Flaring out the fenders and 1/4 panels
Old 04-19-2007, 10:26 PM
aleks77's Avatar
Default Flaring out the fenders and 1/4 panels
I want to run wider rims/tires on all 4 corners, mostly for show, dont flame my question is what is a good way of flaring out the fenders, i only need about 1.1" extra, so the new rims fit and not rub, im not gonna do the work myself but would like to hear some ideas as to how to do this, weld new sheet metal and then shape it, bondo it smooth? THanks!
Old 04-19-2007, 10:59 PM
John M's Avatar
Default Re: Flaring out the fenders and 1/4 panels (aleks77)
what kinda car?
Old 04-20-2007, 03:24 PM
Lucky-13's Avatar
Default Re: Flaring out the fenders and 1/4 panels (John M)
just roll the fender with a baseball bat.....
you just place the bat inbetween the tire and fender, and roll the car back and fourth while someone is holding the bat in place, you have to roll it back and fourth a few times to see progress, but alot cheaper than getting them professionally rolled.
Old 04-20-2007, 03:58 PM
John M's Avatar
Default Re: Flaring out the fenders and 1/4 panels (YoUvegOtMaiL)
He is wanting to add a flare to the fender like im guessing you can rivit a premade flare on and go back and cut the metal under the flare out.
Old 04-20-2007, 07:04 PM
aleks77's Avatar
its a CB7, 90-93 accord. And yes i want flared fenders, not just rolled, i need 1" extra added, but dont want it to look out of place, want it to look as oem as possible.
Old 04-20-2007, 08:13 PM
kiddcarbuff's Avatar
make some templates out of cardboard then get those fitting how u like, copy the patter onto sheet metal. hammer dolley. test, hammer some more, test, weld on fiberglass in. basically howd i would approach it
Old 04-20-2007, 08:15 PM
John M's Avatar
Default Re: (kiddcarbuff)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kiddcarbuff &raquo;</TD></TR><TR><TD CLASS="quote">make some templates out of cardboard then get those fitting how u like, copy the patter onto sheet metal. hammer dolley. test, hammer some more, test, weld on fiberglass in. basically howd i would approach it</TD></TR></TABLE>
Old 04-21-2007, 09:41 AM
GarageAlchemist
Guest
Posts: n/a
Default Re: (John M)
any more info on this ?
Old 04-25-2007, 11:38 PM
aleks77's Avatar
TTT
Old 04-26-2007, 06:59 AM
B_CRUZ!'s Avatar
you need a heat gun and a fender roller. You can gain a good uniformed inch with a fender roller and still have it looking OE.
Old 04-27-2007, 11:43 PM
EKFerioHawaii's Avatar
Default Re: Flaring out the fenders and 1/4 panels (B_Cruz)
Check out vipstylecars.com
They have tons of rolling and pulling fender topics.
Only thing you have to become a member to search.
Awluiz
02-11-2013 10:40 AM
dlstech
Paint and Body
11
03-04-2012 06:29 PM
Hella_Fresh
03-10-2007 01:31 AM
maldini76
03-18-2005 04:00 PM
goowakjai
03-12-2005 05:38 PM
Quick Reply: Flaring out the fenders and 1/4 panels
