Door needs adjusting inward?? - Honda-Tech
Old 03-10-2011, 12:59 PM   #1
Default Door needs adjusting inward??
I recently bought my ek hatch and was noticing that the drivers door sits outward from the body in the back.. I know the doors where replaced by the previous owner with coupe doors so that he could do the power window conversion. Anyways ive searched and have come up with nothing. I looked at the door striker and they are not adjustable. Any ideas on how to go about adjusting this?
TriedAndTrue is offline   Reply With Quote
Old 03-10-2011, 01:04 PM   #2
Default Re: Door needs adjusting inward??
I would try moving the latch on the door jamb inwards.
boostedb20ek is offline   Reply With Quote
Old 03-10-2011, 01:37 PM   #3
Ive already looked at that. But like i said it doesnt adjust its fixed in there. The plate where it scews into the jam has indentations where the screws seat into there.. Im at a loss i kno i should just take it to a body shop but id like to know whats all entailed in adjusting it so i dont get screwed over in labor.
Old 03-10-2011, 02:47 PM   #4
likwidchz's Avatar
you have to adjust the 4 bolts holding the door on, you have to take the fender off, take the bottom skid skirt off and adjust it.
it helps if you take the door latch completely off adjust the door, then put the latch back on and get it situated. It really helps if you have 2 people, doors aren't light.
Good luck
likwidchz is offline   Reply With Quote
Old 03-10-2011, 03:28 PM   #5
Ok ive dont that before to adjust it back and forth.. Didnt know i could adjust it in and out like that as well.. Im guessing loosen the bolts that hold the bracket to the door and adjust them in?
Old 03-10-2011, 03:38 PM   #6
Hawkze_2.3's Avatar
You can also switch the countersunk screws that hold the latches to button head bolts and get some adjustment, just watch out for clearance with the bolt heads when the door closes.
Hawkze_2.3 is offline   Reply With Quote
Old 03-10-2011, 04:40 PM   #7
Quote:
Are you refering to the hinges or the striker screws?
Old 03-10-2011, 07:52 PM   #8
Hawkze_2.3's Avatar
The striker screws and the latch screws on the door (not the hinges).
Old 03-10-2011, 09:22 PM   #9
AP14TW's Avatar
have the same problem with my EF. I'm going to look into that!
AP14TW is offline   Reply With Quote
2000 Odyssey Sliding Door Alignment pcconway Odyssey | Ridgeline | MDX | Pilot | RDX | HR-V 0 09-21-2016 05:48 AM
Are Crx and Ef hatch Door Latches the same ? Si2See Honda CRX / EF Civic (1988 - 1991) 5 04-15-2012 05:13 PM
how to adjust the door? crazyboy Honda CRX / EF Civic (1988 - 1991) 2 04-18-2011 02:59 PM
EK door alignment (gap), please help. JLEK Honda Civic / Del Sol (1992 - 2000) 4 01-02-2007 08:59 AM
FS: Socal POWER DA doors whoa its len 2 Southern California (Sales) 27 03-24-2006 06:00 PM
Tags
06, adjust, adjusted, adjusting, adjustment, crv, door, dorr, fit, honda, latch, mdx, plate, rear, striker, tailgate
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
