Dry ice/Hair dryer and CO2 dent removal
Old 02-03-2009, 08:42 PM
ABK
ABK's Avatar
Default Dry ice/Hair dryer and CO2 dent removal
Did anybody try using any of these methods to remove small dents on a car?
Old 02-03-2009, 08:56 PM
eklum's Avatar
Default Re: Dry ice/Hair dryer and CO2 dent removal
works errr time!
Old 02-04-2009, 01:57 PM
Hawkze_2.3's Avatar
I have heated up dents with a heat gun and then sprayed them with cold water to remove the dents successfully
Old 02-04-2009, 02:53 PM
ABK
ABK's Avatar
sweet
lol, I like you mod list, lol
Old 02-05-2009, 06:42 PM
ek_bape's Avatar
Wow, I'm going to do this.
Old 02-05-2009, 09:20 PM
aznkr4zyboi's Avatar
i'm going to try this on my door dings. no damage to the paint at all?
Old 02-05-2009, 09:47 PM
PMK
PMK's Avatar
I'm not sure but I was told that you do not directly hit the dent area with the heat gun, I read somewhere that you should use something like aluminum foil wrap, hold it behind the dent and apply the heat, after 5-10 minutes of heating or maybe less quickly spray and coat the area all around the dent. This should work perfect for the small and simple dents that have no crease or sharp points. It works for my EK!
Old 02-08-2009, 08:38 PM
Frost7177's Avatar
you guys keep mentioning a heat gun do you mean a hair dryer? and then you said spray and coat the area with what co2?
Old 02-08-2009, 10:16 PM
PMK
PMK's Avatar
You can use either a hair dryer or heat gun, the heat gun will work faster but can harm your paint if you directly aim it for a certain spot, after this you will spray the area with CO2 or for instance I forgot what it was but you grab a can of air duster, flip it upside down and spray the area, the dent/metal will contract with the hot and coldness, they will pull against each other, popping out the dent!
harmonator84
Paint and Body
275
01-30-2018 09:22 AM
MechEng
01-16-2012 09:48 AM
MugenManR
04-15-2007 03:34 PM
Mistermark
Welding / Fabrication
18
02-17-2006 11:37 AM
[HrZn]4life
03-11-2003 05:19 PM
Quick Reply: Dry ice/Hair dryer and CO2 dent removal
