covering up spoiler holes with just bondo
Old 08-24-2007, 03:24 PM
cilvia's Avatar
Default covering up spoiler holes with just bondo
i know im supposed to weld or put fiberglass first but is using just bondo ok?? what could happen in the future with my trunk with just using bondo??
Old 08-24-2007, 05:51 PM
msinsky14's Avatar
Default Re: covering up spoiler holes with just bondo (cilvia)
it would crack. have shop weld the holes shut, shouldnt cost u more than 20 bucks
Old 08-24-2007, 08:29 PM
kiickz4dayz's Avatar
Default Re: covering up spoiler holes with just bondo (msinsky14)
dont do bondo or you would have to do the job twice.
Old 08-24-2007, 11:06 PM
IP RACING's Avatar
Default Re: covering up spoiler holes with just bondo (kiickz4dayz)
dont do it
Old 08-25-2007, 05:52 PM
SneezinCD5's Avatar
Atleast fiberglass it first if you can't weld them up. The bondo is not for filling holes.
Old 08-28-2007, 08:12 PM
MEAN88Si4WS's Avatar
Default Re: covering up spoiler holes with just bondo (SneezinCD5)
And now for an alternate opinion:
I do it all the time.
Ive bondo'd the holes left by the 'honda' and '2.0Si' emblems on the back of numerous third-gen preludes.
None of it has ever cracked and fallen out.
For larger holes from a spoiler, I would recommend putting super glue gel all over a quarter, or any other round peice of metal big enough to coverthe hole, then gluing it to the UNDERSIDE of the hole, this gives the top bondo layer something to sit on, sand it all smooth and paint it up nice.
Make sure that quarter is glued on there good tho or it will fall out and take your bondo with it....
Old 08-31-2007, 08:03 AM
italianchooch88's Avatar
if u can get to the inside of the panel sand it with 80 grit then use fiberglass mat and resin/hardener mix to bond it from the back then the holes should basically be filled from the back.then just use filler or fiberglass jelly on the top.I just went through this whole thing with my emblems and side molding holes.
or u could just plug it just in case u ever wanna put the spoiler back on.
cloudx71
03-22-2005 10:34 PM
lilbastrd
Honda S2000
57
03-08-2005 09:16 PM
dawrenn
27
02-13-2005 04:19 PM
Integra_Boi
02-25-2003 10:58 PM
Quick Reply: covering up spoiler holes with just bondo
