's Avatar
Default Re: sanding and primering (msinsky14)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by msinsky14 &raquo;</TD></TR><TR><TD CLASS="quote">yes. if u dont the paint will peel off, or mabe even run down the lip ur painting before it even adheres. if u dont want to primer, but u should, u can just scufff it with a 3m red scuffing pad and clean it with wax/grease remover. but at that point u might as well just spray some cheapoxy primer after scuffing and lay the paint on right over it</TD></TR></TABLE> yeah i only got enough for like the coat and paint. ill probably sand it with 600grit then apply paint.
nukedawhales
12-16-2006 12:15 PM
rota power
11-19-2005 10:58 PM
sjteg
07-29-2005 03:12 PM
pphan3
03-20-2004 06:24 PM
civicboy95
09-08-2002 05:26 PM
Quick Reply: sanding and primering
